Question about Kenmore Elite HE4 Electric Dryer
My Kenmore Elite dryer keeps beeping..just going through the end of cycle alarm-high,low,off...anyone have any suggestions. Now no panel lights, drum light on with door open, off when closed.
  • Kenmore Master
  • 2,699 Answers
It sounds like you have a bad computer board.every time i saw a dryer that beeps on it's own it was a bad board and now you say you have no lights.most likely it's the board.there should be a tech sheet that will tell you how to get the machine into diagnostics,also you can try to unplug it for like 15 minutes and plug it back in,sometimes it will reset the board just like a house computer but if you have no lights it might not reset.remove the bottom panel the tech sheet should be taped to the back of it or in that area.
Posted on Oct 17, 2013
SOURCE: DYRER PROBLEMS
i took the top off checked all the wiring, cleaned the back vents, and the vent tube going outside. I also cleaned the lint screen and gaurd really good, put it all back together. I also unplugged the dryer waited a few minutes and plugged back in. The dryer had a code flashing saying it lost power, I reset the dryer and it has been working great now. Evedently it must be sensitive.
Posted on Aug 19, 2008
InMrFixIt
  • 121 Answers
SOURCE: kenmore elite he4 dryer wont run
Hi! crystal2hd
My he3 dryer does not have a door lock. The door switch turns off the light and allows the dryer to start. Make sure this switch is not damaged. Unplug the dryer before removing the front cover.
InMrFixIt
Posted on Aug 27, 2008
huuum
  • 750 Answers
SOURCE: Kenmore Elite HE4 - Smartheat Quietpak9 ERROR CODE 4E
Buckeyw,
Huuum,at your service!
With an error code.
This can reset the system.
First unplug the washer and wait a 5 minutes then restart it.
It's like rebooting your computer when its acting strange!
Usually it corrects some error problems.
if they are not serious, or they are a temp glitch!
How old is the appliance?
If the appliance is 10 years old or more you it may not be advisable to put good money into bad!
New appliances are so much more efficient today that they can save you a lot of money in energy!!!!
Water,Electric and detergent! And put money back in your pocket!
The new appliance will pay for itself in only a few years!
Bless You
PLEASE GIVE ME A GOOD RATING HERE AT FIXYA.COM BEFORE YOU SIGN OFF.
Thank You
Posted on Sep 18, 2008
JR JR
  • 116 Answers
SOURCE: drum light goes on and off kenmore elite oasis dryer
repl user interface ,, it has a stuck button,, order inter face
Posted on Nov 30, 2008
SOURCE: my kenmore elite he4 dryer-model#110.95087401 keep
I had the same problem and eventually none of the cycle buttons light up or the cycle time display. So it would not run at all. After taking it apart once and fiddling with the cycle push buttons, it worked for one load then would not work again. I could see 3 of the led faintly illuminated and unplugging and plugging back in the power changed nothing. Then I removed the plastic ring of cycle buttons that is between the panel circuit board and the outer plastic. (There a several layers to get to the ring.) Now I use a long allen wrench to push on the switch on the circuit board. I left the middle start button in place. That does not seem to cause a problem. Several loads now and still working. So it looks like the ring on plastic buttons don't release from the circuit board buttons causing a problem.
Posted on Mar 15, 2010
How do I stop my washing machine door alarm beeping?
do this and fix it. God bless you
However read the instr. manual section troubleshooting /
if doesnot have download from www.fitness.manualsonline.com
The processes below will get most controls unlocked.
Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 15 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 15 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 15 seconds.
Some Models- Press and hold the control lock button for 15 seconds.
If none of these work try unplugging for 5 minutes
Sep 28, 2012 | Hotpoint WMA74 Front Load Washer
go to instru.manual section troubleshooting and fix it. God bless you
if doesnot have it download from www.fitness.manualsonline.com
However try this.
Sep 28, 2012 | Hotpoint Ultima WF860 Front Load Washer
Have a kenmore he4 front load gas dryer. It would go completely dead like it had no power... intermittedly working... we replaced the control board. Seems to come on fine now however the end of cyc
is the dryer sensing strips clean? Could be some dryer sheet goopus on them causing intermittent sensing to clothes?
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jun 28, 2017 | Dryers
Kenmore Elite Smartheat Quiet Pak 9 won't start. Light turns on and off inside drum when door opens/closes, but no lights come on on the outside display.
My Kenmore Elite dryer keeps beeping..just going through the end of cycle alarm-high,low,off...anyone have any suggestions?
May 30, 2010 | Kenmore Elite HE4 Electric Dryer
My kenmore elite he4 dryer-model#110.95087401 keep beeping and the end of cycle lights are going on from off to high and back to off right through the drying cycle.
Feb 21, 2010 | Kenmore Elite HE4 Electric Dryer
Kenmore dryer beeps constantly
End of Cycle Signal
The End of Cycle Signal produces an audible sound when the
drying cycle is finished. Promptly removing clothes at the end of
the cycle reduces wrinkling.
@ H_GH
@ LOW
@ OFF
END of CYCLE S_GNAL
Press END of CYCLE SIGNAL to adjust the sound level or turn off
the signal.
NOTE: When WRINKLE GUARD _ is selected and the End of
Cycle Signal is on, a tone sounds every 5 minutes until the
clothes are removed, or WRINKLE GUARD _ ends.
Sep 15, 2009 | Dryers
Kenmore Elite Elec Dryer Model # 110 62032100
Kenmore Ellite Dryer - Model 110.73952102 Type DDOT - NAT 1206006 - EH22
The Heat does not turn on! It spins and spins but no Heat? Any suggestions and how to fix intructions would be greatly appreciated. Thank you!
Oct 14, 2008 | Kenmore Elite HE4 Electric Dryer
DYRER PROBLEMS
Aug 18, 2008 | Kenmore Elite HE4 Electric Dryer
Cycle Signal Beeping
The user interface button panel has failed and will need to be replaced.
Apr 19, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite HE4 Gas Dryer-triple beep
Did you have any lights at all on the panel? I just took off the User Interface as going through the troubleshooting guide I found underneath the control panel led me to that solution.
Feb 11, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite HE4 Electric Dryer Logo
103 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
