Question about Moen 87450SRS Varese High Arc Kitchen Faucet with Pull-Out Spout and S
Handle is lose what size allen does it take to tighten ?
3 Suggested Answers
  • 94 Answers
SOURCE: Is it an allen key to tighten the big single
no,it is a phillip's screw i do believe.pop the top cap and there it is.
Posted on Apr 25, 2010
deankjm
  • 4 Answers
SOURCE: cant find right size allen wrench to tighten handle
I have the same problem. The screw under the cap fit loosely with Alan key, either one size down is loose or one size up is too small and doesn't fit the key. I used smaller Alan key to tighten the loose and damaged the screw hole, now I have new handle but can't unscrew the stupid thing.
Posted on Dec 01, 2012
What is the wrench size i need to tighten handle bars on a jeep FT 4,0 boys bike
There are nuts or allen bolts for both the stem and the bars. They are almost certainly a metric size, but hard to say what unless one has the same bike. My guess would be a 12mm hex, plus or minus, or a 6mm allen, again plus or minus. Get a metric hex/allen set and see what fits.
Dec 30, 2016 | Jeep Cycling
What size Allen wrench tightens handle on Moen Koran faucet model87599srs
Allen wrenches are sold in sets and not expensive. Moens are not metric so any set of small SAE allen wrenches will contain the right size for your Moen.
Aug 28, 2015 | Moen Plumbing
What size allen wrench do I need to tighten a moen (annabelle) single handle kitchen faucet?
google manufacture or go topumbing supplier and they should help you
Mar 02, 2015 | Moen Plumbing
Steering too lose
From the images I have seen of the bike the loose steering could be resolved by tightening the allen screw (hex key) in the goose neck. If you were sitting on your bike and looking at the handle bars, just below where the handle bars adjust, pivot forward or back, there is an allen head bolt going down. Tightening up this bolt should tighten your steering. Some bikes have a standard bolt headed bolt to tighten the steering. Good luck!
Mar 13, 2014 | Raleigh Venture 3.0 20" Mens
Loose handle
There is a long vertical handle held to the door by two short horizontal pieces. Run your finder along the under side of the two short pieces and feel for a very small indentation under each one. Each one is a set screw with an Allen head. Insert a small Allen wrench (English not Metric -- I don't know the size, but it is probably the next to the smallest in the set) into each one and back them out (counterclockwise looking up at the screw). The big vertical handle should come off when you back the Allen screws out far enough Now look into the short pieces sticking out from the door. Inside each one is a Philips screw holding the piece to the door. Tighten those screws with a small Philips screw driver making sure that the indents on the front of pieces will align with the vertical bar when you put it back on. When the Philips screws are tight, put the vertical bar back on and tighten the Allen screws. If you have some Loc-Tite, you might use that as well.
Mar 11, 2013 | Marvel 6BAR-BD Beverage Cooler
Cant find right size allen wrench to tighten handle
It is a 1/8 inch allen wrench. Do not overtighten the bolts. You can crack the wood. Wishing you a happy baby!
Aug 14, 2012 | Moen 87845CSL Quinn Single Handle Kitchen...
I have a kitchenaid KBLS19KTSS 01 bottom freezer, and the freezer handle has come off on one side. do I need to disassemble the door to reattach it? Or, do the small screws on the bottom of the handle...
It looks like your handle is the style that slips over a screw that is threaded into the face of the door...
According to your owner's manual you most likely just tighten the small allen head screws to secure it. It lists the screw size as 3/32. You should have been left the allen head with your paperwork when you bought it.
Jun 12, 2010 | KitchenAid Refrigerators
How do you tighten a loose handle of the fridge door? Sub zero 642
I have the Sub Zero 650. I am not sure if yours iworks same but what you do is use a 3/32 Allen wrench; as you push the handle into the screw on the door so that it is flush, you insert the Allen wrench in the hole at the bottom of the short vertical connector at top and tighten; repeat for upper or lower part of handle.
Aug 15, 2009 | Sub-Zero 642
The door handle on the freezer of my GE Profile Bottom Freezer Refrigerator came off.
Hi, Please get me the model # from the label inside the refrigerator and I will look this up for you. Most handles have a set screw that tightens down.
Vic
Jul 11, 2009 | General Electric Profile PFSS2MIXSS...
Trying to raise handle bars on roadmaster xtreme hype.trying losing 2 big nuts on top section of the fork. doesn't seem to do anything. tried losing the allen type bolt at the top the fork but it only...
You loosen the nut that you see where the handlebars enter the front tube on the frame. Pull up a bit after loosening and then be sure to tighten the nut back when you get it where you want it.
Jul 05, 2009 | Schwinn Mesa Gs Mountain Bike
Moen 87450SRS Varese High Arc Kitchen Faucet with Pull-Out Spout and S Logo
95 people viewed this question
Top Moen Plumbing Experts
john h
Donni Steen
Don Numinen
Don Numinen
Are you a Moen Plumbing Expert? Answer questions, earn points and help others
