Question about GE GSH25JSRSS Stainless Steel Side by Side Refrigerator
How to check inverter on ge model# gsh25jsxlss
2 Suggested Answers
jyackle5
  • 8197 Answers
SOURCE: where can i purchase acircuit
You can get the board on the link below.
http://www.appliancepartspros.com/part_details.aspx?part_id=4436216
Posted on Feb 18, 2011
I have. GE commercial skip tv that went almost dark all the sudden.i tried the menu to set the right colors with no luck..any help plz?
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Apr 14, 2017 | GE Televison & Video
There is a control panel reset for my GE Monogram side by side, Model # zfsb23dnss, It was "repaired" with a new board and now will not cool or freeze, HELP
There is no such button. What part # was on the replacement control board? Your model also has an INVERTER used to control the compressor... When the machine is turned "on" does the fan in the freezer and the fan near the compressor run? Is there any frost on the back wall of the freezer, or is it room temp? GE Refrigerator Main Control Board WR49X10152 .... GE Inverter Board WR49X10283 These two parts control compressor function on your fridge, the first two are the expensive parts called for by your model number- the second two are identical function, but cheaper part number!
Jul 01, 2016 | GE Monogram Side by Side Refrigerator
UndefinedHi I have a Dk smith HD LCD TV model GE-6824,approx 2 years old,display doesnt work now,just black,will turn on ok turn off,green light-red light,but no picture,any idea.And yes its just out of...
In some models of LCD TVS; the backlight inverter and its T'Con board will be a part of the panel itself, and will be a built-in type inside the LCD panel. If so, they can't be replaced. In this case; a panel replacement is the only repair. For some other models, the backlight inverter section circuit will be a part of the main power supply regulator [SMPS]. To such sets, the power supply section circuit too should be troubles hooted. Contact any service technician. The circuit will differ with models and versions.
Mar 13, 2015 | Televison & Video
Need price for ge pfsf5njw model compressor electronic control unit
You have and machine control and a compressor inverter. So I assume you need the inverter that controls the compressor function/run. Part number is WR55X10685, I know you asked for a price but I would check you local parts store and the internet for better pricing for you needs. I don't sell parts, I install them and repair units. I give advise when I have time to help. Good Luck
Sep 11, 2014 | GE Profile PFSF5NJW Bottom Freezer French...
Compressor stopped working, ge side by side
Can you cut the inverter open and look at the board for swollen capacitors or burn marks like these HERE Here is one of my earlier post about a=> 48" GE Monogram ZISS480NRISS Refrigerator It may be necessary to order both the motherboard and the inverter board for your model and return the parts not needed. WR55X10490 Inverter Board
3_22_2013_9_04_47_pm.jpgThanks I will be here to answer any questions you may have Sea Breeze
Mar 22, 2013 | GE GSHS9NGYSS (291 cu ft) Side by Side...
How do I change the inverter board on a ge monogram 36" built in, side by side refridgerator ZISB360DX
it's pretty easy,pull off the old board and put the new board on the same way the old board came off,wires go the same place.are you sure that's your problem,GE has had bad mother board problems and everything that runs on that goes through the board,i've changed over 50 mother boards and have never seen a bad inverter board only bad mother boards but i'm not there to see why you say the inverter board is bad.good luck with your machine and changing the inverter board is easy but it's around 300 dollars,unplug the machine and open the cover and check the mother board it's also on the back,back wall with a few screws holding the cover on and check to see if there's any short marks on the board or the metal frame where the board is mounted,i would say that's your problem but like i say you must of checked it with your meter to know it's the inverter board.good luck
Apr 22, 2011 | GE Refrigerators
No power. outlets is fine. please help. thanx GE Spacemaker® 1.7 Cu. Ft. Over-the-Range Microwave Oven Model # JVM1740DMCC
This will occur if the inverter has experienced a surge or, if the cut off fuse has blown. you can check the cut-off fuse by removing the cover. it is located near the magnetron tube. replace it if it is blown. if the fuse is ok, this will confirm inverter failure. replace the inverter in this case.
Aug 29, 2009 | GE Spacemaker 1.7 Cu. Ft. Over-the-Range...
GE GSH25JSRSS Stainless Steel Side by Side Refrigerator Logo
42 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
