Question about Toro PARTS CATALOG, GM 4700-D Part 3327-354"
I have a Toro 4700 D with about 5200 hours. I will be changing my 5th coupling spring, part number 92-1753. The last repair was made only 200 hours ago. Has anyone else experienced problems with this? The part runs about $400 and takes a good 8 hours to repair. In speaking to Toro, they suggested that the motor mounts be changed? Their belief is that maybe an increase in vibration is contributing to the problem.
wadembly
  • 462 Answers
SOURCE: Mower won't keep running after 10-15 seconds.
check the air filter & also spray some carb.clean in the carb see if that helps
Posted on Jun 06, 2009
harlan301
  • 205 Answers
SOURCE: Toro Proline 400 blades fall out of engage
if your unit desengages have the clutch gap checked. also you should check for shorts in your safty wiring. the other would be a bad switch. finely your under warranty this my be warranted.take it to a toro dealer or call one to make sure
Posted on Oct 13, 2009
SOURCE: I have a toro snowblower that quit running last
Hi
I have seen them go through the engine into the muffler. Did you check the valves if it damaged them. I would check for spark first if that is good put a tea spoon full of gas in the spark plug hole and try to start. If it fires you need to clean the carb. If not i would do a compression test that will tell you if the screw damaged anything.
Sam
Posted on Jan 08, 2010
2strokeJim
  • 577 Answers
SOURCE: Toro GTS 20332 (bought it 12 months ago) won't run
I believe that Toro Guarantees to start 1 Pull, was gas left in it all winter?, If so this is'nt covered under warranty, cause gas is to be ran out or dumped out at end of season this will prevent any gumming up of carb . did you completely disassemble carb? does it have a primer on it, those gskts need replacing, clean out the jet in bottum of float bowl,small holes,sometimes missed and remove and check your needle/seat to make sure that when float drops gas runs out then lift float up and gas should stop. hope this helped you,another thing spray carb cleaner in carb and pull over and see if it will start that way enough to keep running with choke to see if it will **** gas into it
Posted on May 16, 2011
BAMOUT
  • 2478 Answers
SOURCE: toro personal pace lawnmower recoil spring broke
Go to www.youtube.com and type in fix starter spring lawnmower in Goggle.
Posted on Mar 01, 2012
Does the hour meter in a toro tractor lx 420 show Tenths?
Best way to check that out is to run it for six or seven minutes and see it the number changes by .1 and if it takes an hour of running to move the nkmber you will know that it reads hours nit tenths.
Sep 21, 2014 | Garden
How do I replace the torsion spring in the handle of a Toro Personal Pace lawnmower?
Thanks so much Jamie. I had the top of the handle off but couldn't get any
further. I had to use a screwdriver on one side to get the brass bar out of the
plastic channel (I was afraid I would crack the plastic but didn't). I was able to remove the bar from the handle by myself with lots of effort ( BTW in your
solution did you mean your son pulled vertically up on the handle while you pushed vertically down on the bar?). I had one foot on one side of the handle and pulled up on the other side while pushing down on the bar. Isn't the web and Google amazing. The Toro sight didn't have a service manual. So I just typed "How to replace the torsion spring on a toro lawnmower" in Google an the question came up. I think Toro has a design issue with an overstress point on the spring. That part is on back order at the factory.
I did it.
May 01, 2012 | Toro Personal Pace CARB Walk Power Mower
Toro personal pace lawnmower recoil spring broke
Feb 28, 2012 | Toro Power Lawn Mower
I have 20 year old Toro s-200 snowblower. I ran it dry last spring before storing it for the summer. Pulled it out recently and it won't run. It will turn over and run for about 5 seconds...it seems to...
When you start it keep pushing the primer too keep it running for as long as you can.this usally helps when they have been sitting without gas in them.if that don,t work take the carb off and clean it out.
Dec 03, 2010 | Garden
I BOUGHT A BRAND NEW TORO LAWNMOWER, MODDEL 20330,
don't waste time looking for the primer bulb. probably wont work anyway if its over 6 months old and repairs probably wont do any good either. bad design for a primer system.
Apr 08, 2010 | Toro Lawn Mower With Toro Power Tools
After a couple of hours of use last week, the motor started slowing down. Turned it off and it would not restart. tried again after an hour and it started but sounded really rough. stopped it and took it...
sounds like the motor is worn out. Toro does not sell the motor separate. It is considered a throw away unit.
You will have to purchase a new one.
Sorry.
Good Day.
Nov 05, 2009 | Toro Electric Ultra Blower/Vac 12 Amp
How to change the pull string on a toro 22 inch recycler
To take the housing off, you may need to remove the carb choke houseing "becasue of a hard to reach bolt. A small oil filler tube screw and then a couple screws on the top. I dont know if you broke the rope or of the assemble inside is broke, but they make a kit for new springs and wings that is fairly simple to replace if thats the latter of the two.
I would discourage the average handy person from undoing the screw on the plastic reel inside under the cover and pulling up, as it is the metal band that creates the recoil tension and those are challenging still 15 years later. ;)
Aug 09, 2009 | Toro Lawn Mower With Toro Power Tools
Toro powerlite snowblower sputters out after 10-15 minutes
I would change the spark plug and be sure to gap it as per your owner's manual. I would also clean or change the air filter. I would also use only high test gas and the oil recommended by the manufacturer. good luck.
Jan 14, 2009 | Mowtownusa Snow Thrower Starter Switch for...
Self propell just went out on my toro, how do I change the spring?
Can you please help, I am trying to put the belt on my toro and found that one of the bolt has broke off trying to fix it before husband gets home.ha I love all your help. Top on my list......
Oct 20, 2008 | Toro Lawn Mower With Toro Power Tools
Toro PARTS CATALOG, GM 4700-D Part 3327-354" Logo
73 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
Mike Squire
Roland W VanLue
Roland W VanLue
Are you a Toro Garden Expert? Answer questions, earn points and help others
