Question about Onkyo TX-SR608 Receiver
Firmware how to put new firmware on my Onkyo?
Onkyo NR5010 receiver select usb input and the now initializing do not display. some options are missing,only "setup" can be selected, "net" and "usb" and "firmware update" can not be selected.
Hello, I am sorry about your issue. Please email me at askonkyo@us.onkyo.com with your serial number and I will check on your options. Thank you, Onkyo USA
Mar 04, 2017 | Onkyo Audio Players & Recorders
Onkyo reciver powers on but no sound
most likely a bad digital board. onkyo has a problem with one of the chips on the board having bad solder joints causing the firmware to not load correctly
Feb 11, 2017 | Onkyo Audio Players & Recorders
Best method to update firmware on Onkyo 656
The first thing you do is go to the Onkyo support site and see what firmware is available if any for this product, there will be instructions on how download and install it.
Oct 11, 2016 | Onkyo Audio Players & Recorders
My onkyo tx-nr5007 wont give me the option for firmware updates. it wont give me a picture on my t.v so i cant adjust anything that way. what can i do? how do i know if my hdmi board is no good?
Greetings
The DSP HDMI board is not accessible anymore .
ONKYO has this problem for some time now
while upgrading over the Ethernet, the system doesn't recognize the new software.
And the AVR stops responding.
At the moment am working on it .
hope for the best .
Jun 11, 2016 | Onkyo Tx-nr5007 145 Watts 9.2-channel Av...
Do I need a firmware update to decode DTS:X Blurays? If so, when can I expect Onkyo to upgrade?
Hi Tony, DTS:X will be available via a Firmware update as soon as it is released by DTS:X, we will advise you via our webpage at onkyousa.com, Thanks, JT
Jan 06, 2016 | Onkyo Audio Players & Recorders
Onkyo error codes
good evening i have a onkyo tx-nr646 and im getting a NG: L R in my display when i power it on
Aug 25, 2014 | Onkyo TX-NR808
DISPLAY STAYS WITH THE ONKYO DISPLAY AND THATS IT
The video card to your Onkyo is OK, as it displays the Onkyo Logo. Contact the authorized service center for Onkyo. A firmware update is necessary. With a Corrupted firmware, this kind of display effects can occur. Gopakumar Gopalan Google
Feb 28, 2014 | Onkyo TX-NR905 Receiver
Hello, i have a problem with my Onkyo receiver. Every time i put it out, it has lost all his institutions. I don't know why this is happens. Every time i have to install the whole receiver again. Do you...
It will help diagnose problem if you provide the model no. of the Onkyo receiver.
Normally the settings are stored in a flash memory device (EEPROM). It is possible this is failing.
Have you recently updated the firmware of the unit? If you know how to run to reset the receiver then try it and see if holds the settings after that.
Oct 24, 2010 | Onkyo Audio Players & Recorders
Simular Problem
HDMI must be hooked directly to the TV and optical or digital coaxial to the receiver. Your receiver has 1.1, 1.2 or 1.2a HDMI firmware and hardware. There is no fix for this issue w/out a new receiver that has 1.3b firmware. All receivers on the market have this issue, not just Onkyo. HDMI comes directly from HDMI. And there customer support !@#$%^&*()!!! Sorry for the bad news! but that's the fix. Hope this helps.
Aug 12, 2009 | Onkyo TX-SR605 Receiver
Onkyo TX-SR605 7.1 Channels... Problem
firmware up date go to onkyo homepage
Apr 01, 2008 | Onkyo TX-SR605 Receiver
Onkyo TX-SR608 Receiver Logo
77 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
