Question about Boating
I have a marine westernbeke 8k btda it runs perfectly but it does not generates Any electricity to The boat! Where should i start troubleshooting???
Check to see if the main breaker on the unit is working.
You can download the technical manual online, it has trouble shooting tips.
Posted on Oct 24, 2013
Where can I get an owners manual ?
PDF]10000W Generator
scene7.samsclub.com/is/content/.../GG10020-Eng%20manual-cpdf
Gentron/UPC will repair or replace, at Gentron/UPC's sole option, products or components ... Expendable parts or accessories supplied with the product which are..... FILLED WITH OIL OF A HIGH QUALITY SAE 10W-30 GRADE ENGINE OIL.
Gentron - 10000 Watt Gas Generator with Electric Start
www.samsclub.com > Sam's Club > Emergency Supplies
Sam's Club
Rating: 4.4 - ‎330 reviews
Gentron 8,000W / 10,000W Portable Gas Powered Generator with Electric Start ...... 1 year parts and labor limited manufacturer's warranty; For issues not ...
Gentron Pro2 10000w Gas Generator (GG10020)
https://generatornow.com/gentron-gg10020-pro2-10000w-gas-powered-...
Gentron GG10020 Pro2 10000w Gas Powered Portable Generator with Electric ... It's a one year/1000 hr parts and labor warranty for our residential customers.
Jan 21, 2016 | Electrical Supplies
Mercury boat motor troubleshooting
Could be a fuel issue. You don't say how old your motor is, but if it is 10 yrs or older, there is a good chance it does not process regular highway fuel very well. Too much ethanol. Makes the fuel separate after warming up. Your engine will normally start fine, but after getting warm, will either stall out at low speeds, or won't start after shutting down. Try a good additive to reduce the ethanol effect. Most boat docks with fuel pumps also sell the needed blend of gas for marine engines. Thus, a few more cents per gallon, but less problem for you. I mixed a good additive to my 20 yr old Johnson 115, and it runs like a new one! Hope this helps. Good luck !
Skip
Aug 13, 2014 | Boating
Why is it hard to start my Mercruiser 7.4L MPI after a hot run?
Electric choke? Try retrofitting a manual choke. I think the electric choke is closing over a hot engine, thinking that the engine's cooler than it really is. A manual choke will allow you to start it with no choke at all when you know the motor's already warmed up.
Jul 25, 2014 | Mercury Marine Mercruiser 350 - 454 - 5.7...
50 hp mercury outboard pull start diagram
http://forums.iboats.com/mercury-mariner-outboards/wiring-diagram-pull-electric-start-mariner-20hp-1985-a-468275.html
Feb 24, 2013 | Boating
Kohler marine generator troubleshooting
I have a kohler marine generator that shuts down when it reaches operating temp of 200/210 degrees. It runs for about 5 minutes. Already replaced impella and have sea water pumping through, coolant level is good. Any suggestions? Thanks
May 02, 2012 | Electrical Supplies
Where can I find a wiring diagram to install a generator into a boat? I know how to wite the 110 volt side but where do I connect the 12 volt power from the generator into the 12 volt distribution panel?
Installing a generator into a boat is critical to be done correctly. You need to contact the manufacturer of your generator for approval, and wiring diagrams. If done incorrectly (which if you are connecting 12v from gen), you may create eddy fields that can cause galvanic corrosion, not to mention electrical shock hazards.
If your generator isn't marine rated, then don't install it into a boat.
Portable generators can be used, but don't hardwire those into a boat. Just use extension cords to the appliances you want to power.
Nov 22, 2009 | Northern Tool Electrical Supplies
Boating Logo
54 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Boating Expert? Answer questions, earn points and help others
