Question about Toro Lawn Mower With Toro Power Tools
Can't push my Toro 17-44 HXL rider mower. The pull mechanism in the back of the mower doesn't release from the lock position. Any assistance would be appreciated.
  • 109 Answers
SOURCE: Cannot pull the cord more than 6 inches to start Toro lawn mower.
Hi Patti, If you can not pull the cord more that what you said, try removing the spark plug and see if that makes a difference, if not, leave the spark plug out to prevent accidental starting, raise up the front of the mower and see if you can turn the blade if not...it only gets worse from there. If you can't turn the blade from under the mower, the engine is more that likely seized up, sorry
Posted on Apr 26, 2009
  • 203 Answers
SOURCE: Replacement of Belt to mower deck on a Toro 17.38
Go to this website:
https://homeownersolutions.toro.com/portal/server.pt?open=512&objID=214&PageID=0&cached=true&mode=2&userID=19461
Type in 71243 in the search. You want to click on the red tab that says "manuals". Look for the english version, if that is your preference. Click on the red text and it will open up a .pdf with your operators manual. Think it was on page 33 that gave belt lace instructions.
Posted on Dec 04, 2009
  • 3 Answers
SOURCE: hy,i have toro ride on mower,model 71242,serial
You have accepted an Answer! From Ranwell1
Tuesday, January 04, 2011 12:42 AM EST
There are several things that can cause this problem. I will try to give you some ideas and then we can discuss each of them as you wish.
1. The brake someimes sticks on with this model. On the right hand side of the transmission (As you are standing behind the tractor) there is a small brake lever that is connected to the transmission and has the brake rod going from it to the brake pedal. Take this small lever that is on the transmission and pull it backwards toward you. If it is stuck, then it should release and the tractor should move. Most of the time you will have to spray some WD-40 on the brakes behind this lever and move the lever back and forth many times so it will not stick again. One of the reasons this happens is because the battery is usually located above this break and it corrodes. Another cause is that people tend to either wash the unit with water...which you should NEVER DO..... and it rusts solid and sticks.
2. The drive belt may have broken or has worn too much to operate the transmission. Replace the belt even if it looks fairly good if this is over 3 years old.
3. There is a transmission push/pull valve located in the back of the tractor. This is used so you will be able to push the tractor. If this is still in the PUSH position, then the tractor will not drive. Check this and move the lever back and forth several times to make sure that it is not stuck. Sometimes the lever on the transmission will stick and you will have to reach under the transmission and move the small lever itself to unstick it.
4. there is a keyway that is built into the main DOUBLE SHEEVE PULLEY that is located on the engine crankshaft. Many times the built-in key in this pulley will shear and cause the crankshaft to turn inside the pulley without turning the pulley and thus the transmission does not turn under load. If this is the case, you will have to replace this pulley.
5. If someone has taken off one of the wheels to thave a tire fixed, or fro any other reason, many times the key that holds the wheel to the axle slips out of place and the axle rotates inside the wheel without turning the wheel. this will cause the tractor not to move. Check the keys in both back wheels to make sure that they are in places and not sheared.
6. The transaxle itself may have gone bad and may need to be replaced. If this is the case and you have tried all of the other suggestions, I recommend that you take the entire unit to a GOOD Toro repair dealership and have them check it out. These units are sealed units and are not usually customer serviceable, but the dealer can check to make sure that it is not just low on oil. IF it is, then he can add the proper oil to it and it may work, if not, then the transmission will have to be replaced.
Ok, now that I have said all that, I think that TORO has a link on there website where you can download a service manual http://www.toro.com/
You MUST have the EXACT Model and serial number of the tractor. It is located under the seat of the tractor. If you input these numbers, you should be able to get a service manual for this unit.
I hope this helps you.
Posted on Jan 08, 2011
barterjoe
  • 344 Answers
SOURCE: Toro rider 16-38 HXL
Three options:
1. The carburetor throttle plate (closest to the engine is stuck); clean it with gumout and work it back and forth
2. the linkage is hooked in the wrong hole ; check the wear pattern on the throttle shaft plate to see if it is in the wrong hole.
3. The govenor arm or gear is not adjusted properly; loosten the govenor arm, push the throttle plate of the carburetor all the way closed. push the govenor arm the same direction all the way until it bottoms out. tighten the arm clamp. Test again
I recommend getting a manual or at least a free parts diagram from a local shop like www.arcolawn.com
Good luck
Joe
please vote me up if the fix was good.
Posted on Feb 12, 2011
vincob
  • 718 Answers
SOURCE: when i try to start the riding mower will only
Make sure your battery is in good condition first. Then if your machine is an OHV you might want check the intake and exhaust clearance. Go to smalleng.com and watch video they have a great tutorial on this subject. Good Luck...
Posted on Sep 27, 2011
Wheels are locked when trying to push it forward with engine shut off.
There should be a release to disengage the drive system so you can push it when not running. On my Cub Cadet it is on the back above the hitch. It is a simple lever that I pull out and push up to disengage. Has to be something similar on the toro.
May 02, 2016 | Toro Lawn Mower. 22 in. Personal Pace with...
How do you push a toro riding mower
riding mowers have a bypass system to be able to move a machine that's not running. At the rear of unit you will find a heavy wire coming out the back end lift a little and pull this out. you should now be able to push unit
Oct 18, 2014 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
I have a Toro 16hp 38 in hxl with the parking brake stuck, is there a trick to this i dont know.
The snapping sound by the starter is either a bad cable connection or a bad starter. Check the cable at the starter to make sure it is tight and not corroded. If that is ok then test the starter. As for the parking brake, most mowers have a small disk with two brake pads like a disk brake on a car that is controlled by the brake/clutch pedal. Release the brake and check to see if the mechanism on the transmission is releasing. If it isn't it may need an adjustment
If you need further help, I’m available over the phone at https://www.6ya.com/expert/kelly_69a0cf1b13789df1
Jan 18, 2013 | Toro Garden
I can't push my toro pony lawn tractor out of my shed is there a release lever for the ****** if not how can i make it possible to push
on the rear of the mower near the tow hook there is a rod with a loop on it pull it out and move it to the side or down to lock it
Apr 17, 2012 | Garden
MOWER WILL NOT MOVE
check the belts then make sure the levers you pull to be able to push it around are released
Apr 04, 2012 | Toro 74360 Zero Turn Rider Lawn Mower
Hello I have a toro zero turn rider z4220 I think I bought it new about 2 to 3yrs ago when I was putting it up last winter the left drive would not go forward or reverse then shortly there after the right...
Hello, W/D here.
Look for a transmission disconnect rod, usually at the back of the tractor, about even with the top of the gearbox. If it has been moved to the out position, the transmission will not operate from the seat, but you can push it.
Good luck, --W/D--
Mar 17, 2011 | Toro Zero Turn Rider 74366 Lawn Mower...
WHAT CONFIGURATION DOES BELT GO BACK ON TORO RIDE ON. TORO WHEEL HORSE 15-44 HXL
You can go here and get a manual. Theres a $2 charge but it's worth it and will certainly help you.
Jan 15, 2011 | Toro 3 Blade Set For Wheel Horse 42" Deck...
Toro rider 16-38 HXL when I start it revs at FULL speed and sounds like it will blow up. I slow it down with choke all other linkage seems to be in place properly- Is there a trick to fixing?
Three options:
Good luck
Joe
Dec 29, 2010 | Toro Lawn Mower With Toro Power Tools
I have a Toro 1644 HXL mower.It starts fine but if you go to release brake/clutch or try to engage blades it dies immediately. Will start right back up? Safety switch?
u have a saftey interlock circuit issue, poss a bad seat switch or relay is causing it to die when the pedal is released.....good luck hope this helps oh and also might even be the blade switch itself.... get out the volt meter and go to work my friend!
Nov 19, 2009 | Garden
Stuck pull cord on Toro 6.5 self-propelled mower
1) Common problem when a mower sits for several weeks at a time between mowing;
check for extra grass debris to be glogged between the blade and the mower shell.
2) If the mower has a 'bail' or 'zone' control handle;
this releases a brake mechanism on the flywheel to allow it to rotate, and after it is running, releasing the lever will 'kill' the engine.
NOTE* when transporting a push mower in the trunk of a car, try to keep the mower as level as possible.
*extra note when mower has been transported in the back of a car;
sometimes the mower is placed in a trunk at such a severe angle that the oil from the crankcase is forced around the rings and sits on top of the piston so that when you try to pull the rope you have a 'hydra' lock. (that is when a liquid is between the piston and the spark plug) You cannot compress a liquid, so the rope appears stuck.
If this happens, remove the spark plug (make sure the loose plug wire is fastened away from any combustable that comes out of the spark plug hole *** AND THERE WILL BE A HUGE STREAM OF OIL AND GASOLINE, SO BE PREPARED TO CLEAN UP A MESS ***
pull as normal until fluid is dispelled from internal engine
clean or replace the spark plug
a few more pulls (no choke required) and you are up and going
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Nov 08, 2009 | Toro Garden
Toro Lawn Mower With Toro Power Tools Logo
170 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
