Question about Insignia I-LC23Q1 23 in. HD-Ready LCD Television
There are no audio outputs on my 37 lcd only four audio inputs. How do I connect my surround sound system.
    Problem Solver:
  • 17 Answers
Look for an optical or "coax" digital audio connect jack. That will transmit all surround sound channels on a single cable. That will go from your TV to your surround sound "receiver's 'digital audio in'
Also - if you are using HDMI the sounds goes over that cable along with the video.
Posted on Oct 16, 2013
How do you connect a Nakamichi surround sound system to my Phillips tv model 42PF7220A/37
I'm confused. The message header shows a problem with a Yamaha RX-V995 receiver.
As for connecting a Nakamichi (or any surround system) to a TV - the only connection would be the Monitor output (video connection) to an appropriate video input of your TV.
If it is a Nakamichi, it is a little older and probly predates the invention of HDMI cables. My guess is you will either use the S video output or Composite video output to the TV's input with similar connections.
This allows you to route whatever video sources you have connected to the Nakamichi to the TV.
May 07, 2014 | Yamaha RX-V995 Receiver
I am trying to hook up a Bose surround sound to my fusion 37 tv and cannot find the correct audio outputs
There should be a pair of audio outs marked Audio Out / Monitor Out. May be close to the digital out port.
Jan 02, 2014 | Fusion Fus37 dvd 37 LCD TV
My Insignia 37" LCD TV only has four audio input jacks. How do I connect my surround sound to my TV
Depending on how you have it set up, and what inputs you have on your TV/surround sound system, you can connect your surround sound through HDMI or optical cables. Otherwise, you can use standard composite (red, white, yellow) or component (red, green, blue).
Oct 16, 2013 | Insignia I-LC23Q1 23 in. HD-Ready LCD...
I have audio cables going from HD 61g887 jvc tv, to my phillips surround sound system under aux but it is not giving me sound?
hi
you didn't mentioned the model number of your surround sound system, for a better solution its important. any why try the following.
if you are connected the analog audio output of your tv to the system using RCA cable, then go to the setup of the surround sound system and change the input assignment setting from digital to analog.
If your connected the digital output of your tv to the digital input of your surround system using optical cable then, goto the setup of your surround system and change the input assignment to digital (optical) input.
if u need any further assistance fell free to contact through fixya
Jan 20, 2011 | JVC HD-61G787 61" Television
I have a hitachi 42ldf30ua lcd tv and when i connect the audio out to my surround system i am getting no sound the surround works if i connect directly to it but not though the tv i only have one audio...
I also can not connect my Turtle Beach x11 headphones to the Audio output on this TV - I have tried entering the code above but to no evail - sounds like there is a hidden problem here
Jan 05, 2011 | Hitachi 42PD6600 42 in. HD-Ready Plasma...
I want surround sound. How do I hook up my audio 5.1 RVC-884VBK, with my HDbox and LCD TV? It's too confusing. What hooks to what? Currently the HD box and blueray DVD is hooked straight to TV ...
Does you television have an "Optical Audio Output"? This would be the best and easiest way to get surround sound from your system. If your TV has an optical output the you can use an Optical Cable to connect the TV to the reciver. This way whatever you are watching from the TV will be in surround sound. The HDMI connection sends a surround sound signal from each device to the television. If you connect it to this output on the TV then make sure the optical output is turned on in you telivison's menu. If your TV does not have an Optical Audio Output then you will need to connect each optical output from the blu-ray and HDbox to your reciever. Your reciever will need to have two Input channels(one for each device). Then you can select that input to the device(blu-ray or HDbox) that you are using. The optical cable is the best way to go for surround sound because it is pure digital and produces the best sound. If the HDbox or Blu-Ray does not have an optical output then you will need the six rca jacks to get the surround sound. Let me know further info on what you have so I can assist you more.
Jun 26, 2010 | JVC RX-884V Receiver
Where is the output to return to my vcr
the order i normally use for the sound system (if thats what your asking) is run everything including the vcr to the tv then on the back there should be a red plug and a white plug labeled audio out then run that to the sound system any input on the sound system will work long as the colors match and its labeled input...hope this helps!.
Aug 24, 2009 | Vizio VW37L 37 in. LCD HDTV
How do i get my ps3 to run through my lg surround sound
Connect your yellow and red lead from the PS3 to the surround system, connect them to aux input. (the white lead is not needed). Then in the sound settings on the PS3, go to audio multi-output and change it to on. On your remote for the sound system press the input button until aux appears on the front of your LG HT303SU, and thats it, happy gaming.
May 18, 2009 | LG Televison & Video
Faint sound when watching TV with Bose GSX 321 System
I connected my surround sound to the audio output on my samsung tv and it works fine. Of course I don't have an hdmi input on my surround sound system because its an older model, but it works great. Just got to put the surround sound to audio instead of dvd or tuner setting
May 07, 2009 | Bose 3 2 1 GSX System
I have an LG LCD TV (LG 37LG5000 37IN). I also have an older DVD Home Theatre System (SONY DAV-DZ100). It seems that the surround system works well with DVDs but I cannot get the sound to work with DIGITAL...
It works fine if you plug the surround system SCART lead into the AV2 input. I believe this is a 'smart' scart plug (same as SONY but it is not mentioned as in the literature). The AV1 is only good for inputs NOT outputs as well.
Oct 04, 2008 | Televison & Video
Insignia I-LC23Q1 23 in. HD-Ready LCD Television Logo
91 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
