Question about Garden
I want to remove the blade bar of a Morrison Vantage Motor Mower to replace of the swivel blades. The bolt holding the bar to the direct drive shaft comes out Ok but the bar won't budge....
    Sergeant:
    Champion:
  • 320 Answers
Most blade bars have to be driven of by hitting it with a hammer. They are spun on and off. Sometimes they go counterclockwise.
Posted on Nov 08, 2013
4 Suggested Answers
SOURCE: Sovereign SLM 1500 lawn mower blades have stopped turning
The belts are available part number is SV150. Call ALM Manufacturing 01423 797208 for advice/stockists.
Posted on Jun 29, 2009
  • 1114 Answers
SOURCE: Cant remove blade on lawn mower
Follow directions. See if this works;
Blade Maintenance
�� Warning! Switch off, remove the isolator
key, battery and grassbox before adjusting
or cleaning.
�� Always wear gardening gloves when handling
or working near the sharp blades.
Turn the machine on its right side and inspect
the blade; if blunt or damaged, replace.
Use the following procedure to remove and replace
the blade:
Insert a screwdriver into hole 26 to lock the
drive. Hold the blade 30 using gardening gloves
(not provided) and use a spanner (not provided)
to remove the blade bolt 29, blade washer 28
and blade 30.
Fit the blade 30, blade washer 28 and the blade
bolt 29. Ensure that the blade is the correct way
up (so that this symbol can be seen located
as in figure I) and tighten the bolt 29 firmly.
Ensure the screwdriver is removed before attempting
to turn the machine on.
If this procedure does not work then try the following;
It is not uncommon for the blade bolt to become seized onto the shaft due to all the gunk and moisture on the underside of the deck. Try to soak the bolt several times over with penetrating oil ( WD 40, PB Blaster, etc). Spray the bolt head, the top of the blade where it contacts the shaft, etc. Do this several times and let the penetrating oil soak in. Hit the bolt head gently several times with a hammer to loosen up the corrosion. Then try to remove the bolt per directions.
Hope this helps, if so Please rate, Thanks, and Good Luck!
Posted on Aug 02, 2009
mowerman1857
  • 389 Answers
SOURCE: HOW TO REMOVE MTD BLADE ADAPTER AND INSTALL NEW
Remove the blade bolt and blade, slide the adapter off the crankshaft. If it will not slide off, spray it with a good penetrating oil and let is soak for a bit then take a SMALL hammer and gently tap on the sides of it while pulling at the same time. Slide the new one back on and repklace blade and bolt(s)
Posted on Sep 14, 2009
How to replace plastic blades on a challenge mower
Dave, Remove plug wire, raise mower, or tilt on it's side to access blade. Remove center bolt holding blade on, noting the position so as not to install new blade upside down. Install new blade correctly and tighten blade bolt tight. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Change Lawn Mower Blade
Lawn Mower Repair How to Remove Lawn Mower Blades
What Direction Do Turn the Nut to Change Mower Blade
Jul 28, 2016 | Garden
How do i remove the cutting blade from a morrison 500 reel mower
Disconnect spark plug wire. Turn on side. Block blade from moving using a block of wood. Loosen blade blot with appropate wrench or hindge handle(breaker bar) and socket.
Oct 19, 2014 | Garden
My craftsman 190cc 625 series lawn mower stopped and a friend said that there is a pin that drops when the mower blade gets caught and stops, I'm really in need of help on how to get to the pin if possible...
Wow it's a lot of work it's called the fly wheel key that is sheard. In every case like this you have to make sure you remove the spark plug or uncap the spark plug. Remove the pull cord assembly and then use a pipe or wooden board to keep the blade from moving underneath the mower. VERY VERY IMPORTANT TO USE A CLAMP TO HOLD DOWN THE CLUTCH BRAKE AND DO NOT REMOVE IT TILL YOUR FINISHED OR YOU'LL BRAKE OFF THE BRAKE FOOT ON THE LEVER. Use a breaker bar to remove the bolt holding the fly wheel down. Now here is the hard part. The fly wheel is made of aluminum and can brake easily as well as the fly wheels blades. If it cracks or the fly wheel blade is cracked or broken it's junk. If you don't have a Briggs and Straton puller you can use a lug wrench and pry the fly wheel up. You must first place the nut back on the 1 inch bolt on the center shaft so the threads are not showing at the top of the drive shaft. You have to hit the nut on the center hard but not like to hard to brake anything. After you get the fly wheel off you have to use the model and serial number to get the key from a lawn mower shop. Place the key under the fly wheel and very carefully watch to see if it lines up as you push the fly wheel down. Push it down from side to side so it fits flush. Tighten the bolt. Don't start it first see if when you pull the pull cord it moves with out pulling the rope back into the mower. You'll have to make sure the top bolt is tight like maybe 60 pounds. MJ
Sep 29, 2014 | Garden
I had to change the blade on my CM1936. The hex bolt that holds the blade on had fused to the thing it screws onto -- the metal bar with threads that goes through the middle of the mower. I had to saw off...
You shouldn't have sawed it off. This wasn't a hex bolt, it was a nut threaded onto the motor shaft. The motor shaft is now damaged and so the entire motor will now have to be replaced....unless you can get a machinist to drill and tap a threaded hole in the center of the remaining motor shaft. Good luck!
Aug 01, 2013 | Garden
Motor runs but blade wont turn belt not broken
Although there really isn't much info to go one from your description (type of mover, make and model would help). It sounds like you may have broken the shear pin on the motor shaft pulley.
Mar 28, 2011 | Garden
Shaft turns while trying to remove blade on B&D MM875 elec. mower
Here's the scoop on the MM875: it has a plastic piece called a "blade insulator" (part # 241381-01) that "locks" the shaft to the blade, so that you can remove the nut by stopping or blocking the blade. If it has been damaged or stripped out, then stopping the blade won't do anything. However, the metal spacer directly under the nut IS still locked to the shaft (because of its shape), so you can use a pipe wrench or something to hold that in place and unscrew the nut. You might even be able to get someone in a home improvement store to do this for you. But you will still need to replace the insulator, which is only a few dollars.
Jul 22, 2010 | Black & Decker 19" Electric Lawnhog...
How to remove a blade from a 2.5 hp sears table 10 inch tablesaw
First and foremost unplug the unit from the receptacle. Raise the blade as high as it will go and have it set to 0 degrees in a vertical position. Remove the throat plate (usually red) so you can access the bolt holding the blade in place. The saw came with a wrench for this purpose. It may have even come with 2 wrenches. One to remove the bolt holding the blade on and another to place behind the blade on the shaft to hold the motor. If it only has one wrench look for a small hole in the blade and use a screwdriver to keep the blade from turning. If there is no tool or hole to hold the blade then use a heavy scrap piece of wood to hold the blade while you remove the bolt. As you remove the blade notice the direction the teeth are pointing and put the new blade on turning in the same direction. You just reverse the procedure to put the new blade on. NOTE: Some saws have a motor lock that locks the motor and blade in position making it easier to change the blade. Just be very careful as it is easy to cut yourself on the blade.
Jan 10, 2010 | Craftsman 10" Table Saw
Blade Maintenance
or cleaning.
the blade:
and blade 30.
Aug 02, 2009 | Garden
Looking for spare parts for morrison rapier 710 self propelled slasher specifically a working carburettor . where can I find grave yard of retired MR710 slashers which retain some useful parts. Engine is a...
firstly you are the only person i know of with a mr710 other than myself mine still has serial no on it 00054.To me this says not many made. i could not find a blade for mine so done my own mods with cox swivel blades but do not know of any others in australia. I can not even find any info on net. honda motors with vertical shaft are not common but never give up like all hondas. try the mower shops as an alternative. hope this may help
Apr 24, 2009 | Garden
Blower motor location for 2000 Caravan
The motor is located just under the glove box on the passenger side. I remove the glove box then the panel below the glove box. I also go ahead and pull back the carpet and the padding under the motor. It is held in place by 3-4 bolts that take a 7-8 millimeter socket. I use a swivel extension for the back bolts. The motor with the fan blade attached is a tight fit, just keep wiggling and pulling it should come out. Try to remove the old moter without cracking the fan blade, because sometimes the replacement motor doesn't come with a blade
Sep 17, 2008 | 2000 Dodge Caravan
Garden Logo
81 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
