Question about RCA F32TF720 32" TV
Hissing noise My RCA has a very distinct hissing noise coming from the back. I have heard other people complain about this online but have yet to see a cause or a fix for this problem. Please help if you can. Thank you.
    Prodigy:
    An expert who has answered 500 questions.
  • 556 Answers
Your tv is not properly tuned or reset it once & then see some improvement or your input signal is weak or loose connection near input.
Posted on Oct 01, 2007
SOURCE:
What is causing Loud hissing noise while engine running ?
it may be a hose has a hole in it take carb clearer and spray on the hoses if engine speeds up that hose has the leak
Jun 13, 2016 | Cars & Trucks
How to remove stuck bonnet nut in shower
If you heard a hissing noise, you probably have a leak. In that case, it's probably still leaking right now, hiss or not. You'd better have someone come take a close look.
Aug 04, 2014 | Delta & Single Handle Shower Faucet
Tire leak hissing sound heard under hood from engine
Not the tires
Only makes a noise with the key on
or engine on
No idea without the car
Jul 23, 2013 | Nissan Cars & Trucks
My freezer is located in a garage that is staying hot in these 90 degree temps. I just heard a noise coming from it, looked and stuff was thawing. Husband unplugged and noise has stopped fills like cold...
I would first check to make sure the the condenser coils are free of debri and there is not something against the fan.
Did the noise sound electrical or mechanical or a hiss. A hiss is most likely a freon leak or a compressor blown (usually not worth repairing). A mechanical sound could be something blocking a moving part like a fan. Electrical could mean about anything.
I would check the condenser grill and then plug it back up and try to tell where the noise was coming from.
Jun 08, 2011 | Kenmore Freezers
Motor noise coming out of speakers
you may have a short in one of your speaker wires, or your antania
Aug 07, 2009 | 1993 Buick Century
Hissing noise when releasing brake pedal
Sounds like your brake booster but can't be sure until I know what kind of truck or car you have....
Jun 27, 2009 | 2003 Ford Expedition
52" RCA big screen tv turns on and few seconds turns off by itsel
if you heard a hissing or like static sound your board probably has a hole in it now. the board on the left side with the flyback fransformer. the hole is from where a prong has come loose an is arking over an it burns the board the ark is the sound you heard.
Apr 23, 2009 | RCA R52WM24 52" HDTV Projection Television
Car hissing sound
The noise maybe the p/s pump fluid return,GM had some problem with this but nothing bad. GM makes a resticter that goes in the return line of the pump, it will slow the fluid down going back in the pump stopping the hissing sound.
Jan 31, 2009 | 1994 Buick Skylark
Hissing.
If the hissing noise is from the LCD, it could be from the power supply due to failing capacitors. This noise is generated when the TV is trying to compensate for the lack of voltage/curent requirements.
Nov 04, 2008 | RCA L32HD31 32 in. LCD HDTV
Yet another hissing/buzzing noise from back of TV
Good day.
Check for the horizontal output transistor, flyback and filter capacitors.
Any of these being shorted can cause the problem.
chris
Jan 20, 2008 | RCA F32TF720 32" TV
RCA F32TF720 32" TV Logo
121 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
