Question about Keurig Platinum B70 Coffee Maker
Why is water going back. In the water tank from the white valve
  • 75 Answers
Make sure your reservoir is fully lock in place, also run a descaling process.
Posted on Oct 22, 2013
Install flush valve
Drain the tank (turn off the water supply and hold the flush valve open with your hand).
Remove the old flush valve. Replace it with a new one. Turn the water supply back on.
Jul 29, 2014 | American Standard Lexington Model 2007 /...
Saeco sg200 vending machine LED says no water .I changed the flow meter but no luck what do i ttry next
Unlike older-generation Saeco machines, the SG200 has an LCD display without LEDs. If you really have an SG200 with a "no water" alarm, try cycling the power and listen for water pump noise upon start-up. If no pump noise, check if reservoir is full, to determine which of the two water pumps is failing (the one in the base cabinet or the one that moves water from the reservoir to the boiler)- GT
Jul 24, 2012 | Coffee Makers & Espresso Machines
I have a Culligan AC 30 aqua-cleer drinking water system;after changing the particle filter and the carbonfilter , the storage tank does not fill.I have pumped air in it to pressure 0,7 bar.
When you put air in the tank did you make sure all the water was out of tank? In a three gallon tank there should be 7 lbs of air, 10 gallon 10 lbs of air.
There can be many reasons for no water in tank.
1. Bad bladder in holding tank. No back pressure on membrane (all water going to drain)
2. Faulty membrane (all the water going to drain)
3. Bad capillary tube (all the water going to drain)
4. Plugged check valve at top of membrane (no water)
5. Faulty water feed valve (piercing valve)
6. Fines from post carbon filter have plugged up the manifold (head) of RO unit.
7. Bad valve on RO tank
8. Plugged drain line
RJ
Jul 30, 2011 | Culligan Under Sink Water Filter
I have a problem with the water in the tank leaks past something, maybe the flush valve assembly and the tank has to refill about every 25 min. I got a new flush valve assembly and changed it and put...
Hi keithn60...
I had the same problem one time with my toilet tank, the answer is to put some silicone on the seal washer between the take and bowl assembly and to use a level on the tank to tighten it just enough to be level and not leak.
Please take time to rate me
Jun 27, 2011 | American Standard 4021 White Cadet 3...
How do you remove a tmp valve out of a propane gas water heater and are they universal or do I have to go to a Bradford White dealer? Thanks
yes you can get a universal one at any hardware store[about 15$]. shut off cold valve at top of tank and drain tank through drain at bottom of tank.you only need to drain enough to get the water level below the t&p valve. you should use dope and teflon on the new threads of the valve to ensure no leaks. a big cresent wrench or pipe wrench will work to unscrew the valve in a counterclockwise direction
Oct 23, 2010 | Fasco Bradford White Hot Water Heater...
I flush the toilet, tank fills up and cuts off, but the water leaks out, then the tank cuts back on to fill up and this is a vicious cycle.
Go to the hardware store and get a new flush valve flap made by Korky and install it. Your flush valve flap has worn out and allowing water to leak through.
Oct 12, 2010 | Jacuzzi Bath Era BK37 959 White toilet...
Zanussi tc7103w condenser dryer-water tank light keeps coming on when tank is empty or nearly empty-have found small plastic float and spring on floor behind dryer-where do they fit?
I had this problem. If you look at the valve on the plastic water tank, you will see that those parts are the same. They fit inside the tumble dryer to shut off the water from flowing onto the floor when the water tank is removed. The white hollow cylinders in the tumble dryer and the water tank push each other open. If you study the water valve on the tank you will see how it is put together. It is all held in place by a little 9mm O ring at the back of the valve. The ring gets tired after a while and pops off. The valve then falls apart and you find the cylinder and spring on the floor and the O ring still inside the dryer. I bought an O ring kit and reassembled the valve inside the dryer using a new ring. You will have to pull the dryer out, turn it upside down and remove the floor to do this
Sep 23, 2010 | Dryers
Atwood rv water heater model G6A-8E heats water to warm only then run cold
Normal causes for that would be by-pass valve not in proper position, or defective, allowing cold to mix with hot, or thermostat not touching up against tank properly, or defective. Do you know where that thermostat is?
Look where the black foam cover is, with white letters, below pressure relief valve. One is lettered ECO, other THERM. If you note where the wires go, so as not to mix them up , and pull them off, then peel back the foam cover, you'll see 2 little round discs, that are held against the tank by a small spring. They need to be checked that they are in there properly and are up against the aluminum tank.
Apr 22, 2010 | RTO Atwood DSI-RV Water Heater-6 Gallon
Tank not holding fill level...
Most likely, you do not have a good seal on the flapper valve at the bottom of the tank. To confirm, try this:
Turn off water and flush toilet. Then lift up the flapper valve and put a light coating of vaseline on the mating surface where it contacts the toilet tank when closed.
Turn water back on and see if it continues misbehaving. If that fixes it, it was a bad seal. Usually that is all it takes.
Dec 15, 2009 | Jacuzzi Bath Perfecta EZ33 959 White round...
Toto toilet: refill valve opens and closes rapidly
I believe you have a high water pressure going to the
tank. Minimize the water volume going to your tank. This is done by fully closing the inlet valve under the tank. Then open about 1/4 to 1/3 of the inlet valve. To do this, count the number of turns to get it full close from full open position. For 1/4, divide the number of turns by 4 and divide it by 3, for 1/3 open. Hope this will solve your problem.
Nov 26, 2009 | Water Heaters
Keurig Platinum B70 Coffee Maker Logo
27 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
