Question about Garden
Why do chainsaws not have sumps - Garden
Husqvarna 266se everything is brand new piston,rings cylinder carb coil muffler and it still won't start even checked the timing it is set right
did you replace the worn out seals on the crank shaft?
if not then the compression made when the piston comes down into the sump to push the mixture up in to the cylinder is lost and there is no air to compress for the next power stroke
when the piston goes back up , the low pressure in the sump sucks air past the worn seals and not an air/fuel mix
probably the reason that you thought that you had to replace the rings and piston in the first place
Feb 17, 2016 | Husqvarna Garden
What is oil capacity of unidentified chainsaw?
I would suggest draining the oil sump and measuring it as you re-fill it. Use measuring devices with oz or ml increments. I don't see your question as relevant though. When a guy is cutting wood, you just fill up the oil and gas and cut. There's no measuring required. Of course I understand there is probably another reason for the question as posted...
Oct 01, 2015 | Garden
Chainsaw rattles when it stops
personally too much hassle prefer Stihl Chainsaw more reliable Seizing is caused by lack of lubrication, First check all level has oil pump seized or is it sump type when running oil circulates all way round, Still there has to be a oil reservoir if this is bone dry theres your problem the rattling is metal on metal with no protection and the damage is seizing caused by lack of oil I have two chainsaws both have oil sumps and are kept full, please check hope this helps
Feb 15, 2014 | Poulan Pro PP5020AV 50 cc Gas Powered...
Bar oil leaks out when not in use
There will always be an amount of bar oil leakage when the saw is not in use, this is due to leakage through the tank breather, and oil caught up in areas of the saw which drain when the saw is stood, if there is not enough saw dust to dry the oil up ( this can happen useing long bars, but only cutting small logs ), if the oil leakage is not excessive i would suggest this is normal. The oiling is a constent loss system, so is not sealed as well as a car sump for example.
Sep 17, 2011 | Husqvarna , No.455 Rancher, 20" Gas -...
I ran my flotec sump/effuent pump dry, model 001D05S. Now it buzzes and doesn't pump. Can I fix it, if so how do I take it apart.
Unfortunatly if you ran it dry for very long it most likly burned out and will require replacement. Sorry. Thank you.
May 29, 2011 | Garden
Oil will not feed to chain.sump is full.
The out let hole can get plugged with sawdust. Drain sump,remove chain and bar.Wrap a clean rag around a compressed air nozzle and pump in some air,not recommended for plastic sumps.You can use a piece of wire or a small dull drill bit or a torch tip cleaner from a welding supply.
May 09, 2011 | Garden
What is recommended oil type for 4 stroke huskvarna string trimmer?
The Four stroke engine on Husqvarna products is a Honda, the sump is filled wit a sae10-40 oil.
Apr 19, 2011 | Garden
Diesel generator shuts down by itself, not out of fuel
Check fuel lines aren't air locked, diesel filter is clean and low sump oil sensor (if fitted) isn't shutting off generator.
Feb 16, 2011 | Garden
What is the gas- oil mix to use for fuel?
Check the cap on the fuel tank normally for chainsaw 40:1 or 50:1 this additional oil is the only lubricant these engines get as they are 2-stroke & do not have a sump of oil for the engine.the other oil is only to lubricate the chain & bar & uses a tacky oil . only mix small amounts of gas for use as it goes stale.
Aug 16, 2009 | Echo 30.1CC Chainsaw With a 14 In.bar and...
Garden Logo
27 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
