Question about Magic Chef Mcd1811st 1.8 Cubic-ft, 1,100-watt Stainless Microwave
Magic Chef Microwave has stopped working. None of the buttons work. It's showing random numbers when you plug it in. I tried a different outlet and it gave me different numbers.
    Scholar:
  • 178 Answers
Try unplugging it for 24 hours. Plug it back in and see if this helped. If it's still the same, it needs a new control PCB (printed circuit board).
Posted on Oct 28, 2013
SOURCE: Magic Chef mco153ubf
I had the same problem. My Magic Chef, MCO153UBF Microwave had similar problems. The Magnatron, Cooling fan, Turn table and under hood lights were not working at all after hearing a pop sound under the control panel. Thought it was the fuse but the fuse was fine after testing and replacing. I checked the circuit breaker wired to my house and saw it had a break to my kitchen outlets so i flipped the switch to get back the kitchen outlets. Then I checked the microwaves Control Panel ( Printed Circuit Board) underneath and saw to traces were burnt. I soldered the two trace lines and the fixed the problem.
Posted on Feb 17, 2008
dmftrucker
  • 1922 Answers
SOURCE: Microwave won't Work
sounds like a fuse for starters, remove outer cover there will be a white cartridge appx 1"longX1/8"dia this is a ceramic fuse avail at most hardware stores in 15 or 20 amp configurations, if this blows again after repl suspect a faulty H.V. Diode/H.V. Capacitor, or the magnetron tube unless while inside unit you see something obviously wrong 2 fuses are under $5.00
Posted on Sep 27, 2009
Testimonial: "Thanks for the help! I'll try it and let you know."
localwonder
  • 6784 Answers
SOURCE: I have a Magic Chef microwave model mco153sf. The
HI. This is , indeed, an issue within the touch pad circuitry. it is damage, and will require replacement. I have located a replacement touch pad. Use the link below to access the touch pad. You can order the pad on-line, by clicking the link below.
CLICK HERE
Posted on Dec 23, 2009
  • 8404 Answers
SOURCE: no heat on magic chef microwave
Check the door safety interlock switches.
Posted on Dec 29, 2009
SOURCE: magic chef over-the-range microwave shut off
I have a Magic Chef Microwave Model MC0153UB that is shutting itself off while cooking. I noticed before this, the light under the microwave blew during a storm. Do you have any suggestions?
Posted on Jul 22, 2010
Where can i find the fuse in this magic chef microwave. I was cooking rice and power just stopped. Not the outlet.
I've used several microwave ovens and NONE of them had a serviceable fuse but maybe this video might help you
https://www.youtube.com/watch?v=IN0BqiVX5ds
Apart of this fact, honestly I don't know have any mocrowave elctronics knowledge to hepl you diagnosing the failure.
If your oven stopped working and you don't have electronic knolwedge to repair it, bad new is that you should take it to a reapair service.
In any case, you may read about issue on line, open thhese links:
Microwave Not Working
How to Fix Microwave Oven Simple Fuse Replacement
My microwave stopped working What should do ACP
GE Profile Microwave JE1390 stopped working
Sep 07, 2015 | Magic Chef Microwave Ovens
No power ,wont turn on
if it happened when you opened/closed the door, check your door switches. if you search for that problem here, youll find a useful video showing you how to do that. if it just kinda happened randomly, (actually you need to check this either way), try the fuse. you'll need tamper proof torx bits and a ratchet. take off the casing and you'll see the ceramic fuse right behind where the power cord goes into the microwave. use an ohlms meter to check it. if the numbers on the meter change, the fuse is good. if they stay at 1, its bad.
Apr 07, 2014 | Magic Chef MCD1311ST Microwave Oven
Magic chef microwave buttons will not work but microwave is on
its a connection problem probally from a bump while driving the camper - you can dismantle the microwave yourself from the back and reconnect the jared wiring, or just replace it with an industrial one that can handle the camper abuse.
Jan 04, 2014 | Magic Chef MCD990R Microwave Oven
Magic chef mco160s microwave control panel not working
That would be a defective membrane keypad.
If it's still available, and you or someone you know might want to replace it, here's a handy guide with pictures showing you what's typically involved.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag in or on the microwave here.
Jan 08, 2013 | Microwave Ovens
SERIAL # 20101639 RELEASED 2002 THIS MAGIC CHEF IS USED IN AN RV FUSE BLEW RESET MAIN FUSE MICROWAVE DID NOT COME ON PULLED OUT CHECKED POWER OUTLET AND POWER IS WORKING TO OUTLET CHECKED ON ANOTHER...
most microwaves do have a fuse to protect the power supply .outer cabinet has to be removed and then you will be able to see it . look where the power cord comes into cabinet
Dec 01, 2017 | Magic Chef MCM660A Microwave Oven
Ours magic chef 900W MCD990ARB completely stopped. We have it in our camper and everything on that end is fine. Checked the micro in a different outlet, still no go. Any suggestions?
Well if you are lucky it is an internal fuse. Open it up and look somewhere near where the cord comes into the unit. If it is not the fuse then I suggest you replace the whole thing.
I recently was attempting to repair one. The part cost $93, a new microwave costs that or less.
May 11, 2010 | Magic Chef MCD990W Microwave Oven
Buttons don't work
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes.
Otherwise, you may have a failed membrane keypad.
If you still need help, please post a new help request to FixYa and include your brand name and full model number.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
May 04, 2010 | Magic Chef Microwave Ovens
No power to microwave all ready checked fuse box and ok , changed microwave fuse ,and still no power and solutions it a whirlpool
the circuitry has probably gone bad, try plugging it into a different electrical outlet, but if that doesnt work, its probably dead. and it will be cheaper for you to replace than have serviced, unless its still under a warranty
Jan 15, 2010 | Magic Chef MCD1311ST Microwave Oven
Microwave magic chef
It sounds like a microwave circuit problem, and it's very likely a bad rectifier or capacitor. It might be the magnetron.
I would stop using the unit and get it repaired before a more expensive component is damaged.
Jan 28, 2009 | Magic Chef CMV1100 Microwave Oven
Magic Chef Mcd1811st 1.8 Cubic-ft, 1,100-watt Stainless Microwave Logo
146 people viewed this question
Top Magic Chef Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a Magic Chef Microwave Oven Expert? Answer questions, earn points and help others
