Question about Frigidaire Dishwashers
Doesn't clean properly - Frigidaire Dishwashers
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 92 Answers
Dirty machine, dirty dishes.
Does it heat?
are the spray arms blocked?
have you cleaned the sump filters?
Posted on Oct 18, 2013
Dishwasher doesn't clean properly
Hi, have you cleaned filters out and then put a cleaner in and run it through ?
Jan 29, 2012 | Refrigerators
My ddx8017 cd sticks sometimes what up??
What do you mean by sticks? Do you mean it doesn't always eject properly? If so, you may have a dirty pinch roller. If you are careful, you may be able to use a qtip to clean it. Just gently put the qtip through the cd slot and move it from side to side. Keep a firm grip on the qtip so it doesn't get sucked into the cd mechanism.
Oct 30, 2011 | Kenwood Car Audio & Video
Ck engine light stays on. Autozone says it is the camshaft sensor. I have pulled it apart and cleaned it with a qtip and alcohol, reset the battery and it has worked great. Now, it doesn't and my...
Gas milage (economy) is dependent upon the O2 Snsr's (oxygen Sensors) input to the ECU (Engine Control Unit). The cam position sensor, if malfunctioning, it should be replaced (cleaning it doesn't repair the problem which exists inside the component/sensor). Before you start throwing money after parts, Have a qualified/certified Hyundai Service Technician properly diagnose this issue.
Sep 10, 2011 | 2006 Hyundai Elantra
You can hear the starter spin but its not turning over the motor? on a 1993 cbr 600
If the starter clutch gets gummed up it doesn't work properly. Take it off and clean it. If that doesn't work you will need a new clutch. The clutch is at the outside end if the starter motor. Go to the website for a diagram of the starter and clutch assembly. www.babbittsonline.com tombones49_256.gif
Aug 20, 2011 | 1993 Honda CBR 400 RR
Dvd will not play properly
how long have you been using this player? I suspect the laser (lens) of the player. I think the laser (lens) is weak that's why it is not playing DVD properly.
To confirm if actually its a laser problem, insert an Audio CD into the player and see if will play. If it plays, then obviously, your laser (lens) is weak. But if it doesn't play Audio CD.
Get a lens cleaner, use it to clean the lens. If that doesn't solve the problem, get a screw driver, open the player's cover so that you can gain access to the lens, use a cotton board to clean the surface of the lens. This should clean dust or dirt that might be on the lens.
If non of the above solves the problem, then know that you need to replace the laser to a brand new one.
To replace the lens, remove the bad laser, use it as a sample to get exactly the same type and do the replacement. Note that replacing a laser (lens) needs a professional touch, so if you cannot replace the laser, get it to a repairman to fix it for you.
Once this us done, your player will play all DVD discs again properly.
Good luck.
Jul 10, 2011 | Televison & Video
When I try to turn on my dryer it just buzzes for about 5 seconds and doesn't do anything else. The heater doesn't turn on and the drum doesn't turn. Help!!!
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jul 09, 2011 | Electrolux EIED55H Dryer
Cannon mp530 says load paper when paper is loaded
Paper not loaded error is displayed by the printer when the printer doesn't detect any paper. Here try this one.
  • Make sure that your paper is properly inserted.
  • If properly inserted and still the printer doesn't detect it. Try putting more amount of paper in the tray.
  • Be sure that there are no damaged paper in the tray.
  • Clean the rollers using a cotton buds and a clean water.
  • Now try printing again.
Hope my solution will help. Thanks for using fixya.
Jul 08, 2011 | Canon Office Equipment & Supplies
My toshiba netbook doesn't start
Check to see that the battery is properly in place and installed into the bottom of the laptop. If so, try cleaning the contacts with a dry cloth (never wet, water and electricity don't mix well!). If this doesn't work, unless you're a professional, do not disassemble your laptop. Bring it into a professional to get it checked. (Preferably where you bought the laptop)
Jun 22, 2011 | Toshiba Computers & Internet
The end button doesn't work can still push it but it doesn't respond (the phone accidentally got wet the other day if that had someting to do with it)
It probably has something to do with getting wet. If you can manage to open your your phone then I suggest you open it up and wipe clean it with a dry cloth. Just be sure to return the parts back properly.
Jun 19, 2011 | Cell Phones
My air conditioner cooling system doesn?t work
To get proper cool, keep the tips as follows:
1. Check air filter is cleaned. 2. Check indoor coil is cleaned. 3. Checkindoor blower motor is working. 4. Keep in cool mode. 5. Set temp minimum 3degrees less than room temp.6.Check compressor is working with correctpressure.
Thanks. Helpful?
Jan 20, 2011 | Heating & Cooling
Dishwashers Logo
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
