Question about Dryers
Light bulbe is not working - Dryers
    Genius:
  • 1,617 Answers
Try a different one!
Posted on Oct 16, 2013
What would cause the low beam headlight not to work when all other lights work?
If you have standard halogen bulbs:
  1. Burned out light bulb; or
  2. Fried wires between the dashboard wiring harness and the headlight bulb connectors; or
  3. Fried headlight bulb connectors.
If you have HEI emitters:
  • Failed ballast.
May 11, 2015 | 2002 Mercury Grand Marquis
What would make the brake lights stops working when the Headlights turn on
The brake light bulbs could be at fault....They are designed to work with the brake pedal and the night running lights....The bulbs work as a two way light....This means they have 2 small wires inside the bulb...Some bulbs only have one wire but they only serve one purpose...In cases like that the bulbs are at fault normally or you have a bad wiring issue ...,there is also a brake light switch connected to the brake pedal but if your brake lights work it should be ok..but don't rule it out...anything is possible with older vehicles...Only one wire inside the bulb can burn out and cause one light not to work but the other light will work because the bulb still has one of the wires connected inside...One 1157 bulb works 2 lights,,,the brake light and the running light....It is common for them to blow only half way leaving the other light working ....Look at the difference between a 1156 bulb and a 1157 bulb and you will see what I am trying to describe..An 1156 is for only a one way light because it only has one wire....look at the difference between the two.....If you have never replaced them change them anyway...Sometimes you can't tell when they are blown....Normally the bulbs cause the problem you are having....Thanks
Feb 17, 2014 | 1991 Mazda B-Series
How do i change the bulb on ag821azh microwave x2
follow this steps and use the VOM for fix it. God bless you
Light Bulb
If the microwave light bulb is not working it is usually located behind the upper grille and behind an access panel, and above the lower panel. On counter top units you will need to remove the outer cover to get to the bulb. If that doesn't solve the problem check the on-off switch, and control board
Main Control Board
If the microwave light bulb is not working check the light bulbs, sockets and wiring. If they are good the main control board might be defective.
Light Bulb Socket
If the microwave light bulb is not working and a new light bulb doesn't solve the problem, the light bulb socket might be burned out and need to be replaced.
Jun 19, 2013 | Microwave Ovens
The lamp of won't work
follow the steps and fix it. God bless you
ight Bulb
Main Control Board
Light Bulb Socket
Jun 11, 2013 | Neff H5642 Convection / Microwave Oven
My tail lights are not working on my 2000 jetta the front lights work the break lights work and the blinkers work all inside lights work just fine
you need new bulbs in tail lights one bulb in each side has two elements one works brake other works running lights the elements in the bulb for tail lites are bad . so just replace bulbs. hope this helps.
Sep 13, 2011 | 2002 Volkswagen Jetta TDI
Can't find replacement light bulb:refrigerator model ET18DKXWW00.
Your problem may be in the bulb receptacle or the light switch.
If you have a voltmeter, let me know and I will tell you how to check it.
Mar 04, 2009 | Whirlpool Refrigerators
Replaced light bulbs but no light
Original bulb has a JDR designation. I ordered bulbs and received bulbs with a JDRC designation, the brand was Hikari--these bulbs were shorter than the original bulbs and will not seat properly even after removing filters and turning bulbs by the neck of the bulb (porcelain section). Since they won't seat completely in the socket there is no electrical contact and they won't work.
Feb 05, 2009 | Zephyr Savona ZSA-M90S Kitchen Hood
Dryers Logo
15 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
