Question about Canon PIXMA MP160 All-In-One InkJet Printer
Where are the absorber pads - Canon PIXMA MP160 All-In-One InkJet Printer
    Scholar:
  • 100 Answers
I have never heard of replacing ink absorber pad? My printed has stopped because it says the absorber pad is almost full. Where can I buy, how do I fix
When you select clean print head the ink that is pushed through it is collected by an absorbent pad directly under the print head This pad can be removed, washed with water and reinstalled after it dries.
Nov 02, 2014 | Brother MFC-J4710dw All-in-One Wireless...
Canon IP90 ink pad is full
This may clear the ink absorber problem. There is ink absorbers located at both ends of the printer where the ink head move.
To dry the ink absorber, power up the printer and open the cover so the ink cartridges and print head will move to the middle of the printer.
Then take several sheets of absorbent tissue, fold it into a pad and place it inside the printer over the ink absorber on the far left hand side of the printer to soak up the excess ink. You may need to change the absorbent tissue a few times. Then repeat the same procedure on the right hand ink absorber.
Close the lid and the printer should now function normally.
Feb 11, 2013 | Canon PIXMA iP90 Mobile Printer
Ink absorber full on a canon mp190
my canon Mp 190 ink absorber all most full. How to do?
May 09, 2011 | Canon PIXMA MP190 All-In-One InkJet...
How can I change the foam pad that absorbes ink? What part is that called?
Hello
Its better to just remove them clean them up and replace it in the printer, because usually some printers require a reset code to re-set the waste ink counter. If the counter is not re-set there will come a time when then printer will refuse to print.
Here is how to clean your waste ink absorber;
Open the printer and locate the waste ink absorber near the ink cartridge.
Remove the absorber pad and hold it in cold water while squeezing the ink out. It would be wise to wear gloves while doing this, because the ink in the pad will leave stains.
Use paper towels to dry the waste ink absorber pad. Let it dry completely before installing it back in the printer.
Reinstall the ink pad into the printer and run a test page to make sure it works.
Apr 20, 2011 | Epson Stylus Photo R300 InkJet Printer
Canon MP160 Printer "Ink Absorber is Full"
There are two ways to fix this:
First Solution - Clean the Absorber pads
The absorber pads is filled with waste ink. Access the printer to get these two absorber pads and clean it with soap and running water. After cleaning return it back. To access the printer, first open the top cover for the ink cartridge. The absorber pads are seated under the cartridge carrier, when the cover is open the cartridge carrier will move to the middle leaving the two absorber pads accessible. Use a tweezer to lift up the pads.
Second Solution - Reset the Printer to clear the error
1. Turn off the printer (but make sure power cable is plugged in wall outlet).
2. Press and hold down the Stop/Reset button
3. While holding the Stop/Reset button, press and hold down Power button.
4. While holding down the Power button, release the Stop/Reset button.
5. While still holding the Power button, press the Stop/Reset button twice.
6. Now release the Power button.. (wait until it display "service mode")
7. Press the Stop/Reset button four times
8. Turn off the printer
When you turn on again the printer it will surely works again.
Much appreciated if you could give a four thumbs up rating for this solution.
Thank you for using Fixya.
Sep 14, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Locate waste ink absorber pad
canon pixma ip1000 printer, how do you access and clean waste ink absorber pad
Apr 13, 2010 | Office Equipment & Supplies
Pixma ip1880 ink absorber is full pls tell how to fix
Turn off the printer and take some soft absorbent tissues and fold it into a pad.
Lift the cover to expose the ink cartridges and place this pad over the ink absorber on the LHS of the printer so the pad soaks up the wet ink.
Repeat until the absorber is nearly dry.
Nov 24, 2009 | Canon PIXMA MX310 All-In-One Printer
Cleanilng ink absorber pads
boil them till the ink starts coming out then rinse and repeat if nessisary "DO NOT OVER BOIL"
Mar 27, 2009 | Epson Stylus RX580 InkJet Photo Printer
Canon pixma MP110 waste ink absorber full
1 - Turn on the printer
2 - press MENù SCAN COPY SCAN (it will enter in service mode)
3 - select TEST MODE
4 - Select PRINTER TEST in TEST MODE
5 - Select EPROOM CLEAR
6 - Select INK COUNT
7 - Press OK
8 - Press the STOP/RESET key and then press the ON/OFF key
9 - Change the waste ink absorber in the printer
Oct 24, 2008 | Office Equipment & Supplies
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
27 people viewed this question
old marine
old marine
