Www sunaiservice com
I am trying to connect my dvd/vcr player to my tv, I also have a cable box. I connected the unit directly into my tv, I only receive the audio--
    Scholar:
  • 106 Answers
This all depends on HOW you connect to your TV... is it COAX Cable or Component (RGB) or Composite (RWY) or HDMI (not likely).
Component cables don't transmit sound and can't be used in place of Composite. If you are using Composite it is possible you have the white and yellow mixed up on the TV or the Player, or you might have the yellow (video) plugged into the wrong "input channel" even... it is tough to say without knowing your setup. Just trace the wires from both devices and make sure the DVD/VCR is on the output side of things and that the TV is on the input side of things, and that all the colors match.
Posted on Oct 16, 2013
pishta68
  • 593 Answers
SOURCE: CONNECTING DVD/VCR TO CABLE BOX & TV ETC
If using 3 color RCA (r/w/y) the red and white is audio and should go into your stereo under video or AUX. The yellow is the only video cable you need, that should go to your TV aux in or video1 or video2. You can also put all 3 colors into the tv and then run another red/white OUT to the stereo AUX in and have stereo sound for whatever you are watching.
Posted on Feb 28, 2008
VOTIT
  • 2071 Answers
SOURCE: Hook-up
first you do connect cable to your > combo VCR / DVD player & recorder then connect to > to your TV:
cable coax output or if that cable have video/audio ouput is going to INPUT >to combo VCR / DVD player video / audio output is going to INPUT > to TV,.that's the time you can record and playback;
click below for more information in hooking up:
DVD Players/Recorders: Home Theater Setup, Installation & Hook Up ...If i have helped,please click fixya,it is the only way i get paid for my work ,also please consider leaving feedback...
Good luck ,and Thank you in advance:
Posted on Jul 16, 2008
  • 147 Answers
SOURCE: connecting VCR to TV
Oh man dont shoot your stuff instead use your remote and go to your menu and select your input. You tv is looking at your coaxial input but you can select which input you want. 1, 2 front back whatever you need. channell 3 or 4 has nothing to do with connecting up your dvd if you connect and choose the front connection in your menu.
Posted on Oct 21, 2008
TWITCHDADDY
  • 54 Answers
SOURCE: connecting new Sony DVD player to a TV, VCR, & Comcast cable box
wheres the dvd hooked up
Posted on Feb 14, 2009
SOURCE: having trouble setting up dvd/vcr
Slide down the cover on remote control.On the bottom right side you'll see a little switch(usually is cowered with the warning white little sticker).Slide that switch to DVD1(or DVD2 if somebody got different setting).Power up DVD/VCR combo press system menu botton,go to settings,change to DVD3(factory default)and there you go.Good luck.
Rich
Posted on Apr 11, 2009
Sanyo TV connect to cable box connect DVD player
If your DVD/VCR combo player has three RCA connectors (yellow, red, and white), you can connect them to the corresponding inputs on the front of your TV.
Dec 29, 2012 | Sanyo Televison & Video
Connecting JVC HR-XVC27U VCR/DVD Combo to DIRECT TV
Here is a link to a line diagram to connect most tv/dvd/vcr/direct tv.
Apr 22, 2008 | JVC HR-XVC27U DVD Player/VCR
Combo VCR/DVD player has no cable connection on back> How do I hook it up, through adigital box, to an older TV with one set of white, yellow and red connections?
What outputs are available on the digital box? If you have composite out (AV), then you connect the yellow (video), red and white (audio) to the VCR composite IN on the DVD player. Then connect the composite out from the DVD player to the TV. You will need an extra RCA composite cable. If you need one, they can be found in most stores. (try an online shop that specializes in cables to avoid an outrageous price). The VCR In is to the Right of the DVD/VCR Out.
If the incoming cable is only available with a coax connection, you will need a set top box and a coax splitter. Connect the incoming coax to the input of the splitter. Then connect one coax cable to the TV antenna/cable in. Connect the other to the set top box and then connect the composite output of the set top box to the VCR composite IN.
The manual and the quick start guide are available as PDFs here: http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?slg=en&scy=us&ctn=DVP3345VB/F7 . For diagrams of the connection to a cable or other set top box see the FAQs on the right hand side of the page.
If your cable box has some other output, you will need an appropriate converter to go from component to composite video for example.
I hope this helps.
Apr 22, 2011 | Philips DVP3345VB/F7 DVD Player/VCR
I need help connecting tv to DVD player VCR and satellite box
Connect as following
1. Set top box - RF cable from STB to antenna socket on TV.
2. DVD player output to Video1 on TV
3. VCR output to Video2 on TV.
May be you can route VCR through the DVD player or viceversa. That you can see and try on ground.
Sep 28, 2010 | Haier TN201AUV 20" TV
TRYING TO INSTALL DIGITAL SET-TOP BOX WITH DVD AND TV
Hi ccraigo
To answer your question;
Your motorola will connect directly(not through the dvd) to the tv set into one of the input ,(preferably using hdmi or component cables for hd) and the dvd will use a different input,
All you have to do then is switch between which one you want to watch.
Hope this help Cheers
Apr 20, 2010 | Pioneer Televison & Video
Only dvd plays properly but vhs will not show picture.
Most likely you have the dvd part connected through component or svideo cables. Despite the fact that this is one unit, like other vcr/dvd combo units it acts as two separate units in the same box. The vcr will probably not play through those cables. As you have audio coming through I'd imagine that the audio is connected using red and white composite cable. Connect the video on the vcr side with composite yellow cable or run direct to tv with a coaxial cable.
Feb 04, 2009 | Sansui VRDVD4005 DVD Player/VCR
Need directions to install a dch70 box to tv
dear woolifer ,
I am not an expert but i hope i can help you..
is it youmean digital cablebox?
if it is try this-
This is a problem a lot of people have with coaxial-only televisions because DVD players do not have coaxial (RF) outputs, which means they can't be connected directly into a television with only a coaxial (RF) input. The solution is to purchase a RF modulator, which is a small device that will convert the AV output from the DVD player to coaxial (RF).
As for the instructions, I am going to assume the DVD player is not a combo unit with the VCR, and that you want to record TV on your VCR. Step 4 will include connecting your DVD player, but if the DVD player is a combo unit with the VCR, just ignore step 4 part as DVD connection will be included in the VCR set up. Actually, you wouldn't need the RF modulator if it is a VCD/DVD combo unit.
  1. Connect the coaxial cable coming out from the wall to your digital cable box in the ‘video in’ slot. It might also be labeled ‘antenna in’ or ‘cable in’.
  2. From the cable box, connect a coaxial or composite (yellow video cable) and stereo (red-white) RCA audio cables to the VIDEO IN terminal on your VCR.
  3. From the VCR, you will have to connect this to the RF Modulator using a coaxial cable from the VIDEO OUT on the VCR to one of the IN ports on your RF modulator.
  4. You can now connect your DVD player to the RF Modulator by using the yellow-red-white composite/RCA cables from the VIDEO OUT on the DVD player to another port on the RF modulator.
  5. From the RF modulator, connect this unit to your TV by using a coaxial cable. It will be from the VIDEO OUT on the RF modulator to the VIDEO IN or CABLE or ANTENNA IN port on your television.
This should be all you need to get started watching your digital television. In simple terms here is what you did:
Coaxial from wall to cable box
Cable box to VCR
VCR to RF modulator
DVD player to RF Modulator
RF modulator to TV
You will only be able to record what is on channel
Apr 09, 2008 | Computers & Internet
VCR, DVD, TV Connection
first let me say that a dvd player and a dvd recorder are different. the dvd player can only play dvd while a dvd recorder can both play and record dvd that is said. what i understand from what you write is currently is - out of your tv box into your dvd player then out of your player into your tv........ ok some dvd has two connections. line one and line two if your tv box is in line one then you should plug the rca cable in line two in. then you select line two on the dvd player then plug the other end to your vcr in line out so that is out of your vcr into line two of your dvd player.(some times one of the connection is at the front of your player hidden) if your dvd player only have one connection then you would have to plug out your tv box and replace it with the vcr cable and when you finish coping your vhs tape you plug in back your tv box to your dvd player. hope i could help.......... Tracy
Apr 02, 2008 | Televison & Video
Can't get my DVD player to work...
Your GE TV most likely doesn't have anything but a antenna input on it? If that the case to connect a DVD player you must purchase a RF modulator to convert the video and audio output of a DVD player to a channel 3 or 4 output. Here is a link for one at Radio Shack.
http://www.radioshack.com/product/index.jsp?productId=2103095&cp=&sr=1&origkw=rf+modulator&kw=rf+modulator&parentPage=search
Nov 30, 2007 | GE 27GT271 TV
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
