Question about Video Game Consoles & Games
I have problem with my ps3 consule it has crashed on screen with wavy line/ribbon across it coloured green i cannot now get into menus on console or access games or do anything with controllers etc
  • 4 more comments
  • jomossi Apr 24, 2009
    do i need to open consule up ??
    as i cannot see why connections would come loose as it never been moved from same place
    will connections become loose inside console will it be obvious which ones ar not connected
    my ps3 console is stuck in green screen with wavy line/ribbon it will not let me inot menus etc and sometimes game sound comes on but screen does not change help
    how do i reset to factory settings as i cannot get into menus ??
    is there a way to do it without being in menu
    thanks am trying this just now and have saved links i was given so heres hoping thanks a lot for your help
  • 326 Answers
Providing you have already left the system disconnected from power while the power switch on the device is switched to on for at least 10-15 minutes, try these procedures
If you can get to the system settings menu, there are restore options. This would be the first place to start.
It sounds like these issues are preventing you from viewing the screen though, so you may have to try this:
1 - Turn on TV and set input to port being used.
2 - Make sure PS3 is connected via correct cable.
3 - Power on PS3 via power button and HOLD IT for 5 seconds (release after the second beep). It should automatically configure your PS3 to the TV's native resolution for all settings.
There is also one last option. If the storage drive in your system is defective in anyway, I have heard of using an application called SpinRite solving the problem. This is not a free application, but it is the best tool for hard-drive maintenance and repair.
http://www.grc.com/sr/spinrite.htm
Hopefully some of these solutions have helped you.
Posted on Apr 24, 2009
  • NitrusInc
    NitrusInc Apr 24, 2009
    Information on Hard Resetting:
    http://www.tech-recipes.com/rx/2265/ps3_...
    President:
  • 1,383 Answers
Open it and reattch all connection .also check assemble is right connected .
  • kishor
    kishor Apr 24, 2009
    can u reset it.
    reset all settigns to factory defaults settigns.
    remove power from it then try.
No icons coming up on home screen
So, when you power on the unit, you get the wavy screen and then nothing more? Perhaps no 'wavy screen'? If so:
Your HARD DRIVE (aka: Hard Disk), located on the left side of the unit, has crashed. You will need to replace the HD.
When you replace your hard drive, you will need to have the latest firmware on a
usb stick. Download the firmware from the playstation official website onto a usb
stick. Once prompted by your system you will need to insert the usb stick into the
PS3. Good luck..
You will need 2.5" Sata Hard Drive.
Jan 26, 2011 | Sony Playstation 3 (PS3) Console
On start up instead of a green screen all I get is grey with wavy lines and it will not play games or dvd's in colour. Any ideas?
Hi.. Try re-seating your video cable at both ends and also try another A/ V cable if you can get one
Apr 19, 2010 | Sony Playstation 3 (PS3) Console
I have a toshiba 22 inch hd tv, when i go on my ps3 at the start screen there is a thin green line (or different colour line depending on the colour of my theme) down the right hand side of the screen. Any...
Would like to tell you that there is nothing wrong with your PS3, but it's the T.V that is causing the problem.
Unfortuntely, the only thing that will cause a thin line or two is the lcd panel assembly. The cost to replace this would be really high so the best you can do is put up with it as long as you can, then replace the set.
Apologies on the bad news but i must be honest with you. I have seen this with all makes of both lcd and plasma tv's
Mar 19, 2010 | Video Game Consoles & Games
When I switch my ps3 on, there are just wavy lines across the middle of the screen, the icons do not appear and games will not play
If you have componite connetion and have played in hdmi than you need to switch the connection back and you will see the screen. Set it to auto detect, go to video settings
Jul 20, 2009 | Sony Playstation 3 (PS3) Console
No start up menu, just wavy line on screen
Your hard drive is corrupt. google: rescuetechla to find my blog page which explains how to fix the problem in detail.
May 11, 2009 | Sony Playstation 3 (PS3) Console
I turn my ps3 on and the lighjt stays red when i hit the on button it turns green and starts to load but stops and all i see is wavy lines across screen what is the problem?
If the wavy line is like static I no exactly what you mean My old Laptop did that to me but that's because my niece dropped it so you might want to think back if you have ever dropped it if not then you might need to get a new hard drive for it because PS3's have a tendency to Screw up because mine wont play any games it just doesn't even try to read the disc but you might have left the system on too long and fried it as well. so i suggest you either have a professional look at it or replace the hard drive and i doubt you want to buy a new system so i hoped i helped you out ttyl BYE.
Apr 26, 2009 | Sony Playstation 3 (PS3) Console
Thin line of colour run across tv screen
Got my mate to look at it ! He had to reset the factory settings for the HDMI (my son was'nt to chuffed as he lost all his saved stuff ) also the screen setting were set to a lower sieze? what ever that means ? but its solved the problem
Nov 21, 2008 | Sony Playstation 3 (PS3) Console
Video Game Consoles & Games Logo
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
