Question about Compaq Computers & Internet
Cannot install xp on my compaq presario cq40-133tu blue screen error may be of sata raid driver
  • 56 Answers
It is not possilble. Try with other XP CD. It will definitely get installed on your PC.
WINDOWS XP REQUIRES MINIMUM OF 128MB OF RAM.
Please do so, your problem will get solved.
Posted on Apr 24, 2009
  • hendra Apr 05, 2012
    you need win xp with service pack 3. or, if you don' t have it you can turn off sata feature at bios
I also have the same problem. I am not able to install XP on my compaq CQ40-133TU. But could install Vista. But I want to install XP which is much faster with this level of hardware configuration
Posted on Aug 23, 2009
I want to install xp2 in compaq presario cq40, but a blue screen is show
Hello Download the SATA driver for your particular chipset. Then download nlite (just google it). Install it and follow the directions to slipstream the driver into your installation disc. You can also add SP3 and all the drivers you need to it.
or go to bios and restore it to default setting if you have a sata hard disk then disable it in bios setting or RAID Auto/Ahci to RAID Auto/ATA then reboot from installation disk or You can get help from this site http://www.laptops-drivers.com/compaq/how-to-install-windows-xp-on-hp-compaq-cq40-115au.html
hope this helps
Jan 28, 2011 | Compaq Presario Notebook
How can i install windows xp when screen showing blue screen
Check whether you have installed the SATA Hard Drive driver using a Floppy disk. Some Computers needs SATA Hard Drive Driver before installing the Windows XP. Try using Windows XP SP2 disk.
Jul 01, 2010 | Compaq Presario 700 470024-192 Notebook
Installation Of Xp Give Blue Screen Error.How Can I Install Xp On My Notebook(CQ60-104tu
Did u format Windows installation drive...
If not then try running fixmbr command....
OR...else
Format entire harddrive and delete all partitions...
Then try to run XP installation by Boot From CD option and this shud work for you.....
If not then give detailed info on the error messages shown to u
->also check data cables inserted properly or not,
-> ensure that hard disk is primary and rest devices is secondary
Sep 03, 2009 | Compaq Presario Notebook
Compaq CQ40-108TU unable to install XP OS
Prepare a Bootable XP Disc installer.
At first go to BIOS Setup to Boot First Priority the CD/DVD Rom Drive.
After that disabled SATA or RAID Configuration. The Bootable XP Disc Installer could not go on when you don't disable the SATA or RAID Connection.
Don't worry that you are thinking it would not detected the SATA HDD by Bootable Disc but it is. Then follow the instruction.
If i am helpful to you please rate me.
Thank you.
Yboyandrei
Aug 24, 2009 | Compaq Presario Notebook
Intalling window xp over vista
XP does not include SATA drivers in the distribution. You need to get the SATA drivers for your particular model from HP's website and watch for the prompt to hit F6 when prompted to install SATA or RAID drivers.
The trick is that the mechanism to add these drivers at this point assumes that you have a floppy drive which is rare these days. There are a number of work-arounds for this, here is one:
http://news.softpedia.com/news/Install-Windows-XP-On-SATA-Without-a-Floppy-F6-47807.shtml
Aug 18, 2009 | Compaq Presario Notebook
How to install windows xp sp2 on compaq v3239tu
That happens because the BIOS uses a SATA controller that is not included in Windows XP install disk.
Usually you can solve the problem going to BIOS settings and changing SATA/RAID settings.Check your BIOS settings, and disable SATA RAID mode.This is done in different ways depending on the BIOS.
On HP/Compaq computers for example you press F2 on startup to enter BIOS, then disable SATA mode on bios settings.
On other makes the procedure can be slightly different.
Another way to fix the problem, is by creating your own XP setup disk with SATA drivers included, see:
Resolving "Setup did not find any hard disk drives" during Windows .
Mar 14, 2009 | HP 417068-001 Compaq Presario V3000...
Xp drivers for compaq-presario-cq60-104tu-laptop
i have compaq presario cq60 104tu laptop and no driver for xp
Jan 10, 2009 | Computers & Internet
Problem in XP installation in the HP presario Note book
Sata hard disk does not require driver, however the sata controller which belong to any manufacturer may require. You have to go to driver cdrom, browse for IDE OR SATA if you cannot find it the clue is "RAID" find the RAID driver, you will also find the sata controller driver
example only: si3112.cat, si3112.inf, siblabla.bla....
copy all the files in folder (do not copy folder!! only files). Then put floppy disk in drive, make sure you boot from cd-rom.
Start XP installation then follow:
Press F6 for third party SCSI or driver installation at the beginning of text mode installation. Press 's' when setup asks if you want to specify an additional device, and insert the diskette then press 'Enter'. From the menu presented next, select the controller installation process that corresponds to the version of Windows being installed and press 'Enter'.
4. Press 'Enter' again when prompted to continue on with text mode setup.
5. Follow the setup instructions to select your choice for partition and file system.
6. After setup examines your disks, it will copy files from the CD to the hard drive selected above and restart the system. After restart the setup process will resume to finish the installation.
Good Luck
Damak
Jan 07, 2009 | HP Pavilion dv6000z Notebook
Computers & Internet Logo
1,029 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
