Question about Magellan MAESTRO 3100 98083401 GPS Device
Charger receptecal yellow liner inside charger receptacal has gone inside can't plug in the charger
  • 846 Answers
There is a website that shows you how to replace GPS DC-Jacks, parts are usually available on www.ebay.com. The repair tutorial is a : GPS Repair
Posted on Apr 24, 2009
How can I determine whether the on-board charger is working?
The m51 is notorious for failure of the on-board charger. An easy check would be to plug an off board charger into the 3 prong female charging receptacle at the front of the joystick to see if you can bring the voltage up. You can test the on board charger with a voltmeter at the battery connections or charger joystick port with the charger plugged in. Hope this helps
Jan 13, 2016 | Invacare Pronto M51 Power Wheelchair
How to charge the batterry
the charger port is located under the front of the joystick. with the charger off plug the 3 pin connector into the charger port then turn the chrger on or plug it into the wall. You should see a red and a yellow light when the yellow light turns green the batteries are charged turn off the charger and remove the plug from the joystick See my tip on charging Hope this helps you
Jun 05, 2011 | NRS Hoveround MPV 4 - Hovaround Used...
Hi we have just purchased a 2nd hand 2000 volkswagon beetle for our daughter. It is a beautiful car & well cared for. the only problem we are having is the sunroof liner (on the inside of car) has...
YOU HAVE TO TAKE CAR TO A UPHOLSTERY SHOP TO REPLACE HEAD LINERS.HEADLINER REPLACEMENT WILL COST ANY WHERE FROM $200.00 TO $300.00 TO CLEAN OLD HEADLINER MATERIAL.GLUE IN NEW LINER.CALL AROUND ON PHONE GET SOME PRICE CHECKS.
May 03, 2011 | 2000 Volkswagen Beetle
MY scooter battery needs recharged and I plugged it in and it indicatied it was fully charged and it wasnt. So I bought a new charger and that is showing the same thing. I dont know what to do next. The...
Has the scooter been stored unused for a while? If so, the batteries may have gone solid from improper maintenance. There is a gel inside the batteries that needs to have current run through it at least once a week to keep them fluid. The charger is showing a green light because it senses the batteries are full, but instead of being full of power, they are full of crud and need to be replaced again. If the batteries have been properly charged but you still cannot get power, check all your connections to make sure they are tight and that your fuses are not blown.
Oct 12, 2010 | Electric Mobility Health & Beauty
The charging yellow light is not on when I plug the charger. The positive and negative terminals hooked correctly and I am charging it at 120 volts, 6 amps
the wire at the clamps might have came off,there is a thermal fuse inside the charger also, get one at the auto parts store .bring the old one with you. OR some of the newer chargers are fussy that the battery must have some power to get the charger to turn on.. i use jumper cables to get my charger started..
DID I HELP ? VOTE . THANKS J
Sep 12, 2010 | Schumacher & Fast Charge Starter Charger
Wire broken off inside of liner at both ends
Hi Ray,
You can remove the liner from the gun and replace it - probably cost you about $15. Liner comes out from rear of the gun. The rear of the gun (that plugs into the feeder) is removable. Once this is out, you can remove the liner from the rear of the pin. Remove front end consumables, install new liner, cut it to proper lenght at front of the gun, and replace gun back into the feeder, reinstall the front end parts and run wire through and beyond tip, cut it leaving about 1/2". Now you can weld again.
Apr 19, 2010 | Lincoln Electric LINK2400-+1 CV-305 MIG...
Seised wire inside feeding tube
You can replace the liner by removing the shroud tip, and pulling the spring (liner) from the machine end of the trifgger cable.
Liners are replaceable.
Dec 23, 2008 | Hobart Handler 140 Mig Welder
Toshiba satellite pro a200 my laptop has stop recharging i don't know if its the adapter or the battery
It might mostly be the charger that has gone bad or check inside the DC in plug on ur machine and see that its not broken if not its the charge control chip that has gone bad
Sep 04, 2008 | Toshiba Computers & Internet
Magellan MAESTRO 3100 98083401 GPS Device Logo
88 people viewed this question
Top Magellan GPS Experts
Jungle Ghost
Jungle Ghost
Are you a Magellan GPS Expert? Answer questions, earn points and help others
