Question about RCA 20F512T 20" TV
No standby light has a ticking sound - RCA 20F512T 20" TV
    Top Expert:
  • RCA Master
  • 75,157 Answers
Check and replace damaged component/s at its main power supply regulator board and horizontal scan output section circuit. If you wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window
Posted on Oct 16, 2013
Top gas cooking range continues to make the ticking sound ( tick-tick-tick) even when all burners are off. There is sparking at all the burners too with the sound, I have removed the electrical plug f
This seems like the burner control valves are not functioning properly. The rear is still working properly so without knowing brand I would say the control valves are defective.
Apr 19, 2017 | Kitchen Ranges
Singer TV Model 20LNC
while it goes off does it make a ticking sound?
Jun 29, 2008 | Pioneer SD-P50A5-K 50" Rear Projection...
Hi, I have Sony Bravia KLV-32S400A Couple of months ago suddenly get switch off after I switch on standby light(Red) gets blink. I unplug the power code and switch on the LCD after 3 hours it works fine. I...
Dear User,
in your case there is a supply fault..capacitor of power board is weak .kindly change the capacitor ..the sign of capacitor faulty is that capacitor is blow up like oil is coming out form upper side..kindly do the need ful.dnt use the lcd until the problem fixed.
Feb 04, 2011 | Sony Televison & Video
Clicking noise from sub when in standby mode
Disconnect the input. Does it stop? If yes...
It sounds like it's sensing a signal at its turn-on threshold. Figure out why there's signal present when it shouldn't be there.
Exactly how is it connected to the source? LFE-only or full-range signal?
May 24, 2010 | Velodyne CHT-10 Subwoofer
When I turn on my TV (KF50WE610), it makes ticking
Hi,it sounds like a problem with your ballast.The ballast is the board that powers the lamp .When it starting to fail it will make clicking sounds.The part is around $40-$60 depending where you look for it.I believe there's instructions on youtube.Have a bless one!
Feb 09, 2010 | Sony Grand WEGA KF50WE610 50" Rear...
Tv ticks like a clock,no standby light, no picture
Hi
tick sounds is the relay, the relay is trying to oscillate the power, but its failed because of shorted regulator or any parts are shorted this is what happen cant start normally..
Thanks!
Apr 25, 2009 | Samsung Televison & Video
MY telly wont
Hello Haplorhine:
It sounds like there is a problem with you power supply or the small signal board, it should be taken to a repair center.
Aug 19, 2008 | Televison & Video
No power even standby LED..
This is like a car running without a driver,the horizonatl output transistor has the voltage it needs but it does not have horizontal drive signal applied to the base of the horizonatl driver transistor,the driver transistor should have a signal coming from the signal processor where the signal is generated just to get give it to the driver this driver then it gives it to the output to energize the flyback and light up the picture tube and generate a few other supplies,158 volts are there because the output is not turn on,try measuring voltage somewere else in the set and not at the collector of the output,there is a b+supply that goes to the signal processor(8 to 12 volts),check to see if you have this voltage,I couldn't tell you the pins in the siganl processor IC without squematic,It seems you know your way around tv service but be careful when checking voltages.Let Us know if you need more information.
Oct 10, 2006 | Samsung TXJ2067 20" TV
RCA 20F512T 20" TV Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
