Question about Dryers
Bonnet hair dryer will not heat - Dryers
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 142 Answers
Check for 240V from breaker or check bot fuses...not just one.
There is a thermal fuse somewhere that, if it is open, the heat will not come on. This would be the high limit Thermostat. Find it on your diagram or test all your thermostats that they are good. Test using an Ohm meter. Replace defective fuse or thermostat.
Posted on Oct 19, 2013
How do I know when the thermal fuse for my whirlpool deut electric dryer is bad?
Take it out. check it with a multimeter set on ohms. Get a hair dryer turn it on hotest setting. with meter leads on each end of the thermal fuse have someone hold the hair dryer blowing hot air on fuse. It should show continuity through it when cold. After heat is applied it should show 0 or infinity. If its working properly move on to over temp switch.
Sep 02, 2014 | Whirlpool GEW9250 Electric Dryer
Sunbeam 1400w hair dryer doesn't blow out any heat
This is a hair dryer correct? Only two things can be the problem here.
1) a wire is disconnected or broken that provides power to the Heating element. Or 2) the heating Element is burned out. Do to UL regulations these hair dryers are not supposed to be repaired by anyone not having sufficient electrical knowledge or Factory training. A wire or a n Element burns out FOR A REASON, normally excessive heat causes failure of the unit. They are cheap enough to replace without being put out by extreme costs. Do yourself a favor buy a new one.
Apr 06, 2014 | Dryers
Hair product
Talk to the manufacturer not this forum.
Aug 22, 2017 | Garmin Health & Beauty
How to close hair dryer
Hold the blue 'bar' looking handle in the front in and you should be able to collapse it.
Feb 15, 2013 | Gold N Hot 'N Hot GH9271 Professional...
What are thermal hairbrushes and are they worth buying?
Thermal hair brushes are special brushes that are used while blow-drying. They work with the heat of the hair dryer to help style your hair. Smaller thermal brushes can act like hair rollers.
Feb 14, 2013 | Health & Beauty
Power supply problem on pavillion
What are you heating with a dryer? i have never heard that one before? Who came up with that idea and why? Are the fans comming on? Curious?
Dec 26, 2012 | HP Media Center m7250n (ED842AA) PC...
Freezer door got stuck
Careful how you go about opening it. If it moisture is frozen to the seal and you rip it open you could damage your seal and then the problem will get worse not better.
What works best for me is to use a large putty knife with a hair dryer. I heat the blade up somewhat with the hair dryer and slowly work my way around the seal heating the putty kife blade with the hair dryer.
Once you get the door open, examine your seal very closely. If there are pitts or tears - replace the seal.
Also check to make sure that the evaporator fan is operating.
Jun 16, 2011 | Jenn-Air JFC2089HE French Door...
Gas dryer heats then wont heat?
Bad ignitor most likely. Has a hair line crack, and yields an iffy contact.
Jun 21, 2010 | Maytag MDG2706A Gas Dryer
S-type 2000 badge removel how to do it
Gradually heat up the badge with a hair dryer which will soften the sticky material holding it on, lift the bonnet , locate the badge underside and gently push off.
Jan 18, 2010 | 2000 Jaguar S-Type
Dryers Logo
Top Dryers Experts
