Question about KitchenAid KUDC03FV Builtin Dishwasher
Not enough water
Doesn't add enough water to wash
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 92 Answers
Clear blockage from pressure switch tube inlet air dam.
Just run a few cycles without dishes, can use descaler or vinegar solution
Posted on Oct 18, 2013
How do I increase water level in my wfxd8400uc?
I get this complaint a lot from home owners , I take it you have just got your first front loader washer , and you don't think it adds enough water to wash anything , this is the water saving feature of front loaders
but a simple test I tell most folks to do if they think there water level sensor is not working right
set washer to auto load sense on water level , normal wash cold water, permapress add nothing to drum completely empty! no soap unless you have a auto soap dispenser then it wont start to you add some and close door
start cycle wait till fill is complete just as it goes to agitate stop cycle (plug can be pulled for this if buttons have locked out )and open door see if water level is two fingers wigth under door seal , if its close your ok if it's a long way off then contact a repair department to look at auto sense water level
May 07, 2015 | Washing Machines
My lg intellowasher wf t8501tp won't go into a
Check the pressure switch and hose. Pressure switch is what turns the pump on and off. Trouble is usually in the hose so check it first. Look for the hose to be unattached or clogged.
Jan 13, 2013 | Washing Machines
Samsung WA422PRHDWR not filling with enough water
I find that some of my clothes don't seem to get wet enough to clean them properly. I like to use the pre-wash cycle to wet everything thoroughly then the machine goes through the normal wash cycle and it seems to do a better job. Just an idea.
Dec 08, 2012 | Samsung WA422PRHDWR
Maytag bravos doesn't use enough water
see this causes and fix it.
God bless you
Water comes in very slow This is usually a water valve problem or an inlet screen blocked. 1st check your inlet screens of your water valve. Turn your house water valve off to the washer, undo the fill hoses and inside the water valve, you will see a silver screen. If the screen is filled with water deposits, clean it out and re-install into valve. Don't forget to check your fill hoses also, some hoses come with screens that also may be clogged. Your cold water valve usually clogs before the hot water valve, all that sediment settles in your hot water tank and not in the screens. If you are on a well system, your screens usually clog more often. If your screens are good, then most likely your water valve needs replacing.
Oct 11, 2012 | Maytag Bravos MTW6600T Top Load Washer
Starts water cycle then stops
Probably needs new carbon brushes in motor.
Dec 17, 2011 | Bosch Washing Machines
My washer GTWN5050MOWS doesn't have enough water. Is there a way to make it add more? Newer models have an overide, can mine be upgraded to this?
one bucket at a time perhaps .last new model I saw last week did not have any water level settings for water fully automatic
Oct 18, 2011 | GE Washing Machines
Our dishes are not being cleaned well with residue left on plates and cutlery and the light next to the rise aid is on at the end of the wash
I have had the same problem a time or two. Make sure that you don't overload the dishwasher and nothing is blocking the spout where the water comes out. Also if you haven't done so already, you may want to add some detergent to the pre wash. Make sure you have enough detergent for the regular wash cycle also....Hottest water possible (at least 140 degrees F). If all that doesn't help, try cleaning them on heavy wash. Check to make sure the rinse aid level is still full. I have also found it easier if you rinse the dishes or cutlery off before putting them into the dishwasher.If none of the suggestions work I say changing your dishwashing detergent and/or rinse aid.Good Luck!
Sep 08, 2011 | Dishwashers
No rinsing water coming in
There are 2 versions of this washer dryer, a cold fill only one and a hot and cold fill version.
If it is the cold fill version, it could be the water level switch that is malfunctioning, cutting off before the correct level is reached, or a sticking water inlet valve.
If it is the other version, then the same thing applys, plus the coil on the valve that controls the rinse cycle could be open circuit.
You need a meter to test the valve coils for continuity..
Make sure that there is actually cold water to the valve, if it is a hot and cold fill model.
Plz rate my solution.
Thanks.
Jan 11, 2009 | Indesit W 123 Front Load Washer
KitchenAid KUDC03FV Builtin Dishwasher Logo
57 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
