Question about HP Photosmart 8250 InkJet Printer
Paperjam - HP Photosmart 8250 InkJet Printer
    Sergeant:
  • 329 Answers
If no paper and check for small piece any where, remove power and usb cord and re insert cords and turn on to see if it will reset....
Posted on Oct 16, 2013
Paper jam printer
kindly check it what shows in the display:
"paperjam 0" , its related to pick up roller related problem.
"paperjam 1", its related to cartridge unit, kindly re inserted the cartridge.
"paperjam 2", its related fuser unit, kindly open the rear cover of printer, ther you can see the fuser unit. check the one liver from fuser unit to HVPS .
kindly check all these things and contact
Jan 29, 2014 | Samsung SCX 4521F All-In-One Laser Printer
Always paperjam, the printer takes the paper 10cm then warns about paperjam ?
you should clean the roller of the printer with wet cloth, els consult with a qualified technician for technically handle.
good luck
Nov 27, 2010 | Samsung CLP-300N Laser Printer
My canon mp190 gives E3 paperjam error but there is no paperjam how do i fix it?
I have solved this problem with read post at http://slayo.com/how-to-fix-error-e3-canon-mp198-printer.html thanks to slayo.com "Canon MP198 Printer Error E3 is becaused something inside of the printer that makes paper sensor not function properly. To fix this error E3 you must open inside of the printer to remove the things." you must open your printer to remove the things, maybe waste letter or other small part things. Read the post for complete it.
May 18, 2010 | Office Equipment & Supplies
310, 311 318 paperjam can not find it
is the paper in the fuser, try turning the fuser, sometime there are some small pieces of paper stuck in between the fuser and pressure roller
Feb 18, 2010 | OKI C3200n Led Printer
Says paper jam but NO paper is in the machine
One problem i found with those printers is that over time the casting around the paper tray is wearing off and printers starts to show paperjams when there is no paperjam.
One way to fix is try and positions the paper tray better or perhaps raising it a bit with piece of wood or paper.
Cast unfortenately is too expensive to replace so if this doesnt work and you are sure there is no paperjam and nothing obstructing the sensor then replace the printer.
Nov 02, 2009 | HP LaserJet 2200D Printer
My printer says there is a paperjam but I don't see a paperjam.
its a mechanical problem ...
check the rollers of the printer ..and the paper pick mechanism ..maybe it can't caught the paper in the tray that why it display an error of jammed..
May 24, 2009 | HP DeskJet 3653 InkJet Printer
Kyocera paperjam
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 02, 2009 | Office Equipment & Supplies
PaperJam
I found that the little plastic hinge guide that supports/aligns the scanning area with the printer (stage 4 on the internal paper jam problem) was misaligned. I just removed it and the printer now works OK
Aug 28, 2008 | Samsung CLX-2160N All-In-One Printer
Paperjams
Sounds like the pick up rollers are worn or dirty.
You can try to clean them with alcohol.
When you pull the tray out the rollers
should be towards the front of the printer.
Nov 21, 2007 | HP Color Laserjet 3550 Printer
Flashes paperjame sign but there is no paper jame!
the problem is same sensor no work in the good way or ther is problem in the fusing unit or ther is problem in the feed unit
Jul 24, 2006 | Toshiba 1370 Black and White Copier
HP Photosmart 8250 InkJet Printer Logo
15 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
