Question about Mega Bloks Dragons Man-O-War Play Set
Billy beats plays one song regardless of changing the mode buttons
How to program drum beats from one alesis sr16to another alesis sr16 drum machines
5.4J Copy a Song to Another SR-16 Via MIDI
The SR-16 can send Song system exclusive information to another SR-16 via MIDI. If you have only one SR-16, you can skip this section.
1. The source SR-16 should be in Song mode and stopped. Connect the source SR-16 MIDI out to the destination SR-16 MIDI in.
2. Select the Song to be copied.
3. Press and hold the COPY button, and keep holding it down until step (5). The display says COPY TO SONG.
4. Do not enter any destination Song number-just press PLAY to send the data out over MIDI. It will end up in whatever Song number had been selected at the receiver. If the Song was not empty, the new Song steps will be appended to the existing Song steps.
5. Release the COPY and PLAY buttons.
Caution: This does not transfer Pattern information, only the song steps. To transfer Patterns to another SR-16, see section 3.3D and 3.3E.
Hopefully this helps, it comes out of the SR16 Manual, page 40 I think
Cheers Pete
Sep 25, 2014 | Alesis Sr 16 Stereo Drum Machine
How do i transfer patterns from one sr-16 to another?
There are two ways. 1st way is to use the tape out and a 1/8 to 1/8 cable connected to a tape recorder or computer. And use the send thru tape function. while recording. then on the second one reverse the cable. And use the tape in function. The 2nd way is to copy beat for beat in the quantize mode by hand onto paper, the reprogram each sound(beat) back into it.
Aug 18, 2011 | Alesis 16 Bit Stereo Drum Machine System
How do I get my sing a ma jig to sing its song
push the hand button to change modes until it says sing or something similar (they all vary a little)
then push the belly to the beat of the song, you ll get the hang pretty quick.
good luck!
Jan 29, 2011 | Toys
Only playing a few sec of the song and then going to the next song
your player is in the "intro mode" , to change this follow these steps.
  1. play a song and while the song is playing
  2. press the menu/mode button and then with repeat highlighted,
  3. press the menu/mode button again to enter the repeat settings sub-menu
  4. press the right/left keys to change and highlight the repeat setting from "intro" to the mode of your choice like "repeat all"
  5. press the menu/mode key to save your setting...
Since this is a free answer,please take the time to rate my response,thanks.
Oct 09, 2010 | Toymax Impecca MP-1825 MP3 Player
Playing by album
To change the play mode on the GPX ML648B you need to play a song, hit the MODE button on the side of the player and select Play Mode.
The options are INTRO (this will play about 10 seconds of a song and then go on to play the next 10 seconds of every song.) NORMAL which will just continually play through everything on your device, Repeat One, which will repeat one song, FOLDER which I'm not sure of, FOLDER REPEAT which I assume repeates a folder, REPEAT ALL and RANDOM.
May 19, 2010 | GPX ML648B MP3 Player
Wont play the whole song
Sounds like the player is running in INTRO mode, only playing the first part of each song. To change playback mode, follow the steps as described below.
Switch the player ON and start music playback:
1. Press PLAY button to START music to play
2. Press PLAY button again to PAUSE the playback
3. Press MODE button to enter playback mode selection
4. Scroll with MODE button through selections
5. Press MODE button when selection REPEAT is in the display
6. Use MODE button to select from: Normal, Repeat One, Repeat
within current Folder (if any), Repeat Folders (if any), Repeat
All songs, Random Play back, and Intro
7. Press MODE button to confirm selection
May 02, 2010 | Element Electronics GC823 MP3 Player
Song plays and go to another
Your MP3 player is in INTRO mode. To change this, play a song and press the MODE button (button on the side of the player). Then select PLAY MODE from the options. Then select NORMAL. Or whichever option on that menu that pleases you. Just be sure not to choose INTRO again. :D
Apr 25, 2010 | GPX ML648B MP3 Player
Rock Band 2 Wii bundle song selection problem
You must beat songs before they can be unlocked.
Play the career mode and beat some songs.
Later on, these songs will become available.
If they do not appear once the career mode is beaten, contact the company because some disks end up being badly burned and are missing songs.
Regards
Jun 24, 2009 | Nintendo Rock Band for Wii
Changes songs every 15 sseconds.
its in intro mode.
during the time a song is playing, click down the mode slider, slide it to play mode, click the mode slider again, slide it to normal, click i down again, and it should be fixed. (the mode slider is the button on the top of the mp3 player)
Jan 09, 2009 | Nextar MA933A MP3 Player
How can i get it to play to the next song
Well, you can press the button you use to change songs. If you press it, you get options. Move the mode button and find play settings and you will find normal mode. Press the mode button and you will solve the problem.
Aug 13, 2007 | Mach Speed Trio DA-8033 MP3 Player
Mega Bloks Dragons Man-O-War Play Set Logo
Top Mega Bloks Toys Experts
thegtw
Nikki  Mclean
Nikki Mclean
Javier Segura
Javier Segura
Level 1 Expert
Are you a Mega Bloks Toy Expert? Answer questions, earn points and help others
