Nideka biometric When selecting GLOG file it says: "Error(s) encountered while getting ATTENDANCE LOGS from usb drive". cant open the glog! help!
Buschchris1
  • 474 Answers
SOURCE: when i try to boot
Most likely a driver error or bad hardware. Could be a video card, modem or NIC, bad memory. try some basic troubleshooting, Remove all but the bare esentials. Take out any add is PCI devices such as modems or network cards, sound cards or extra usb ports. If you have onboard video but are using a AGP or PCI video card, remove that as well and use just the onboard.
If it works, then you know its one of the things you removed.
put on in and boot, then another and boot, till it has that problem again, Once it does, you will know it was the last thing you put in.
Remove it and test anything else you removed to be sure.
Then boot into windows and try un-installing any drivers and then re-installing them before putting it back in. This way Windows is ready for it when you hook it up.
If you still have problems, then the hardware may just be bad. Replace it.
IF you are still having trouble or think its something else, let me know, we can try other stuff.
Posted on Dec 01, 2008
  • 33 Answers
SOURCE: Car turns over wants to start but won't defin not starter
if your car has problems starting then gas shouldnt be the problem.. maybe an alternater or starter ignition
Posted on Jun 02, 2009
  • 13 Answers
SOURCE: Motor will turn on and run, but on heat...
it sounds like the hot surface ignitor is bad. if you have an ohm meter check across the leads going to the ignitor, it should read a resistance of some value, if it reads "o" the ignitor is open meaning there is a crack in the ignitor. you can remove it and visually check it for cracks in the coil, sometime they are hard to see so look very closely ,even under a magnifier glass.
a good ignitor should read 10 ohms if it reads higher it may still work for awhile but is definitly on its way to failing soon.
Posted on Dec 28, 2009
  • 51 Answers
SOURCE: internal error,failed to initialized HAL. i
To solve Root Password problem :
Type
Sudo su -
then you need to change the password for root. do this by typing
passwd root
and then enter your password
Please check this Link : http://www.linux.com/archive/forums/topic/2539.
Hope this have helped you. Please rate if it helped. Thanks
Posted on Apr 18, 2010
KevinWhite
  • 1902 Answers
SOURCE: The light for the drain glog is on and I lifted
Hello & Welcome to FixYa
The light is on as the unit won't drain or is unable to drain due to blockage in the drain hose. This problem usually occurs due to clogged/blocked drain hose or the drain pump not working. First try to clean the drain hose and drain pump filter for any clogs, then check drain pump operation. If the problem returns after cleaning then it is the drain pump that needs replacement. Please get back to me if you have any other questions.
Kevin
Posted on Dec 22, 2010
I forgot password of ls-838 lonestar biometric
The password is present to prevent the usage of it by a thief after it has been stolen.
May 25, 2014 | BestPriceCables Lonestar Biometric Time...
Biometric finger print verification problem in IE8 32Bit
go to control panel
open java
you see java configuration
go to security tab
select use java in brousers
and scrool down secruty bar to medium or low
restart computer and check
Feb 08, 2014 | SecuGen Hamster Plus Fingerprint Scanner
Takes 2 hours to dry one load
Check to see if you have any kind of glog in the dryer vent system. Check the filter, the ducting from there to the rear duct opening. Then check the ducting to the outside vent door & also the vent door outside should open freely.
Jul 29, 2011 | Dryers
Cant seem to remove the "write protection" error off my store and go micro flash
It has password protection. Open My Computer on your PC, insert the USB drive, open the password file, enter your password, then select the option to remove password protection from the USB drive. If this does not work, contact Verbatim for a solution, these USB flash drives have lifetime warranties.
Dec 29, 2010 | Verbatim CORPORATION 94933 USB 2.1GB...
I have a Badger insinkerator model 5Plus-7 which will not drain.
You have a glog in the p-pipe / drain pipe that is not allowing the water to pass and drain.
Jan 24, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Engine wants to stall with A/C on or off.
its proboly is the fuel filter whic is glog
Jun 06, 2009 | 2005 Chrysler PT Cruiser
Computers & Internet Logo
471 people viewed this question
David Payne
David Payne
