I am not sure my machine is agitating correctly. This is my first load and all it does is swish back and forth. Is this normal agitation.
    Master:
  • 818 Answers
Nicki-you must have a front load machine or an older model that you can lift the lid on. Or this may be a new machine to you-unfamilar with-a make and model number would be helpful-the last new washer we got said on the lid-your new machine will not make the same noises as your old agitator-cheers Denny
Posted on Oct 16, 2013
  • 1073 Answers
SOURCE: Whirlpool Wash Machine and Agitator
check the direct drive coupling between the motor and the transmission
Posted on Apr 21, 2008
mastatech
  • 478 Answers
SOURCE: agitator only turns clockwise (Whirlpool top load)
You will need to replace the dogs under the agitator, they are pretty easy. Just pop the cap, take out the center bolt, remove it the dogs are 4 teeth looking items.
Posted on Mar 13, 2009
  • 5 Answers
SOURCE: thumping hitting front stops on wash cycle.
if it was not NEW and under warranty, you bet i would ask for your paid service in heartbeat.
the repairman is arriving finally tonight.i will update what he finds.
Posted on Apr 06, 2009
Maytag317
  • 1136 Answers
SOURCE: agitator stopped moving back and forth
Hi, Can you tell me if the spin cycle works? It sounds like maybe a couler has gone bad. Also check and see if the lower half of the agitator is working at all.
Please let me know and I can help you through this.
Thanks
Vic
Posted on May 28, 2009
milten1
  • 1304 Answers
SOURCE: My top load washer will not agitate or spin, but
if you have aaccess to the belt already,
start the machine let it fill
then keeping an eye on the motor and the clutch underneath it, sounds like your clutch might be slipping..
you will notice immediately the motor will be spinnging but the clutch will not engage
ive included the part number
and phone number to call
AP2045377
1-800-477-7278
aplliancepartspros.com
runs about 120.00
but its a pretty easy repair especailly since you figured out how to open the cabinet
Posted on Oct 09, 2009
The agitator is only working in one direction so the washing is getting tangled
The top portion of the wash tub agitator is designed to rotate in the clockwise direction. It should be intermittent. Turn stop turn stop ....in its normal operation.
There is a set of plastic cams that allow for this function. Below the top agitator the lower agitator goes back and forth. With a short load the water just reaches the upper agitator. Try short load. Other possibility the tub is under filled try increasing the water level.
26221857-hkbf5riehselkv40qtw2in2z-5-2.jpg Two piece agitator
26221857-hkbf5riehselkv40qtw2in2z-5-5.jpg Two piece agitator.
Hope this helps?
Jun 20, 2016 | Washing Machines
How to remove clothes stuck under agitator
the agitator should pull straight up, you may have to twist it back and forth as you pull upward. when you put it back on make sure its all the way down and in place, this may be the reason your clothes are getting stuck under it.
Aug 23, 2014 | GE WBSR3140DW Top Load Washer
Does the whirlpool ultimate care II washer agitate like regular washing machines?
it sure doesnt, whirlpool agitation should be a very fast, short and rather violent looking/sounding back and forth motion unlike most other brands where it is a long smooth sweeping motion back and forth
Oct 28, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
The agitator is not agitating when you start it and it seems to be loose and rocks back and forth
the agitator will rock back an forth. what you will need to watch for is how it washes. fill it will water at a low water level setting. listen for the splashing. if you hear splashing then the agitator is fuctioning correctly. you might have something else wrong with your unit.
Oct 15, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Thumping hitting front stops on wash cycle.
Apr 05, 2009 | GE Washing Machines
Agitator only turns clockwise (Whirlpool top load)
Mar 12, 2009 | Whirlpool LSB6200KQ Top Load Washer
Just spins during the wash cycle
Sounds like the agitator got dislogged during moving. In some machines the design allows for the agitator to move up and down alittle too much. Try this and this is only a guess. With the machine empty push down firmly on the agitator and move it back and forth as you do. You might hear a little "pop". If it does, try running the machine again. If it works problem solved, if not tell what happened.
Jul 17, 2007 | Whirlpool GSC9455 Top Load Washer
Grinding niose from agitator.
If the fill and drain functions correctly, AND the spin cycle works correctly, AND the cycle itself starts and completes correctly, the problem being that the back and forth motion of the agitator starts the loud grinding noise, it will likley be broken gears in the transmission. The single most expensive part in the washing machine.
Feb 04, 2007 | Maytag Atlantis MAV6451 Top Load Washer
Open Questions:
Washing Machines Logo
18 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
