Question about GE GSC23LSR Stainless Steel
GE GSC23LSRC Dispenser working intermittenly
We have had a GE Stainless Steel refrigerator (model: GSC23LSRC) for almost 4 years now. For the last 9-12 months the water/ice dispenser in the door has gone on and off intermittenly. Sometimes it will stay on for a month and then go off; and sometimes it will work for 5 minutes and then go off. There seems to be no rhyme or reason or any amount of predictability.
The ice maker is still working and making ice just fine. And we've changed the water filter since this problem began.
Do you have any suggestions on what we can do before calling out a repair technician?
    Genius:
  • 1,847 Answers
This seem issue with the water inlet valve.
Check this link for details..
http://fixitnow.com/wp/2009/01/25/no-water-from-the-dispenser-on-a-ge-refrigerator/
Let me know if you need further assistance..
Thank
K
Posted on Apr 24, 2009
Auto defrost does not work
Most likely a bad defrost thermostat and defrost heater in the freezer.
We need a model number to be more specific.
Jul 24, 2010 | GE 21.7 Cu. Ft. Top-Mount Refrigerator...
Water Dispenser Making Noise
Usually this means you forgot to turn the water on, once water is in the valve it should quiet down
Dec 19, 2017 | GE Profile 25.1 Cu. Ft. Side-by-Side...
GE profile side-by-side water dispenser works, no ice though
Ice maker bad or the ice maker water valve mounted on the same bracket as the dispenser is bad. These frigs are prone to bad ice makers after a few years.
Sep 29, 2009 | GE Profile PSW26P Stainless Steel Side by...
Ice dispenser does not work and water dispenser works rarely.
the solenoid fell off, where does it go, it must regulate crush ice vs cubed ice. everything works except this
Jul 23, 2009 | GE Profile PSW26P Stainless Steel Side by...
Load noise when I turned on water for ice
I assume it was the water dispenser. It has a solenoid on the water inlet valve which can stick. Is the noise coming from the back where the inlet valve is.
Jun 30, 2009 | GE Profile Stainless Bottom-Freezer...
No water from door dispenser
you have a frozen wtr line inside door turn it off for a day or 2 then try it again but this time palce a thermometer in frezeer and keep temps at 0 to 4 degrees if it drops below 0 then the line will freeze again
Oct 30, 2008 | GE Profile PSW26P Stainless Steel Side by...
Front dispenser On GE stainless side by side
Could be the connector at the bottom of the freezer door corroded but it could also be the main PCB failing as the low voltage power supply may be dropping out . By the 'light inside' do you mean in the dispenser or inside the fridge ??
Aug 13, 2008 | GE Profile PSW26P Stainless Steel Side by...
GE Water not working
You may have a frozen water dispenser tube inside the freezer door. You need a GE Water Dispenser Tube Heater Kit, part number WR49X10173.
Apr 10, 2008 | GE GSS25SGSSS Stainless Steel Side by Side...
GE Stainless Steel side by side fridge GS425JSRF - 2 ys old
Make sure there is no obstructions from the time the ice leaves the chute until it drops into the glass. make sure the motor that moves ice and out to the area for the cup is stuck or seized up let us know thanks
Aug 25, 2007 | GE Profile PSW26P Stainless Steel Side by...
GE GSC23LSR Stainless Steel Logo
199 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Ilia Bichin
