Question about Kenmore HE3T Washer
HE3t leaves water in drum after the wash cycle is complete. Already checked the drain clean out...still leaves water in the drum.
    Master:
  • 818 Answers
Since we are working on the drain side of things only 2 things can happen to not get the water out of your tub-1 the pump isn't working,something stuck in it- 2 you have blockage which we know is not in the trap-check conection to the tub and the pump and all discharge hoses-cheers Denny
Posted on Oct 16, 2013
jsrock516
  • 5911 Answers
SOURCE: Water Leak inside drum
That's because the water fills from around the door bellow via the dispenser. Any small water leakage will probably go unoticed because it drains into the seam in the rubber boot into the wash tub UNDER the wash basket. As it accumulates, it will eventually fill to a point where it is visible in the wash basket. It sounds like you have a water inlet valve that is failing. That's the only way water gets into the washer. It passes from the the water taps, through the inlet valve, through the flowmeter and into the dispenser. If the inlet valve is leaking, you probably have a diaphragm in the valve not closing properly, or a bad solenoid. I would recomend replacing it. To access, you will need to remove the top panel of the washer by removing the three screws in the back of the washer that hold the top panel in place. With the screws removed, the panel slides back, then off. The water inlet valve is located on the left-hand side in the rear of the washer (facing from the front) where the fill hoses connect. You will need to shut off the water supply, disconnect main power, remove the electrical connections to the solenoids, remove the any hoses and finally the mounting screw to remove. If you post back with your complete model number (located aorund the door opening), I can provide you with a part number. If you have further questions, please let me know. I hope this helps you.
Posted on Jun 16, 2008
jsrock516
  • 5911 Answers
SOURCE: Kenmore HE3T washer leaking water
The rubber seal is called the "bellow". Replacements can be ordered on line at searspartsdirect.com, appliancepartspros.com, or repairclinic.com. All three sites offer great service, so shop around for the best prices.
For instructions on how to replace the bellow yourself, follow this link:
http://www.fixya.com/support/r385210-replacing_door_bellow_kenmore_elite
This is not a difficult repair, but it can be a bit intimidating to a beginner. If you have questions along the way, or require additional assistance, please let me know before you rate the solution. I hope this helps you.
Posted on Jan 31, 2009
localwonder
  • 6784 Answers
SOURCE: Washing machine will not complete spin cycle
OK, what you are experiencing is a timer mechanism fault. the timer motor is malfunctioning. anytime you have to manually advance the timer knob, this will signal a fault within the control mech. this is easily fixed by, replacing the timer control module. i will place a link to the actual part needed to fix this issue. you can also purchase this timer on line at this site if you wish.
CLICK HERE
Posted on Jun 18, 2009
  • 5 Answers
SOURCE: Drum doesn't spin at all during wash or rinse.
TRY TURNING THE DRUM BY HAND IF IT DOES NOT MOVE YOU PROBABLY HAVE A BAD MOTOR IF IT MOVES VERY EASILY YOU HAVE A BROKEN BELT. IF IT MOVES WITH SOME RESISTANCE TRY CHECKING THE VOLTAGE AT THE MOTOR IT BE A BAD WIRE
Posted on Aug 22, 2009
  • 949 Answers
SOURCE: I find water in the bin after the cycle has
It sounds like the water inlet valve is letting water enter the machine at times when it shouldn't.
The valve can be replaced and is part number 8181694 it runs about $40.00. The valve can be accessed by taking 3 screws out of the machine top located on the back of the machine, slide the top up and back to remove. The fill hoses connect to the valve in the back and the remainder of the connections are inside from the top.
Posted on Apr 22, 2010
Testimonial: "Thank you"
Is there a lint trap on this washer. Rinse cycle leaves lint. I've even did a complete cycle as a rinse.
Disconnect power, water supply and free drain hose. Turn machine on it's side. Underneath, you'll see two hises the same size as the drain hose ( one is actually the drain hose, the other drains from the drum.
Disconnect both and take shop vac to hoses and water inlets. That should clean out your pump.
look around and see if those hoses lead anywhere other than the drum and directly to the drain. If there is anything inbetween either, that's likely your filter.
Jan 25, 2015 | Washing Machines
Water won't drain out completely and shuts off mid cycle
so do I,try cleaning filter first! if there is one,it would be on bottom front of machine turn it anticlockwise to undo it.clean and refit.get back to me if that dose not work.bye,eire
Dec 12, 2007 | LG WM2277H Front Load Washer
Kenmore elite HE3t front loading washer not starting
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
Sep 26, 2012 | Kenmore HE3t 4.0 cu. ft. Front-Load King...
How to get rid of the stale smell from the atf8000 front loader washing machine
first things first we need to purchase a cleaning tablet from local grocery store called affresh tablets in your laundry detergent aisle ,
then clean out filter sump assymbly in bottom corner of washer som washers have an axcess panel in the bottom righ or left hand corber uncrew filter cap and drain in to bucket or a shop vac .
clean debris out of filter and reinstall the filter screw cap in tightly ..
check your console for a clean cycle option in your wash cycles an select put one affresh tablet inside of washer drum and run cycle..
if you dont have a clean cycle thats ok select your hotest water wash cycle or sanitary cycle put one affresh tablet inside washer drum and run cycle ...
after cycle completes always leave waher door cracked open when washer is not in use ,,, reccomend running an affresh cycle once every month or if u notice stagnant water smell the more often you wash with hot water the less chances of smell
Jan 24, 2011 | Washing Machines
The washer leaves water remaining in drum after the entire wash cycle, it becomes stale and makes my clothes that I was smell. My father's front loader, GE, does not leave any water in the drum
Hello
Check the drain tube,it needs to be 30 inches above the floor.
Also if the drain tube from the washer is too far into the drain the washer will not drain completly.The drain tube should be 1 inch into the wall drain.
Also check for kinks or obstructions in the washer drain tube.
May 13, 2010 | Samsung WF203ANW Front Load Washer
My washer won't drain near end of cycle. Motor
The problem will be on the main board or the power supply board of the machine might have some problem kindly the check the wire lines as well
i do not think that drain pump is having any problem
Dec 30, 2009 | Kenmore 42822 Front Load Washer
Kenmore Elite HE3t which F21 code
I'm guessing the HOSE is the drain hose.
The goop is causing the drain motor to overheat causing it to report error. (luckily or it'd burn out).
Give it a empty load with nothing in it to see if it flushes it all out.
Just water.
See if it completes full cycle and check pump filter again to see if clean.
TIP. Make sure you check ALL pockets before you wash clothes.
Apr 16, 2017 | Kenmore Elite 45986 Front Load Washer
Error code on display panel
F-12 is a drain problem.
Check if the drain hose is free, if cycle stops and gives you f12 without draining the water, there is a problem with the drain system.
The Hotpoint should have a removable paner at the back on the lower side. The panel gives access to the pump. If cleaning the drain hose does not solve the problem, the pump must be removed and cleaned or replaced.The repair should be done by a technician.
Dec 14, 2008 | Hotpoint Ultima WF865 Front Load Washer
Won't spin
As previously suggested, try cleaning out the drain system. See my solution at http://www.fixya.com/support/t114322-kenmore_elite_h3t_washer
-Todd
Nov 25, 2006 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Kenmore HE3T Washer Logo
66 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
