Question about Sharp "Electronics 0.9 cu. ft. Grill 2 Countertop Convection Microwave Oven, White"
My micro wave has locked its door. I was using the convention oven for a week and then when I tried using the micro wave again the unit began sparking fire. Now it has locked the door and I am unable to open it? why?
    Problem Solver:
  • 27 Answers
If it is 'sparking fire' then you better unplug it and get a new one. You don't need a house fire.
Posted on Oct 16, 2013
Testimonial: "Thanks, it is 16 years Old! Great while it lasted!"
Try2910227 serial ywmh2205xvb-0 model arcing on the back corner were the rack sits.Is there a way to repair this seen is the unit was purchaced in June of 2011.
Yes, take the rack out and recycle it. I do not know why these micro-wave company put racks in the micro wave ovens. You get some insulation on the inside the micro flaking off next the rack.
The mega-tron tube is a very high energy transmitter. The energy will come out of the top inside the micro wave oven in a wave guide. Micro wave energy that generation by the tube is high frequency into Gega Hertz. You have a metal tray in side the micro wave acts like a big capacitor it stores energy in form of heat the next you know it look like Marconi is putting on a lighting display.
Leave the wire tie on a loft of bread and put in you micro wave oven to defrost. The next thing you might see is a load bread burning, instant toast. ----The use of micro wave were invented by the British before WWII. The mega tron tube generation very high frequency radio wave and these wave struck an object 100 miles away some of this beam energy would balance back to a receiver-----You have Radar.... I wish you and your family well being and be careful of micro wave ovens it can burn from inside out. GB you...stewbison
Aug 22, 2011 | Microwave Ovens
When micro wave oven is in use, I can feel air coming from the door. is it leaking micro waves?
Not likely if the door seals are intact, clean, and the door is latched. The pin-holed screen that you can see through stops the microwave energy. Hope this helps!
Jan 25, 2011 | LG LMH1017 Convection Microwave Oven
Error code F5:E7 Can not get the oven door unlocked or reset this code. What do we do?
Beginner on forumn, don't have any manual in front of me on f5:e7. Sounds like a conventional oven problem, oven door locking. If in fact is some form of conventional heat oven (convection?), I had similar problem with a GE range, it flashed some kind of code seams like which I later interpreted by using owner's manual that explained codes. In my case it was in "cleaning mode" and you can't turn that off unless you unplug or turn breaker off, that puts it back to default mode with nothing running. I simply tried out the self cleaning feature, from there the oven went to full on heat and oven door locked unexpectedly. I learned stays locked till cycle finishes and oven cools, which is some time after the oven automatically switches off, said that it can be a couple of hours before you hear a...click, and now door opens (note to self, don't ever do that again).
Jan 13, 2011 | KitchenAid Microwave Ovens
My Emerson microwave is about 2 years old. I washed it just like I do every week and the power went out on it.
you mean it want power up or want work when you press the star buttom?
1. check the fuse if no power.
2. If it doesn't work when closing the door after setting timer it is the micro switch that the metal lach hits when the door close.
3. unpluge the micro wave unscew the scews to the cover of the microwave remove the cover. up front by the door you will see the micro switch maybe (brown,black,white,red/white ) what ever color it is disconet it take it to the hardware store buy a new one and replace it,themreasemble your micro wave.
Oct 30, 2010 | Emerson Microwave Ovens
Micro wave door closes but micro wave doesn't work
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Aug 30, 2010 | Sanyo EM-A5200SW Microwave Oven
I have a double oven electric whirlpool oven and turned self cleaning on and by mistake as it was loking i opened the door and cannot turn on its showing locked the opens and i can not turn on oven
Hi, Door locked flashing after the attempt of the cleaning cycle. After taking the oven appart to get the door open, I began troubleshooting. I discovered that the door lock motor failed in the locked position. I opened up the motor and found the magnet inside was cracked! The coil winding for the motor was also open. Hope that helps! While your waiting on the new part you can trick the oven by using a zip tie on each of the two lock motor micro switches to hold them closed and remove the lock lever. The oven will work just fine.
bye
Jul 05, 2010 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Range Oven clean cycle problem
An F2 error is the oven temp exceeded 590 Deg with the door unlocked.
I know you have been troubleshooting the door lock issue. There can be a problem with the micro-switch actuating arm of the door latch assembly.
http://www.repairclinic.com/SSPartDetail.aspx?s=t-+JBP30BA4AD+-%3d%3dei245065&PartID=245065
If the actuation arm is bent you will get the symptom your describing. You can attempt to bend the actuating arm "upward" on the microswitch. The curved end of the arm should be even with the curved latch swing arm hole end when properly adjusted.
The switch can also be failing electrically with heat but highly unlikely. You may end up changing out the door latch assy. listed above to correct the problem. I still believe you can just adjust the micro-switch and save yourself some money.
Thanks for using FixYa.
Kelly
May 11, 2010 | GE JBP30 Electric Kitchen Range
F93 code (door not locking) tried to 'reprogram' by leaving unplugged for an hour, worsened the situation. Now when repowering, it immediately attempts to lock the door, obviously unsuccessfully and throws...
F90 Maximum oven door unlock time exceeded.
F91 Maximum oven door unlock attempts exceeded.
F92 Maximum oven door open time exceeded.
F93 Maximum oven door lock time exceeded.
F94 Maximum oven door lock attempts exceeded.
1. (F90, 91, 92, 93 & 94) Check the wiring between EOC & Lock Motor Micro Switch.
2. (F90, 91, 92, 93 & 94) Replace the Motor Door Latch assembly if necessary.
3. (F90, 91, 92, 93 & 94) Check for binding of the Latch Cam, Lock Motor Rod & Lock Motor Cam.
4. (F90, 91, 92, 93 & 94) Check to see if Lock Motor Coil is open. If open, replace Lock Motor Assembly.
5. (F90, 91, 92, 93 & 94) Lock Motor continuously runs - if Micro Switch is open, replace Lock Motor Assembly.
6. (F92, 93 & 94) Check oven door Light Switch - if open, replace Switch.
7. If all situations above do not solve problem, replace EOC.
F90 is a door lock code, Try this...
unplug the range.
wait 1 minute.
turn the range back on,
then while holding in on the oven door.
start another self clean.
wait 2 minutes.
then cancel the self clean.
do not release the door until the door lock light goes out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question&&&^%$
Mar 16, 2010 | Frigidaire 30" Self-Cleaning Slide-In...
I have a microwave unit separate from my oven unit. After I replaced the microwave plate with a dinner plate (because it broke) the following happened after a few weeks: The micro wave suddenly did not...
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose connection on the control unit circuit board
- bad magnetron or other high voltage part (such as a shorted diode)
If you or someone you know decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Please write back with your brand and model number if you need further help.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jun 30, 2008 | Microwave Ovens
Russell Hobbs HOB CTS34 - Faulty glass plate
Door glass broken on russel hobbs 28lt micro wave. Any idea where I can have this replaced. thank you
Mar 15, 2008 | Microwave Ovens
Sharp "Electronics 0.9 cu. ft. Grill 2 Countertop Convection Microwave Oven, White" Logo
57 people viewed this question
Top Sharp Refrigerators Experts
Vernon Taylor
Ilia Bichin
Are you a Sharp Refrigerator Expert? Answer questions, earn points and help others
