Question about Water Heaters
1993 gm 28ft allegro bay rv water heating system just got it and dont know how to turn on hot water can u help
  • clay May 11, 2010
    Is is an electric heater, gas heater or dual (both gas and electric) heater?
    President:
  • 3,433 Answers
Chk for shut off valve to heater , open if closed. Open hot water faucet and listen for water pump. if pumping givre it time to fill heater tank and start runnuing out offaucet. Air will be purged as pump fills the lines and heater. Shoer and bath need hot faucets open also to purgr air.
Posted on May 07, 2009
Boiler won't ignite for hot water unless heating is on.
If this is in a RV the propane monitoring valve may require more gas flow to turn on than the water heater requires. A central heating system requires substantial gas flow so when the monitoring valve opens to fire the central heating, there is enough gas flow to also fire the water heater.
Jan 26, 2016 | Water Water Heaters
Need to separate heating and hot water - just have hot water on
You need a heating engineer to come in and do this.
Sep 09, 2017 | Water Water Heaters
Have atwood 6 gal water heater for an rv. Heats water on gas mode but no hot water in electric mode? Help please!
Sounds like selector switch is bad. I would start there first. If not the switch, heating element probably burned out.
Sep 08, 2014 | Water Heaters
My atwood rv water hearter is not working right
Model # please? Does it spark outside when first turned on?
Jan 25, 2014 | RTO Atwood Water Heater - 6 Gal LP
Fan come on but there is no heat, there is gas because I could turn the stove on. the Heater was working fine, but when I went to turn it on the fan will blow the air but it never got hot it was blowing...
I'm thinking the heading should be furnace so here goes. Need to test for 12 volt power at sail switch, and high limit switch as well. If you give me the model number may be able to guide you better. If you shut it down/off, and remove 2 screws holding cover on, inside your RV , you should see a model number like SF-- or NT -- on a stamp or label. Let me know if you find it and need more help.
Jan 26, 2010 | RTO Suburban Rv Water Heater Dsi Gas Valve...
My rv water heater ignites, I have a steady flow of water in the sinks from the hot water spicket, but no hot water. The bypass valve is positioned paralllel to the cold water valve. I am not sure of the...
If your lighting and not getting hot water then you have a valve closed or your by pass is in the wrong position, if it is burning on gas it will heat water
Sep 06, 2009 | RTO Atwood DSI-RV Water Heater-6 Gallon
RV water heater problem: my water heater ignities, when I turn on the hot water faucet there is a steady flow of water but no hot water. The bypass valve is parallel with the cold water line. I can only...
The first question is this
From the outside of your RV is the water heater square or is it longer than it is tall?
If it is square it is a Suburban
If it is longer than it is tall then it is an Atwood
Forest River mostly uses Suburban
How long do you let the unit burn/run before you try the hot water? From a cold start it will take - depending on the outdoor temp. & the gallon size of your water heater, 15 to 30 minutes for the water to get hot.
If you have waited this long then I would suspect the bypass valve is in the wrong position
Hot Water Heater in 1991 Pace Arrow RV is not working
If you look on the outside of the RV, you will find the vent for the water heater behind and access door. There usually is a drain plug and valve located as well. Generally they will be tucked away under the kitchen sink area with internal access as well. You will need to find where the valve that shuts the water off to the unit is and turn it on. Most times the water heater is either electric or propane. But sometimes they are only propane. Once your find the access door, you will know where the water heater is. You can also contact Fleetwood who makes the Pace Arrow to see if they have any information on your unit. Usually your unit info or trim number will be located on a little plaque right by the entrance to the RV. You will need this when you contact them. Hope this helps.
Mar 31, 2009 | Water Heaters
Attwood RV Water heater model GC6AA-10E overloads breaker when
I would remove the heating element from the hot water tank. Take a look at it as it is probably fried from due to turning on the power to the tank when there was no water in the tank. If it looks ok still do a continuity test on it. I believe that is your culprit.
please mark this answer as a fixya!
Mar 09, 2009 | RTO Atwood DSI-RV Water Heater-6 Gallon
Water Heaters Logo
354 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
