Question about Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348
I have a husky model yth2148 and need a carburetor. Where can I find one?
  • Husqvarna Master
  • 2,478 Answers
Go to www.jackssmallengineparts.com
Posted on Oct 16, 2013
  • 1 more comment
  • Larry
    Larry Oct 16, 2013
    None of the parts sites even show a carburetor for the Husky YTH2148. I have a parts manual and there is no carburetor shown on the schematic. Thanks anyway.
  • Dennis Key
    Dennis Key Oct 16, 2013
    Whats your engine no.?
  • Dennis Key
    Carb. no. on the carb. flanges. May try repair clinic.com
How do I hook up my throttle wire to the carburetor on my 1991 husqvarna 40 chainsaw (or route it)
Also as old as my Husky 37.
It appears to route the handle and to the carburetor mounting area.
Here is the IPL for the Husky 40.
http://cdn.husqvarna.com/ddoc/HUSI/HUSI1998_AAaa/HUSI1998_AAaa_I9800044_.pdf
Dec 02, 2014 | Garden
Husqvarna yth2148 isn't getting fuel to the
Check the plastic fuel line as it become hard due to the heat from the engine and cracks from the vibration
Oct 19, 2014 | Garden
Husky 125B blower, new right out of the box. starts, runs about 30 sec, bogs and quits. I'm guessing likely needs carb adjustment, but set screws are not regular slotted screws. Looks like it requires a...
My name is Dane and I am going to assist you in solving your problem.
You will need to adjust the high speed setting on your Carburetor jet. Turning the screw out just 1/2 turn or so should do the trick. It is not so hard to adjust the Carburetor, however, yes you do need a special tool that is very hard to get your hands on, in order to adjust the jet screws. They don't make many engines with plain screw heads anymore. The newer Carburetors are factory set lean so they can pass emission standards. Since you just bought yours, a local husky dealer should adjust the mixture for free. I hope I've helped. If you found this reply useful, please leave me some THUMBS UP, if you feel I
Dec 09, 2010 | Husqvarna 28cc Hand Held Blower HVH 125B
I need a drawing of a carburettor on a 61 Huaqarrna chain saw\r\nwhere do I get it? It is a husqvarna Chain saw
You didn't specify of its a 61 or a 61 Rancher. Here's the info you need to take to your Husky dealer. The diagram will be with the major repair kit.
Model 61, then the 61 Rancher:
CARBURETOR Model 61: ecblank.gif Tillotson HS-163A, B , HS-254A series or
Walbro WS series
MAJOR REPAIR KIT: ecblank.gif RK-23HS for HS-163A MINOR REPAIR KIT: ecblank.gif DG-5HS/T for HS-163A
CARBURETOR Model 61 Rancher: ecblank.gif Tillotson HS-163A series or
Walbro WS-17A, B series
K10-WS
D10-WS
May 18, 2010 | Husqvarna Garden
Can't get our Husqvarna YTH 2148 lawn tractor to start this year. I suspect it's old gas in the carburetor. Drained the remaining gas from tank and added new and everything else looks good. Battery &...
On my YTH2148 you take off the air cleaner and then the backing plate for the air cleaner and the carb is right there. If memory serves me there is a drain hole on the bottom of the carb, you can unscrew the drain bolt and the old gas is gone.
Apr 05, 2010 | Husqvarna Garden
Husky starts but won't run off choke. mod 359, cleaned carb, gas, new plug. parts manual doesn't show where hose from intake boot goes?
There are 2 lines from the fuel tank on my 359. The one with the fuel filter on the bottom goes to the carburetor. The second goes back down through the plastic housing and appears to be capped off underneath, probably a vent.
Illustration J shows 2 lines.
http://weborder.husqvarna.com/order_static/doc/USA/2006/I06000/I0601077.pdf
Below the carburetor the is a u shaped hose both connections are within 3/4' of one another below the carburetor. I think it is pn 537 24 65-01 on detail G. HTH
Lou
Your serial number is the key to the correct IPL for you saw.
sn 06 1500198.
06 - year made (single digit prior to 2000)
15 - week made (mid March)
00198 - 198th unit produced by Husky that week.
Oct 02, 2009 | Garden
Hard to start when cold starts one pull when warm
Hehehe. It's a "husky". The problem is not uncommon even with Husky motorcycles. Some things to check are: Correct sparkplug; correct gap; no carbon buildup: Correct gas/oil ratio mixture, old gas is a NO: Weak or stiff carburetor diaphram. Maybe this will help. I sold mine and a friend sold his because of this specific problem. I also sold my race winning Husky "trials" motorcycle because of this aggrevation.
Jun 26, 2009 | Husqvarna Garden
Need to adjust carburetor jets of homelite chain saw
what is the adjustment for high and low settings on a homlite 330 ?
Jan 11, 2009 | Garden
Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348 Logo
53 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
