Have a satellite called Aura and also bought a remote control wich is called one for all and i cant find the code for satelitte and it works with the tv any clue ????
    Top Expert:
  • Televison & ... Master
  • 75,178 Answers
0038,0031,0037,0032 are the codes intended to work with most satellites. Check these codes. If you wish to get more details, check the sites linked here. Setup code list, and setup procedure to many popular brand remote controls are given. http://electrohelponline.blogspot.com/ http://remotesearch.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy.
Posted on Oct 16, 2013
  • 4 Answers
SOURCE: Remote Control Codes for Phillips TV using Jumbo Remote Control
TRY THESE CODES FOR PHILLIPS:
062 204 184 208 205 206 207 004 288 003 008
068 075 086 087 141 189
Posted on Jan 06, 2008
  • 8 Answers
SOURCE: Program codes for tv and satelite.
https://fjallfoss.fcc.gov/prod/oet/forms/blobs/retrieve.cgi?attachment_id=305485&native_or_pdf=pdf
The manual
Posted on May 25, 2008
  • 8 Answers
SOURCE: i need a code
Manual Code Search and Entry 1. Manually turn on the TV
2. Press and hold the TV button The illuminated ON•OFF key turns on and remains on.
3. While holding the component key down, press and hold the ON•OFF key. The illuminated ON•OFF key turns off.
4. After holding down both keys for three seconds, the illuminated ON•OFF key turns back on.
5. Release both keys. The illuminated ON•OFF key remains on. TIP: Throughout the programming of each key, be sure to keep the remote pointed at the IR sensor of the component you are currently programming the remote to control.
6. Press and release the ON•OFF key repeatedly until your component turns off. Each time you press the ON•OFF key, the illuminated ON•OFF key blinks, and the next
code in the list is sent. This process continues until all of the codes in the Code Lists have been searched. If your component turns off, you have found the correct code.
TIP: Because there are so many codes, you may have to press the ON•OFF key many times-possibly up to 200 times.
7. Once you have found the correct code, you must save the new code by pressing and releasing the STOP key. The illuminated ON•OFF key turns off. You must press the STOP key to save the code or the correct code will not be stored!
8. To confirm that the component key is programmed with the correct code for maximum functionality, test the component. Attempt to control a variety of the component's functions with the remote. If some of the features of your components do not work, try programming the remote with a different code in the list until you find the code that allows the remote to control the majority of your component's functions. Different codes can provide different levels of functionality
Posted on Jul 28, 2008
SOURCE: pro team remote control
1. Press and hold SET button and press and hold device key at the same time, when l.e.d. lights release both keys.
2. Enter the code for your device.
3. Press power on the remote
If device can be controlled then code has worked if not try another code.
4.Press any device key to quit setting procedure.
Posted on May 12, 2009
SOURCE: REMOTE CONTROL CODES FOR EMPREX TV
Emprex uses the Memorex codes. They are 1002, 1004, 1005, 1010
Posted on Feb 03, 2010
One for all remote URC7120 need a code for Aura satellite dish E13401 URC117120 R01 ... S3F80KX2W.COCB E thanks
Please try the vendors "find your code" site. If that does not help please comment for further support.
http://www.oneforall.com/en_UK/support
Oct 17, 2013 | Televison & Video
Ge universal remote 24991 v2 need code for apex dt250a or rca stb7766c
There is no setup codes for Apex or RCA STBs with this GE remote control.
Oct 11, 2012 | Apex Digital Apex Apex Remote Control Oem...
What remote controls that are compatiable to Vivitek model RP51HD41-A and what are the codes to use to the compatiable remote control?
your cable or satellite will do just fine. i have a vivitek rp51 and i was told that if i lost my remote i was SOT well i found out that the parent company of vivitek is DELTA and wouldn't you know it i programmed my direct tv remote using the brand delta wich was on the list and it worked... by the way vivitek is not on any list for remote control codes....
Sep 25, 2010 | Televison & Video
PHILLIPS REMOTE WILL NOT WORK ON OUR 53 INCH SONY NEED CODE
i bought a universal remote today for my magnavox dvd player but it wont program it and it didn't come with a dvd code list
Dec 03, 2009 | Philips Televison & Video
Cant found code for phillips universal remote need help
If setting up whith brand name codes is unsuccesfull used the manual serch:
1.Turn ON the device you would like to control.
2.Point the remote control unit at your device.Press and hold the SET key,press simultaneously the device key that you would like to control.
3.The LED of the device key will be turned ON to inform you .
4.Press the power ON/OFF key.
5.The LED keeps now flashing to confirm the manual search mode.
6.Check the functionality of the keys(NOT POWER OR PLAY KEY)
7.If the keys work press the device key TV to confirm the correct code.If the keys not work repeat the steps.
8.If the searched for device switched itself off press the device key to terminate the search run and save the code.Switsch on the searched for device again with the power key OM/OFF or pressing 1.
The device code wich has saving in your remote unit can be called up:
Press the SET key and hold down.
Now actuate number key 1 to display code.
Count how often the LEDs flashed,if doesn`t flash the digit is ZERO.
Sep 07, 2009 | Universal Remote Control Hampton Bay...
Can't program Omega URC-06 remote control
try contacting remotes.com for the original remote control
Nov 25, 2008 | Sanyo 6450160929 Remote Control
Universal remote code for Zenega receiver
Zenega DishTV STB CD-1004is SRU 5130 Philips Universal Remote.
If you have bought the above universal remote and didn't know the code for your Zenega STB, use the manufacturer code for HANDAN which is 1184
Oct 27, 2008 | GE JASRM24912 Remote Control
Cant find the codes
Magnavox dvd player need code please
Feb 26, 2008 | Zenith DBZN-311 Remote Control
Televison & Video Logo
Top Televison & Video Experts
