Question about LG WM3431 Front Load Washer / Dryer
Manual for WF-T7008TP - LG WM3431 Front Load Washer / Dryer
  • Ronald Bainathsah Oct 18, 2013
    this is an english user manual for automatic wasmachine-brand LG
I cannot find the online user manual for the WF-3620!
You can find easily by google it, Just type the model number of printer with user manual or user guide
you can use this key work " epson wf-3530 user's guide "
https://www.epson.com/cgi-bin/Store/support/supDetail.jsp?UseCookie=yes&oid=232591&infoType=Doc
https://files.support.epson.com/pdf/wf3520/wf3520ug.pdf
Feb 01, 2016 | Epson WorkForce WF-3620 Wireless Color...
Need a manual for Epson wf-2660 printer
https://www.manualowl.com/p/Epson/WorkForce-WF-2660/Manual/229834 go here for a complete run down and manual of your printer:)
Aug 23, 2015 | Epson Office Equipment & Supplies
Lg fuzzy logic manual wf
You can download the manual on LG's website at LG.com/ca_en/appliances
Aug 29, 2014 | Washing Machines
LG WF-T753A Top Loader washer hot water inlet valve
Just found this whilst looking for known issues with my machine as the cold water won't stop when filling.
http://safemanuals.com/user-guide-instructions-owner-manual/LG/WF-T753A-_E
Aug 25, 2008 | LG WFT1071TP Top Load Washer
Open Questions:
How to resolve "PF" power failure on an lg WM3431HW Hello, I have an LG WM3431HW which is a combo washer/dryer. It is around 4-5 years old. It was working fine, then recently after completing the washing cycle and after a few minutes after the start of the dryer cycle. The dryer cycle shuts off without error (power to unit still on). We opened up the top and cleaned out all the lint caked on within the dryer duct and made sure lint trap off drain pump in front was cleaned. We started again and received a DHE error. We confirmed the dryer element was heating up fine. We also tested continuity to through the dryer thermostats and it had continuity. Also confirmed appropriate voltage over dryer element. We then took dryer duct fan off, turned it upside down and re-connected to make sure it was turning properly. It seemed to start and stop and it was also very hot so we thought there was a problem with the fan so we replaced the fan, and to be safe, also replaced the thermostat. Once that was done, a few seconds after the unit goes into the dry cycle, the cycle stops and shows a "PF" power failure error. We checked all connections we can find but everything looks connected correctly. We eye-balled the power board to see if there was any burn spots or anything else noticeable but nothing. We also eyeballed the power filter for the same but nothing looked out of the ordinary. The heating element was hot and confirmed the dryer fan duct was revolving, albeit for a short time. It seems that there is something tested after the heating element is started and the fan revolving, that is not working and which is telling the unit to shut off or "power failure". We had also unhooked the dryer thermistor to see if anything looked unusual but looked fine and re-connected. What else can I check and what part is likely to be at fault ? Since the wash cycle runs fine, I am hoping the power board is fine. Thanks
Jul 16, 2014 | LG WM3431 Front Load Washer / Dryer
Additional details: Questions with more than 25 words are more likely to be answered well. 0 chars Your Question Preview No product selected LG WM3431 Front Load Washer / Dryer How to resolve "PF" power failure on an lg WM3431HW Hello, I have an LG WM3431HW which is a combo washer/dryer. It is around 4-5 years old. It was working fine, then recently after completing the washing cycle and after a few minutes after the start of the dryer cycle. The dryer cycle shuts off without error (power to unit still on). We opened up the top and cleaned out all the lint caked on within the dryer duct and made sure lint trap off drain pump in front was cleaned. We started again and received a DHE error. We confirmed the dryer element was heating up fine. We also tested continuity to through the dryer thermostats and it had continuity. Also confirmed appropriate voltage over dryer element. We then took dryer duct fan off, turned it upside down and re-connected to make sure it was turning properly. It seemed to start and stop and it was also very hot so we thought there was a problem with the fan so we replaced the fan, and to be safe, also replaced the thermostat. Once that was done, a few seconds after the unit goes into the dry cycle, the cycle stops and shows a "PF" power failure error. We checked all connections we can find but everything looks connected correctly. We eye-balled the power board to see if there was any burn spots or anything else noticeable but nothing. We also eyeballed the power filter for the same but nothing looked out of the ordinary. The heating element was hot and confirmed the dryer fan duct was revolving, albeit for a short time. It seems that there is something tested after the heating element is started and the fan revolving, that is not working and which is telling the unit to shut off or "power failure". We had also unhooked the dryer thermistor to see if anything looked unusual but looked fine and re-connected. What else can I check and what part is likely to be at fault ? Since the wash cycle runs fine, I am hoping the power board is fine. Thanks
See all LG WM3431 Front Load Washer / Dryer Questions
LG WM3431 Front Load Washer / Dryer Logo
300 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
