Question about Car Audio & Video
I have a gto- 521 ex and can't get the auto turn on to work. It never turns off even with the no remote wire connected and remote turn on switch set to on. The protect power light is green help! Can't figure it out
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 117 Answers
Remove the remote wire and use the auto on button.
you dont need the remote wire.
Posted on Nov 15, 2013
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
  • 33 Answers
U need to hook your remote wire to a wire that is power to it only when your switch is turned on
Posted on Oct 16, 2013
  • 113 Answers
SOURCE: Amp will not turn off and the Remote wire is correct.
check pwm chip ,may need replacing
Posted on Aug 22, 2007
SOURCE: auto amplifier installation
Does the new deck have a blue wire for remote and a blue/white wire also? The blue one is for a power antenna and shuts of when playing discs or axillary inputs. The blue/white is for power amplifiers and stays on when the deck is on. Also be sure the remote wire that goes to the amp is not pinched and grounded out to the frame of the car. Let me know, and be sure to leave feedback or I don't get paid.
Posted on Oct 03, 2007
  • 41 Answers
SOURCE: amp wont turn on
It's possible the ground is not a good connection. Sometimes it may look good but dirt or corrosion builds up resistance creating a voltage drop where the wire is grounded to the frame.
Posted on Jan 26, 2008
tech48
  • 624 Answers
SOURCE: Protect Mode with RCA's
It sounds like you have some DC voltage on the RCA input.
You need to figure out if the problem is coming from the head unit or if it is in the amplifier.
If you have a voltage meter, you can use it to find out very quickly.
Set the meter for DC and for a max level of more than 12 volts. Most meters I use have a 30 volt level. That would be a good setting.
Take the black lead and make sure it is grounded to the chassis of the car or to the ground of the power terminal, be careful and make sure it does not touch anything else.
With the RCA cable disconnected put the red lead on the inner part of the RCA cable and see if there is any DC voltage and then check the ground or outer part of the cable. Do the same for the other channel as well.
It should be very close to zero volts. A couple of millivolts is fine to. Any voltage here will cause the amplifier to go into protect mode, which is what is happening to you. You will then need to have the head unit serviced.
If you have a Pioneer head unit, I have seen many of them with an open ground fuse for the RCA jack. That fuse is a surface mounted fuse and is very small and hard to locate on the main board of the radio. If you do have a Pioneer head unit the voltage may seem OK, but you will have an open ground, but that normally does not put the amp into protect. It makes the audio sound very weak and you would have a loud hum. I can help you with that if it turns out to be the problem.
If the voltage on both the RCA leads is OK, then you need to check the amplifier.
You can put the meter lead on the ground of the RCA jack on the amplifier, if you have anything abnormal there, you have a problem in the amplifier. Be careful checking this because you can easily touch the lead to the chassis of the amplifier at the same time as the RCA ground. Most of the time, if yu have a problem in the amplifier like the one you are having, this check of the RCA ground will result in some DC voltage on it. If it still checks OK, then put the lead into the RCA ground and check the positive part of it. You may need to move the lead around a little to get it to touch the metal inside, it is on the bottom part of the hole inside the jack.
I think you will find that you have some voltage on the RCA inputs of the amplifier. To fix this properly you will need to take it in to be serviced.
Sometimes you can ground the RCA jack ground somehow with a jumper wire and then turn the system on with the RCA cable plugged in and it will seem normal. But you do not want to do that as a repair, only to see if the amp will play. If it does play, you know that the problem is in the pre-amp of the amplifier. That would be the only reason to connect an external ground to the RCA jack. You still have a problem in the amplifier. If it does not play normal, you still have a problem in the amplifier if there was some DC on the RCA jack.
Sorry this answer is so long, but the problem you are having will require service of one of your units, you just need to know which one it is. If your inputs get grounded, you will not have the amp go into protect, you just won't hear anything.
Let me know if you need more help and if this was helpful to you a good rating is always appreciated.
Posted on Jun 22, 2008
  • 899 Answers
SOURCE: Amp won't turn on
disconnect audio inputs and outputs and see if one of those are causing it , if it still does it with all audio inputs and outputs disconnected then there is a problem with the power amp
Posted on Oct 08, 2008
I would like to install a power seat mechanism from a 2004 GTO in my 1966 GTO and need to see the connections needed
you will need a fused power supply and a ground ,,,are the switches on the seat ?? where will you put them ,,,are you going to use the seat belt pretensioner on the newer seat as a 1966 model will not have the sensors or air bag module to connect too .sorry for so vague but never seen a GTO ,now here in spain thats for sure ,plenty of mercs and VWs .europeon turn on is a classic jaguar or a italian fancy job ,here a seat seat 600 turns more heads than anything
Apr 02, 2016 | Cars & Trucks
So I can't get my jbl gto- 521 ex to shut off even with out the auto on wire connected. I tested the wire and when the car is off there is no current but when the car is there is current, so here is my set...
remove the remote wire.
you probably have the power wire touching or connected to the remote wire. you dont need with auto on.
once again, unplug the remote wire.
Oct 16, 2013 | Car Audio & Video
Hunter fan works light broken
Check to make sure light wires are connected at light kit & remote. Otherwise it's probably a bad receiver. If there is a pull chain for the light pull it once & try the remote light button again.
Mar 10, 2013 | Hunter Ceiling Fan Light Switch Control
Hi -\r\n2007 Grand Marque Auto trans stuck in Park. Wont move to gear. Case study: Just have remoate start put in, Steering wheel is easy to turn, car starts, Back lights operate (Except 1 bulb in third...
Check brake light switch behind brake pedal remote start has to be wired into switch so vehicle will shut down when brake is depressed when put into gear without ignition switch turned on. possible bad connection on switch or wires are not attached.
Nov 27, 2010 | 2007 Mercury Grand Marquis GS Sedan
My key died for my 2005 GTO. Can the battery be
your key died? your remote keyless entrey? or the key won't start it no more? if the key won't start it no more try this before wasting money. turn the ingintion switch to the on postion for about 1 sec,. turn off then turn it right back on wait about 30 mins,. then try to start the car. we have alot of problems with them losing the programing for the transponder in the key with the halls effect,. this will usually fix this problem. hope it helps. thanks. and have a great week.
Mar 10, 2010 | 2005 Pontiac GTO
I have a heil heating and cooling unit.The fan is not working but it is still heating ,just not like it did.
Try turning your thermostat from fan auto to fan manual, if the blower starts then you have a burned out speed on the heat leg.
If this is true, shut power off to furnace and try and trace out the blower motor wires. Usually they will
gto to a terminal block that is marked heat/cool.
Just reverse the connections
Feb 08, 2010 | Heating & Cooling
SC 521
Duplex jogger moter Error2
when the hogger fence moves from the home position the jogger fence HP sensor dosent turn off even if the jogger motor has moved the jogger fence 153.5 mm.
ypu need to replacee the sensor
Sep 08, 2008 | Ricoh Aficio 1085 Laser Printer
Xm 1002 hx
1. What type of head unit are you using
2. does the head unit have a Loud feature?
- Sometimes you have to press the loud button on certain head units to engage the amplifier.
Try disconnecting your remote wire from the amplifier, grabbing a piece of small 12 or 16 gauge wire and bridging the remote wire with the (+) on the amplifier. if your light does not turn green, then check your fuse and the ground for the amplifier itself and the subwoofers.
When you connect the remote wire to the (+) it should automatically turn the amplifier on even if the cd player isnt on. The reason I want you to try to connect the remote and power is because sometimes the remote wire for the cd player is bad. If it does end up being a bad remote wire from the head unit, then your best fix would be to connect the red wire (ignition 12v) on your head unit to an on/off switch to the remote on your amplifier. You can then turn your amplifier on and off by flipping the switch. If you go to autozone or advanced auto parts you can pick up a toggle switch for about $3.00.
Feb 20, 2008 | Sony Xplod XM-1652Z Car Audio Amplifier
Keeps swirching to protect mode
First thing to do is disconnect all of the speaker wires on the amp. Turn on the amp, if it is still turning on and off then there is a definant problem in the amp circuitry. If you have no solid state service skills, I highly advise you to take the amp into a repair shop. If it stops turning on and off turn off the amp and try and connect up one speaker at a time untill the amp starts to mess up. you then take that speaker and have it checked out and inspect the wireing for pinchs or shorts.
Oct 03, 2006 | JBL GTO 301.1 Car Audio Amplifier
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
