Question about Stairmaster 3800RC Recumbent Exercise Bike
Set program and the screen starts flashing - Stairmaster 3800RC Recumbent Exercise Bike
    Problem Solver:
  • 7 Answers
Is the panel run on batteries?
Posted on Oct 21, 2013
Why is my IIIWoods 50013 outdoor 24 hour timer switching to OFF regardless of setting? How do I fix it?
First start with the reset button, clears out all past commands.
First the clock has to be set to the proper day and time, It might be in the 24 system versus AM and PM you can find this out by stepping through all the hours when the time comes on. To set clock press Set and see what is flashing, if it is the day, scroll to the right day and hit set, now time should flash scroll to right hour, press set, right minutes, press set, right seconds, press set; Now the clock should be set.
Next you do the programs you want again go through same process, hit program 1 should flash press set, now the days should flash, scroll through till you have the right combo of days, one day, all days of week, Sat, Sun, then last the whole week will flash, if that is the one you want then press set, now press set and the times should flash for hour.
pick the time you want to come on, hit set for hour, minute, second, then hit set again now hit the program button again and it should say off, go through the same steps and set hour, minute second then hit set for last time. In a few minutes it should change to reading the time on the screen. Then you have to wait and see if it works. To do a mini version, see if it will work get a lamp plug in set all the above but use a very short on off time like 4 or 5 mins, then you will know if it is going to work right. then set for the correct time. good luck hope it helps. If it all messes up just hit reset and start all over, REMEMBER it can't so anything until the time of day is set right that's the starting point.
Dec 04, 2016 | Hardware & Accessories
Have Panasonic omnivision VHS PV-D4743S-k 4 head Hi Fi stereo and am having problems setting the timer. Could you help please?
To set the time do the following:
Press PROG*
to display Program.
To set record DATE,
press
to select:
1~31= one time, or
DAILY= MON~ FRI, or
WEEKLY= same time
each week and
press SET.
To set remaining items,
press
to select and
press SET
to set START/ STOP times,
CH (channel) or LINE
input (p. 35), and tape
speed (SP, LP, SLP).
Press PROG
to end programming.
To Enter More Programs,
press
to select and
press SET
to set an unused program
number, and then repeat
step 2.
Or
Press PROG
to exit.
The “Timer” Indicator lights up on DECK.
• You can do Timer Recording with the power on or off.
• “TIMER REC WILL START SOON” appears on-screen for 2 minutes
before Timer Recording starts. If DECK is in DVD mode, no message
appears, but the VCR REC Indicator, the VCR mode indicator and
“REC” will flash on Multi function Display.
Hope this helps!
Brad Nelson
Mar 17, 2008 | Televison & Video
When I turned on the computer this AM it had an update for Adobe Flash Player i...When it showed on the screen I clicked instal and went through the steps I was given, but I do not know if it downloaded...
Hi.
Click on the flashing icon on the task bar, this should open the program on-screen. Just follow the instructions to finish the installation or to exit the program.
Regards.
Jun 02, 2011 | Computers & Internet
How to program #49556 te158wta my add: gd659@cgocable.ca
Woods 49556 / TD1300 manual
http://waterheatertimer.org/pdf/Woods-49556-TD1300.pdf
http://waterheatertimer.org/Woods-timers-and-manuals.html
How to program timer.
Plug timer in until rechargeable battery is charged and display shows.
Unplug timer to program
Set current time.
Hold in reset button for two seconds to clear memory
Press and hold TIME button to select 24 hours so there is no problem. Release Time button.
Press and hold SET button.
MO is flashing, and represents MOnday. TU for TUesday. WE TH FI SA SU
Continue holding down SET button, and press ? ? until current day displays.
Release SET button.
Press and hold SET button again, and Hours will flash
Continue holding down SET button, and press ? ? until current hour displays.
Release SET button.
Press and hold SET button again, and Minutes will flash
Continue holding down SET button, and press ? ? until current minute displays.
Release SET button.
Press SET button again and current time and day will display.
Programing overview:
Set up to 20 on-off programs.
You can select individual days, or groups of days, or all days of the week
For example MO-SU is all days of the week
For each ON time, you also must set OFF time.
So program1 ON is set, then program1 OFF is set
Each ON is set for day, hour and minute
Each OFF is set for day, hour and minute (select same days for OFF and that you chose for ON)
For example if you want timer to turn ON all days MO-SU, make sure OFF time is also set for all days MO-SU.
Program the timer:
Set ON
Press arrow? until display shows PROG 1 ON
This is program1 ON.
Press SET button, but do not press and hold set button as you did when setting current time.
The days for program1 ON will be flashing on display.
Press ? ? to select day, or groups of days that you want for program1 ON.
Press SET button again, and program1 ON hour will start flashing
Press ? ? to select hour that you want for program1 ON.
Press SET button again, and program1 ON minute will start flashing
Press ? ? to select minute that you want for program1 ON.
program1 ON is set, next you must set program1 OFF
OFF
Press arrow? until display shows PROG 1 OFF
This is program1 OFF.
The days for program1 OFF will be flashing on display.
Press ? ? to select day, or groups of days that you want for program1 OFF.
Press SET button again, and program1 OFF hour will start flashing
Press ? ? to select hour that you want for program1 OFF.
Press SET button again, and program1 OFF minute will start flashing
Press ? ? to select minute that you want for program1 OFF.
program1 ON and OFF are set, next you will set program2 ON by repeating steps above.
If you do not want to set more programs, that is fine.
Timer lets you set up to 20 programs.
Finish programming: when program ON-OFFs are set, press TIME button and current time displays.
Last step:
Push manual override button until AUTO is displayed. This will let timer turn lights on and off.
Plug lamp into timer.
Lamp must be turned ON.
Plug timer into wall.
Dec 04, 2010 | Woods Hardware & Accessories
How do you program?
Hello!
This could help
How to set the time:
1. Plug in the unit. Wait until the hour on the LCD starts blinking
2. Press the CLOCK button to set the correct hour
3. Press the SET button to switch to minutes
4. Press the CLOCK button to set minutes
5. Press the SET button to accept the time
***there is no AM icon, only PM***
How to program delay brewing:
1. Press and hold SET until the hour begins to blink
2. Press PROGRAM until you see the tiny bell icon on the bottom of the screen
3. Press CLOCK until you get to the hour you want to start brewing
4. Press SET to switch to minutes
5. Press CLOCK to get to the minutes you want to start brewing
6. Press SET to finalize
Press PROGRAM to activate. When the little bell is flashing, the coffee pot is set to go on at the desired time. While the coffee pot is on or in warming mode, there are vertical lines on the top of the LCD screen that shows you it is on. If you press the ON/OFF button, you can turn it off before the two hour keep warm cycle is complete.
Please rate this answer. thanks
Nov 24, 2010 | Faberware FCP512S Cordless Electric Kettle
HOW DO I SET CLOCK
1 Press STANDBY/ON to turn off the unit, if it is turned on.
The clock flashes on the display window.
2 Press and hold PROGRAM/CLOCK SET for more than 2 seconds.
The hour digits start flashing.
AM
3 Press the CD forward or CD back button (track skip buttons) to adjust the hour, then press PROGRAM/CLOCK SET.
The minute digits start flashing.
PM
4 Press CD forward or CD back button (track skip buttons) to adjust the minutes, then press PROGRAM/CLOCK SET.
I hope this helps.. !
If you need more info have a look here for the manual which is in pdf format:
The clock information is on page 10
JVC RC-EX25 manual
Regards
Mike
Oct 12, 2010 | JVC RC-EX25 Radio/Cassette/CD Boombox
How do i set timer
How to program Raindrip R673CT
Download R673CT manual at raindrip
Other models
R683CP
R672CT
Raindrip drip water guide
R673CT
Install 2 AAA batteries to power display
Set current time:
Press TIME and hour digit flashes > Use up-down arrows to set 24 hour clock
Press SET to confirm hour
Use up-down arrows to set minute
Press SET to confirm minute
Use up-down arrows to set day of week
Press SET to confirm day
Program review
Timer can set 16 watering schedules
When programming, look at display:
Notice: PROG for programming mode, #1, start time, run time, SU MO WE for days
Press PROG and display appear just like image above
Use arrows to select 1, 2, 3, 4 through 16 different watering schedules
Programming
Start time hour will flash
Once hour flashes, use arrows to select hour
Minutes will flash
Use arrows to select minute
Press SET to confirm minutes
Run time hours will flash
Use arrows to set run time hours duration (0 to 9 hours)
Run time minutes will flash
Use arrows to set run time minutes
Press Set to confirm
Now #2 shows on display this is about which days the timer will water
Decide 1) every other day, 2) every third day, or 3) watering at will
1) To water every other day:
While 2nd is flashing, press SET and SU TU WE FR will appear in display
2) To water every third day:
While 2nd is flashing, press down-arrow
3rd will start flashing and TU WE SA will display
3) To water at will:
While 2nd is flashing, press down-arrow twice
SU will flash
Press down-arrow to go to MO TU WE etc
Press SET when day you want appear on display
To set another watering program
Scroll back up to "programming" on this page
Press arrows to select programming 1 thru 16
Repeat programming sequence
After programming is set, press clock button and current time will show
Oct 07, 2010 | Raindrip R673CT Digital Water Timer
I have Mr Coffee APX33; I do not know how to set the coffeemaker to turn on automatically. I do not have the manual. Hope you can help. Thanks! Larry
First you have to make sure to set the clock for the correct current time:
Press down and hold the SET button. Then alternately press the UP and DOWN buttons (indicated by arrows), until you reach the current time, then release the SET button. (there is a PM indicator on screen but not an AM indicator - if you don't see the PM you are at AM)
To set the time for the brew to start in the future:
Press and release the MODE button once and the Delay Brew Clock picture will start flashing on the screen.
While the Clock picture is flashing - hold down the SET button while you use the UP and DOWN arrow buttons to set the desired brew time (you can hold down an arrow button to get there faster). Release the SET button and now that brew time is programmed. (After a few seconds the clock picture will disappear but the future brew time is programmed.)
To activate the delayed brew:
Press and release the MODE button once. The Clock picture will be flashing and the time shown will be the time that you previously set for the future brew). While the Clock picture is flashing - press and release the BREW button. The Clock picture will remain on steady. The BREW light will not come on until the time in the future that you have programmed.
Pretty confusing - but it does work. Just remember that if you see the Clock picture on steady - the machine will come on at the time you have set in.
If you want to use the machine earlier - while the Clock picture is steady - you just press the BREW button and it will brew.
If the Clock picture is steady but you want to cancel the automatic future brew - just press the BREW button twice. (This turns it on and then off and cancels the future brew).
I can send a copy of the manual if you like. Lennyg678@aol
Sep 17, 2010 | Mr. Coffee APX33 Coffee Maker
Farberware FCP512S coffee pot instructions
Plug the unit in
Hope this helps
Sep 09, 2008 | Mr. Coffee ISX23
Just bought a new cuisinart coffee maker and no book came with it. I need to know how to program the coffee maker.
  1. Setting the time
  • When the machine is plugged in, the screen will display 12:00.
  • Press and hold the "HR" and "MIN" button until the numbers flash.
  • Then press the "HR and "MIN" button to scroll through the numbers. When the numbers stop flashing, the time has been set.
CAUTION! When you pass the number 12, the letters "PM" appear to indicate the time between 12 noon and 12 midnight. When these letters do not appear, the time corresponds to the morning hours, from midnight to noon. Always make sure the hour is set according to the correct period so that programming is correct.
  • 2 Programming the start time
  • Press and hold the "PROG" button. The numbers and the indicator light flash.
  • Press "HR" and "MIN" in the same way to set the hour to the desired start time for the cycle. When the numbers stop flashing, the programmed time is set.
CAUTION! Programming the start time is not possible when the coffee maker is running.
Hope this will help you.
Best regards
/Mirran
Aug 28, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Stairmaster 3800RC Recumbent Exercise Bike Logo
128 people viewed this question
Top Stairmaster Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
Matt Olenzek
Matt Olenzek
fordexpert
Are you a Stairmaster Exercise and Fitnes Expert? Answer questions, earn points and help others
