Question about Price Pfister 34-3LC Genesis Kitchen Faucet with Spray - Polished Chrome...
Horseshoe bracket - Price Pfister 34-3LC Genesis Kitchen Faucet with Spray - Polished Chrome...
Horseshoe mean whit an exclamation point
forenza daewoo wonder car.
no year, no joy, sorry
the operators guide in the glove box answers this on all cars sold.
lost it? , suzukipitstop plus sells it. google that. $4 day pass, hint?
here is GENERIC page.
http://dashboardsymbols.com/the-symbols/
Sep 03, 2014 | Suzuki Forenza Cars & Trucks
Where is Horseshoe Canyon?
"in a remote area west of the Green River and north of the Canyonlands National Park Maze District in Utah, USA."
Horseshoe Canyon Utah
Jul 14, 2014 | Computers & Internet
Warning light appeared on dash of my 06 bmw 320d looks like a horseshoe
The warning light that you see is for tyres maybe one of your tyres is flat you can check that all the tyres for pressure then you can rest the warning light.
Mar 08, 2012 | 2006 BMW 320d
How do you install the kickdown cable on a 97 dodge caravan
rotate throttle linkage cam to wide open position, remove cable from slot.squeeze the retaining ears togethet to remove cable from bracket. you will need a flashlite to remove cable from accelerator pedel disengage retainer from top of pedel.remove the horseshoe shaped clip from grommet at fire wall,work grommet out of hole then pull cable out from engine compartment side of firewall. install in reverse of removal
Jun 14, 2011 | 1997 Dodge Caravan
It looks like a horseshoe with an explaination point in it
i'm pretty sure it's either the tire pressure monitor or the traction control. the horseshoe is supposed to represent a low tire pressure
May 21, 2010 | 2008 Volkswagen Rabbit
Replace window regulator
Give your self about an hour and you'll easily have it done. Remove all screws and obvious retainers to the panel (usuall popped on press fittings) Thw window winder handle can be removed with a wide shoe lace or similar . It's retained by a horseshoe shaped spring clip. Use the lace to pull the clip in the opposite direction to the horseshoe clip and try not to loose it ! Pull on panel to remove,This should give you free acess to winder mountings and the glass retaining/mountion brackets. Disconnect glass and remove for safety. remove winder mechanism and reverse proceedure to re- assemble. Ensure all fittings are tight and good luck
Apr 11, 2010 | 2003 Honda Accord
Light on on the dash.located in the lower portion of the speedometer area. looks like a horseshoe with a few lines in it.
It's probably the tire pressure sensor (looks like a horseshoe with the open end up and sometimes an exclamation point in it). Check the pressure on all your tires.
Mar 09, 2010 | 2008 Dodge Avenger
Exclamation mark with horseshoe light is on
it is the tire pressure monitor. It means one of your tires has low air pressure.
Dec 02, 2009 | 2006 Jeep Grand Cherokee
Sort of horseshoe shape exclamation mark in middle
its the tyre pressure monitoring system...check for a deflated tyre
Nov 09, 2009 | 2004 Mini Cooper
Front end sqweeks when iturn sterring wheel
needs to be greased. get a grease gun and crawl underneath and add grease to all grease zerks. your sway bar bushings could be dry too. spray them with some silicone lubricant. there is a bar that runs the width of the vehicle underneath usually between radiator and engine. This is your sway bar. There will be two metal horseshoe shaped brackets with rubber surrounding the bar. The rubber is your sway bar bushings.
Oct 05, 2009 | 1996 Ford Explorer
Price Pfister 34-3LC Genesis Kitchen Faucet with Spray - Polished Chrome... Logo
67 people viewed this question
Top Price Pfister Plumbing Experts
john h
Mike
Are you a Price Pfister Plumbing Expert? Answer questions, earn points and help others
