Question about Electrolux Frigidaire Professional Series 24 in. Built-In Dishwasher Dishwasher
Tried to start it and nothing. Waited a few min. and it started, then stopped after 3 min.
  • Official Brand Answer
  • 4,342 Answers
Hello Richard, thank you for allowing me to assist you!
Let's try resetting the dishwasher by either unplugging it or flipping the household circuit breaker to the off position. It is important to wait roughly ten minutes and then turn dishwasher back on. Confirm that the door is properly latched and try selecting a cycle. If resetting the power does not correct the issue, it could potentially mean a number of things: a potential wiring failure, damaged cord, faulty door latch assembly or control board. Because it could be a number of any one of several underlying causes, I would personally contact a professional to accurately diagnose your dishwasher to determine the root cause to reduce the risk of unnecessary parts.
Posted on Oct 16, 2013
Battery is brand new i just had it out for a 10 minute ride and turned it off for 5-10 mins and i went to start it back up , all the lights were on but it would not do any thing wheni tried to start it i...
Hi,rather than jumping the gun as the bike was running fine before you had new battery fitted,I would say to have the starter checked first.good day to you.
Mar 29, 2015 | 2001 Suzuki VZ 800 Marauder
My wife was using lawn blower, after about 15 mins it cut off. she checked fuel, tried to start again and nothng. waited 10 mins tried again nothing. I checked gas/air filter etc. all o.k., no sign of...
Remove plug, leave plug wire on plug wrap a piece of conducting wire around the plug base and other end of wire wrap around metal part of engine pull starter and see if you have spark. You may have to darken area to see spark. If you have no spark probably bad coil or could be just switch has gone bad.
Aug 09, 2017 | Husqvarna 28cc Hand Held Blower HVH 125B
2001 dodge neon, it was raining and I was driving along fine when suddenly the car seemed to have no power. all the electrical stuff was still working lights, radio, etc. but it wasn't running any more. I...
I would start by checking main fuses under the hood. water could have cause a short also check battery cables to see if they are heavy enough to carry the amp load needed to start the car. factory cables are not heavy enough after a few years.
Aug 07, 2013 | 2001 Dodge Neon
Ford explorer starts good one second and wont start the next until you try a few times
Check for loose or broken connecting wires to your sensors (MAF, camshaft position, etc.) and engine control unit.
Oct 19, 2012 | 1996 Ford Explorer
94 mazda mx-3 does nothing when trying to start it
It could possibly be a short in the ignition itself.
Jun 13, 2012 | 1994 Mazda MX-3
2003 mitsubishi eclipse timing belt broken symptoms
its quite possible that the timing belt broke. if broke the camshaft will not turn, and therefore no start of engine.
Feb 21, 2012 | Mitsubishi Eclipse Spyder Cars & Trucks
Fuel pressure intermittently drops causing sputter and die.
check for 12v constant at your fuel pump if you are not getting that replace your relay.
if you are getting 12 volts at your fuel pump the fuel pump is possible to run tuel it gets warm then shut down to a lower rpm I would then replace the fuel pump
Oct 10, 2009 | 1994 Dodge Ram
Kia Sedona stopped running.
When is the last time you changed the oil? It sounds like you have gummed up your motor.
Jun 23, 2009 | 2002 Kia Sedona
2006 hard starting will not stay running, then no power at all.
What happens when you turn the key?... is there a clicking or clunking noise?... try tapping the starter and the solenoid that is attached to the starter and see if that helps. It may help if you have someone else turn the key while you tap on the starter and solenoid.
May 06, 2009 | 2006 Dodge Ram 1500
Electrolux Frigidaire Professional Series 24 in. Built-In Dishwasher Dishwasher Logo
162 people viewed this question
Top Electrolux Dishwashers Experts
Mike
Starnley Johnwells
Starnley Johnwells
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
