Question about Juki DDL-8700 High-speed Single Needle Straight-stitch w/ Table & Motor
I have a juki DDL-8700, I believe that the tension is off, when I use the knee lift to move my fabric the tension does not return to normal. It leave the back off the fabric all loopy. Help me please!
    New Friend:
  • 72 Answers
Did you get this answered?
Start by tipping your machine back and making sure that the "mushroom" that is in the middle of your oil pan, isn't stuck as it pops up and down when you press your leg on your knee press. Also that your knee press is working freely.
If neither was a problem, you will probably need a mechanic. If you want to try to look behind your tension on the front of your machine, use a soft brush to clean around your tension, being careful not to bend or break off the wire that is attached to the left side of the tension discs.
Do you work on either very fuzzy or plastic type materials? Small pieces of fuzzy fabric or thread can get inside the left end of the machine and slow down the release of the tension. Also, I have noticed that if I sew on too thick of fabric, like 2 layers of upholstery fabric with a self covered large cord in between, I have tension problems. Some of my larger cording feet aggravate the problem, especially if they are not a hinged foot.
Good Luck.
Posted on Dec 04, 2016
Have a Juki 8700 what type of needle do I need to sew leather? Also what kind of leather have a Juki 8700 what type of needle do I need to sew leather? Also what kind of leather foot do I need?foot do I...
hi there
regarding your inquiry about JUKI machine model DDL-8700 , first your machine type was what ? DDL-8700/SS ( for light to medium material , DDL-8700/HS ( for jeans and can use to sew light to medium lather, type of needle is DBx1, size for lather was 18 and you can use thread number #30 and #20. one more thing you want to change your presser foot to teflon presser foot ( please see attached photo for that presser foot you want to buy.
if need more information please ask
thanks and best regards
Mar 07, 2015 | Juki DDL-8700
How do I stop my Juki DDL-8700 machine from skipping stitches?
set up on quilting table? wheres the oil pan?? if your machine sews fine straight and skips on curves i think you are lifting the presser ft as you make the turn. theres nothing wrong with the machine. you could always change the needle which is always the first thing when you encounter a sewing problem.
Oct 08, 2014 | Juki DDL-8700 Industrial Straight Stitch...
Knee lift won't engage on my Juki. Ddl-8700industrial straight stitch
tilt machine back and look at the lifter bar. try moving it now without any pressure on it. move ok then problem too much presser ft tension of the lifter plate on the vertical bar under the machine is bent or not high enough or not align with the botton of the part the machine thta connects to the presser ft. the lifter bar connected to the knee lifter can be bent to line up with the bar on the machine. go to the other side of the machine and look in thru the oil pan to see how they match up.
Apr 07, 2014 | Juki DDL-8700 Industrial Straight Stitch...
I have a juki DDL-8700, I've recently been having problems with it. When I use the knee lift for the pressure foot, the tension does not go back to normal. The machine could be work fine the when I use the...
Check the tension unit, when you use your knee press a pin should open the tension discs then return to normal, check for any fluff in the discs as well
Oct 15, 2013 | Juki DDL-8700
I can not fix the tension disc of my juki ddl 8700
fine sand paper or adjust spring by pulling in or out could do the trick
Oct 07, 2013 | Juki DDL-8700
Trouble with the stiching on a juki7800
try changing the needle, make sure the needle is the correct one for the fabric being used
also adjust top thread tension
Apr 16, 2012 | Juki DDL-8700
My juki ddl 8700 has a tension problem. The tension post assembly is loose.
theres a set screw to the right of the tension device. maybe its loose. the screw is part of the machine body. don't look for it on the tension device. u have to get your head down in the to see it.
Sep 16, 2011 | Juki DDL-8700
Juki DDL-8700 High-speed Single Needle Straight-stitch w/ Table & Motor Logo
106 people viewed this question
Top Juki Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Juki Furniture Expert? Answer questions, earn points and help others
