No power to washer - Washing Machines
    Master:
  • 818 Answers
I apologize-this is where I have to start diagnoising your problem-is the power good in the outlet-any problems with the cord internally-keep me posted-Denny
Posted on Oct 16, 2013
How to check for power?
Do you mean you confirmed there is no power to the washer, or do you just mean it doesn't seem to power on? Have you checked the circuit breaker panel to confirm the breaker for the washer isn't tripped? Do you have a circuit tester or multimeter to confirm you are getting power to the output the washer is plugged in to?
Oct 15, 2016 | Estate ETW4400XQ Top Load Washers
How to fix 12POE-150 power washer leaking gun wand
There are no parts available for the inside of the guns. All you can do is replace the gun.
see parts in link.
http://www.ppe-pressure-washer-parts.com/12POE-150-power-washer-parts
May 01, 2014 | FAIP 1500 PSI Electric Power Washer
Power washer wont pump
Call us when you can be at the washer so we can trouble shoot it with you over the phone.
http://www.ppe-pressure-washer-parts.com/troy-bilt-020416-1-pressure-washer-parts
Mar 20, 2014 | Troy-Bilt TROY-BUILT 91215 - TROY-BUILT...
Frigidaire affnity no power washer does nothing
see this causes and fix it. God bless you
see the diagram attached and troubleshooting.
1. No power to the washer
Make sure there's power getting to the washer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the washer, if this is the case, the wiring must be repaired or replaced.
2. Lid switch
The washing machine may not function if the lid switch is defective. The switch is usually located near the door. Replace if found defective.
Sep 30, 2012 | Frigidaire Affinity ATF7000E Front Load...
Error code F1 on Kenmore Elite "Oasis" clothes washer
Instructions Press "Stop" to clear the current cycle on the washer.
  1. 2
    Press the "Power" button to turn off the washer. Unplug the washer from the power supply.
  2. 3
    Wait several minutes. Plug the Oasis washer back into the power supply and press the "Power" button to turn on the washer.
  3. 4
    Select the desired wash cycle and press "Start."
Dec 12, 2010 | Washing Machines
Low pressure from powerwasher wand when trigger is squeezed
THIS POWER WASHERS ARE TRICKY, TO OPERATED YOU NEED TO OPEN THE WATER FAUCET CONECTED BY A HOSE TO THE POWER WASHER , OPEN THE TRIGGER AND THEN START THE POWER WASHER, OTHER WISE YOU WILL RUIN THE POWER WASHER PUMP.
Nov 01, 2010 | Briggs & Stratton Garden
So I found this power washer for sale. The seller claims that the washer generates a good stream of water, not just full power. He also mentions that after a few minutes the engine starts to bog down...
Don't buy a power that doesn't work.
There are many expensive parts on a power washer. If it was cheap and simple to fix, the seller would fix it and the washer would not be for sale.
Would you buy a car that doesn't work? Especially one with a bad transmission? The power washer pump is like the 'transmission' > the pump is expensive to replace, and the replacement pump may not even be available.
Oct 18, 2010 | Garden
Power went out while washer was in cycle.when power returned the washer wont come on.there is power in outlet but no power onon my washer
hello it's possible that the glass fuse may blown in the power supply inside the washer beware if you put another fuse in and it blows again the you have a dead short on the board someware also make sure you use the same rated fuse the value will be on the end of the fuse or on the fuse holder on the power board good luck
regards
shaun
Oct 08, 2010 | LG WM-2277HW Front Load Washer
My K5.20M power washer won't start. Am looking
Make sure your extension cord is able to provide 13 amps or greater of current. The longer the extension cord the more current it requires to supply the 13 amps to your power washer. If your unit has a long extension cord it could pull more than the typical 15 amps used for a household circuit breaker. If you do not have an adequate circuit breaker it will continue to trip. Now that you have the correct power supply you will notice the GFI Test and Reset buttons by the power washer plug. Plug the power washer into the power receptacle which has live power. Make sure the power washer is off and then push the reset button located on the power washer plug until you hear a click. The GFI should be reset and you can now turn on your power washer.
Jul 26, 2010 | Karcher Garden
Whirlpool GHW9300 Washer does not come on
Aug 06, 2009 | Washing Machines
Washing Machines Logo
19 people viewed this question
Top Washing Machines Experts
