Question about Royal Sovereign ARP-9411 11K BTU Portable Air Conditioner
Air conditioner e3 error
E3 error on display screen
Compressor not running
id try a new capacitor (cheapest solution) , but sounds to me that your compressor is done for. id bet the evap coil is quite dirty , this is a usuall cause
Jul 21, 2015 | Haier ESA412K 12,000 BTU Energy Star...
My Haier HPY08XCM 8,000 BTU Portable Air wont cool. How do I troubleshoot?
  1. HAIER HPY08XCM 8000BTU Portable Air Conditioner 2015
    ? 1:59
    www.youtube.com/watch?v=kx1_1q4ByC8
    Apr 19, 2015 - Uploaded by Denada Pinoy
    In this video I review the HAIER HPY08XCM 8000BTU Portable Air Conditioner 2015. ... No comments to display ... CommercialCool 12,000 BTU Portable Air Conditioner with Timer with Dan Hughes - Duration: 9:24. by QVC ...
Jul 21, 2015 | Haier HPY08XCM 8,000 BTU Portable Air...
Why does my brand new wall AC unit turn on but the fan does not work?
Good Afternoon Michael,
I see that you are having trouble with your Frigidaire air conditioner, model# FRA14EHT2, and the fan not turning on, even though the compressor turns on. Being that this is an air conditioning, I suggest either calling your local authorized technician or possibly the manufacturer. One of which will be able to assist and direct you in the right direction of having your air conditioner working. Hope this is helpful.
-Best Regards-
WP
May 09, 2014 | Frigidaire FRA14EHT2 14,000 BTU...
The e3 is displayed and beeps ran only a month or two
The E3 Code, indicates that the air intake filter needs to be removed and cleaned. Be sure the unit is OFF and unplugged before removing the filter. Filter cleaning should be performed at least once every two weeks, as part of Routine Maintenance.
Hope this helped you.
Jun 07, 2011 | DeLonghi DE400 Dehumidifier
Our delonghi de400p dehumidifier shows an E3 error message. Customer Service says its a sensor but can't tell us what sensor. Any help would be appreciated.
I have a 40 pint and a 50 pint that are very similar. The 40 pint has the e3 error. Experimenting with the 50 pint, I found if I disconnected a particular sensor I got the e3 error. That sensor is a little can with two black wires (smaller than a AAA battery but shaped like that). It is attached to the cooling coils so must be a temperature sensor. This is not the little circuit board sensor mounted in the middle of the radiator in a plastic box/clip thing.
I am now about to see that part to see if I can replace it.
Jul 09, 2010 | DeLonghi DE400 Dehumidifier
Error Code E-3
i don't know if this will help i have a delonghi portable ac and the e3 means not enough voltage to run properly. but it was doing the same thing as yours. i plugged it in where i knew there was good enough voltage and it works fine now
May 26, 2009 | DeLonghi DE500 Dehumidifier
Error code E3 on delonghi dehumidifier DH400P
Be Safe or don't do it....
On the side with the lint screen, remove the five screws holding the top panel in place. The sensor that needs to be checked in mounted on the radiator fins. Remove the sensor and 4 pin connector. With a pin, remove the loose fitting housing the "sensor"...a circuit board that "shorts" with condensation...check corrosion and look for component damage on the oft chance the circuit board was damaged by some inappropriate poking or mechanical failure. Reassemble and replace sensor...
For a short life span...or out of warranty and only at your risk (IF have significant other or kids or pets or human DNA... don't do this...) .. guide wire through screen notch and attach to outer screen. Build fortress around exposed sensor and talk to insurance agent for a special rider...seriously be careful.
Did you? Clean screen and GENTLY clean fins of lint, etc....(vacuum's brush head should do the trick...)
Taking all appropriate safety precautions.
Here's the 100,000 (yen) tip....with humidifier unplugged, hold down the power button (green button in lower center) and plug in the appliance.
Watch the LCD screen as it conducts a self test...and wha...lah!.
Should have a working humidifier!
(your welcome).
no really..."de nada". :"don't touch your moustache" "Doye toche moche"(?), "prego".
Apr 10, 2009 | DeLonghi DH40P Dehumidifier
DeLonghi dehummidifer de500p when i first plug it in comes on
DE500P does not run and shows error code E3. What part do I need to replace and where can I get it?
Mar 24, 2009 | DeLonghi DE500P Dehumidifier
E3 error
I got mine fixed tonight! It was not that easy but can be done.
After my last post, I called the customer service of DeLonghi. The agent can only refer me to the authorized repair shops but she does not know what “E3” meant. There is no shop in NJ where I live, and the closest one is in CT! One of the two shops there knows right away the E3 is the fault of a condenser sensor. He mailed me the part ($25) and I took the covers off (be very careful to record where the screws are from ---- they are not all the same size/shape, and also there are two small tabs on the top holding two cover pieces together, so don’t force it to open or you will break it). There is only one part looks like the same as the replacement part I newly obtained and it has a metal clip attached on the copper coils. Carefully replace the sensor on the coil as you find previously and plug the other end to the control board. It sounds lengthy but once you open the cover it will all become clear to you. Be patient and this can be done. Very glad to see/hear it is working now again!
p.s., the store first mailed me the wrong part (on the plug-in end it has two ridges rather than one) so I have to call them again to explain and they mailed me a different one with a single ridge. Apparently there are two types (old and new model) for this model.
Apr 26, 2008 | DeLonghi DE500 Dehumidifier
E3 is flashing on display panel
Calling two service centers, they both indicated that the main circuit board needed replacing. This would need shipping the unit!!, part and then labor. I figured over $120 - not reasonable. I then took the unit apart and followed the wires from the compressor to the back of the unit. This is where the moisture sensor was located - upper left. You'll see this when you take the filter off. Anyway, I cleaned the face of this part with a old toothbrush, used some compressed air to remove any dust. I then followed the wires with the black sleeve that went to what I think is a temperature sensor - also on the left. The wires go to a sensor that is pushed into a copper tube that is part of the cooling tubing. Gently pull this out, wipe it down and re-install. I then plugged the unit in, set the humidity level and it now works. I just put the unit back together and the compressor is turning on and collecting moisture! I will run it a few days and keep checking on it to make sure it doesn't go into the 'E3' Mode. By the way, the repair shops I called really didn't have a clue what the E3 code was. Dennis
Jun 15, 2006 | DeLonghi DDE40E Dehumidifier
Royal Sovereign ARP-9411 11K BTU Portable Air Conditioner Logo
24 people viewed this question
Top Royal Sovereign Dehumidifiers Experts
Bill Long
Gil Shultz
Michael Youngman
Michael Youngman
Are you a Royal Sovereign Dehumidifier Expert? Answer questions, earn points and help others
