Question about Foxconn Dell Vostro 400 Motherboard , G33m02
Dell Inspiron 530. Power, but just fans. No post, no video, just fans. No noise, just fans. I replaced Power Supply, Motherboard, and Processor, nothing changed. I also tried a different monitor, and went from Video Card to Onboard Video, still nothing changed.
  • Steve Geile
    Steve Geile Oct 16, 2013
    I forgot. This is a Foxconn G33M02 Motherboard.
  • 55 Answers
Change the RAM modules or clean it and reinsert
Posted on Oct 16, 2013
I have a Dell Inspiron 530. Was getting 2 quick beeps on start up and loud fan noise. I replaced the cpu fan but the one I bought did not have the right plug for the motherboard connection. I had to modify...
This model (as well as many other Dell desktops) has a DUAL SPEED CPU fan. If the motherboard detects that the CPU temp is running hot it will increase the speed of the CPU fan to lower the temp of the CPU. You should do a Google search for the correct CPU fan and purchase it and install it back into your computer.
Aug 28, 2011 | Dell Inspiron 530 Desktop Computer
Computer wont turn on power light is yellow
Here is the Diagnostic LED information
http://www.fixya.com/support/r4282412-find_no_post_diagnostic_information_dell
Normally a solid Amber Power LED is a motherboard failure or a device attached to the motherboard (Expansion card or external device)
May 15, 2010 | Dell Inspiron 530 Desktop Computer
I am trying to power up my Dell Inspirion 530 and it just makes a beeping noise continuously. How do I fix this?
It could be many things honestly. A couple possibilities could be; you put in too much RAM/not the correction offset of RAM; CPU issues; System fan issues (though some computers will let you run it anyways pressing F2); Power supply issues; or something errored on the motherboard. Those are just a few off the top of my head. If you recently installed RAM, try putting things back the way they were previously and look online for your max RAM support. If not, look on the back of your power supply and you should see a brightly lit green LED. If it is dim, pulsing, or off...you will need a new powersupply. If light is bright and on, try opening your case and making sure all of the cables from the power supply are firmly in place on your motherboard. If after all of that and your computer is still having issues, you might need to replace your Motherboard/CPU, or both. Hope this helps. :D
Mar 21, 2010 | Dell Inspiron 530 Desktop Computer
Dell Inspiron 530 won't start up - is motherboard dead?
From your description, I agree with you assessment of a likely Motherboard failure.
Mar 09, 2010 | Computers & Internet
Solid amber light ON Dell Inspiron 530 desktop.The Fans start and stop immediately.The mother board has the power ON Amber light.
The Yellow Light of Death, anyway turn on Your PC, as it starts You will here some beeps especially on a Dells. Count the beeps , there will be a slight pause so it will beep once then pause then beep again. Count the beeps and that will be Your code. Go to Dell Support site and look up code. Most of the time a Yellow amber light means that there is trouble with Your Motherboard but thats not to say its the Motherboard itself, it could have possibly burned out Your RAM, Processor, Heat fan, even the power supply itself. So look up the code and at least You'll have a better chance of finding the solution, Good Luck
Mar 04, 2010 | Dell Inspiron 530 Desktop Computer
Have a dell Inspiron 530, getting a yellow ower lite and no boot. Fans turn on for a sec then shut right off. what is causing this?
Hello, Ray.
Sounds like a power supply problem - needs to be replaced. But, it's also possible that you have bad memory. So, taking safety precautions (disconnect all cables and touch metal once to dispel static electricity) and if you are comfortable, remove the cover of your tower, remove and reinsert your memory one module at a time and power to test.
If not, replace the power supply.
Hope this helps.
Dec 15, 2009 | Dell Inspiron 530 Desktop Computer...
Solid Amber light when starting the Inspiron 530 . Every time i start the Dell inspiron 530, the solid amber light comes on and it dont start. As per Dell user manual i have tried everything but of no use....
Amber led simplifies a start-up-error. This could be a number of things.
For example:
Check if HDD is connected properly
Check if RAM is connected properly / also if this is damaged your pc wont start.
Check your m/board for any loose capacitors an if they are not popped at the top.
Your LCD screen is properly plugged in to the m/board and if the cables aren't damaged they are very thin and fragile.
also could be the power supply...
Goodluck
Ryno Gerber
Jul 30, 2009 | Dell Inspiron 530 Desktop Computer
Dell inspiron 530s is giving me major trouble. When ever I turn it on, the power button lights up and the fan turns on but then thats it. There is no activity on the monitor, just the loud noise of the...
my inspiron 530 giving me trouble. Blue light is on, but the computer goes no where. Try to start by shutting down and restarting but the start sound keeps coming fora long time and nothing happens. So to say having trouble starting and sometimes it shuts down but the blue light stays on. Sometimes I cann't even turn off the computer by pressing blue light - trouble trouble trouble
Feb 22, 2009 | Dell Inspiron 530s Desktop Computer...
Foxconn Dell Vostro 400 Motherboard , G33m02 Logo
112 people viewed this question
Top Foxconn Computers & Internet Experts
Rommel Balcita
David
David
Gareth Cockram
Gareth Cockram
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
