Question about Dishwashers
Cycle lights on dishlex302 wb are flashing continuiosly.Won't start any cycle
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 92 Answers
Hold two buttons for 10 seconds to reset (cant remember which buttons)
if still flashing, its an error code
>> call a service agent
Posted on Oct 18, 2013
SOURCE: start flashes and will not begin wash cycle
My dishwasher Model is 665 15891790 and the serie #FG3907905. After programing my dishwasher and pressing the start button, it fills with water, but when it is due to start the sensing light comes on. I have notice that the ring under the watering arm on the bottom of the machine seams to be cracked. Could that be the problem for the machine not starting its' cycle. Thank you.
Posted on Jun 05, 2007
  • 145 Answers
SOURCE: Normal cycle light flashing
If its the ormal led flashing that is normally caused by a stuck key ing the key pad. Might try unplugging and plugging back in but sounds like you need a new touchpad.
Posted on Apr 18, 2008
SOURCE: l63 Salt light is flashing
goes for short time and 2 ljghts flash the red salt light wont go on
Posted on Jul 06, 2008
  • 320 Answers
SOURCE: failure to start cycle
Please reset the unit once by unplugging the power cable of the device.
and also mail me the brand name and the type of your device, so that i can give you the exact solution.
This is often the electronic control card, or motor relay, but it is often worth unplugging and reseting any component connector plugs and sockets, as they can work loose, and low-level electronic sensors rely on good connections. Pay particular attention to any plug and socket that looks corroded, burnt, brown, or otherwise discolored compared with the rest. High resistance contacts can create intermittent faults, and cause high current parts of the machine to stop working (e.g. heating elements, or motors) Pull off any suspect plug/socket, and clean the contacts with a small file or emery board . Try above steps hopefully it should work. Thank you........
Posted on Sep 24, 2008
  • 9 Answers
SOURCE: starts bleeping 10mins into cycle
http://www.manualnguide.com/dl/12334/ Check on the troubleshooting page as to what certain flashing sequences mean and that may help
Posted on Jan 25, 2009
Won,t work just flashing blue light
Cycle light flashes, but machine wont start - Kenmore Elite ...
https://www.ifixit.com/.../Cycle+light+flashes,+but+machine+wont+...
iFixitThe Kenmore Elite HE3 is a washing machine by Kenmore. ... Whatever cycle I choose, the light just flashes and holding the start button ... I don't seem to have a black pin....the normal wash button just keeps flashing and won't let me start or .
The good ol' Whirlpool Lid Lock Flashing Light Problem - ApplianceBlog
www.applianceblog.com/.../42456-The-good-ol-Whirlpool-Lid-Lock-Fl...
Dec 11, 2013 - 10 posts - ‎3 authors Red Lid Lock light flashing intermittently when you try to start a cycle. ... Mode -- Lid Lock won't work, nor will anything that requires the lid to ... Once the lid has locked the second time, the washer ... shuts down with the lid lock blinking; go back into diagnostic codes and look for shifter or speed sensor errors ...
Nov 26, 2015 | Washing Machines
I have a Whirlpool Cbrio top load washer. it won't start it's cycle. Once it senses the load, the lock lid light flashes and it does nothing. can this be fixed?
I would say that the lock has failed. Either the lock itself or maybe the pin or latch that fits into it when you close the door may have cracked / broken. If the machine thinks the door / lid is still open, it wont let you start it.
Jan 03, 2015 | Whirlpool Washing Machines
The CLEAN light is flashing on my Kenmore QuietGuard3 , but it won't clean anything. It starts a cycle for a few minutes, stops and starts flashing clean again. Any suggestions?
You will have to reset the dishwasher. First try and turn off the mains power and back on after a short time. If the clean light flashing starts again then you go through the hard reset procedure.
press NORMAL WASH then HEATED DRY buttons one after the other until all the lights on the board lit up (3X's). The dishwasher will enter into a cycle; Press Cancel. This should stop the flashing.
If you are supplying dishwasher from hot water inlet then make sure the inlet water temperature stays within the recommended range of 145 deg F.
Apr 21, 2013 | Dishwashers
Whirlpool WTW4950XW Washer won't go past the sensing cycle.
It may be as simple as a defective door switch or even a clogged drain hose (the hose between the tub and drain pump. Here are some videos that may help you more than i can. This guy knows:
http://www.youtube.com/watch?v=Aq7a3j7pFUM&playnext=1&list=PL5258B1D98A50745F
Jan 12, 2013 | Whirlpool WTW4950XW Washer
Machine won't start and is showing error lights
What is the model number of your unit?
Dec 06, 2012 | Washing Machines
Favorit 44070 3 flashes on end of cycle light. No water loading. Does not start
you need a water valve if the overfill float is not malfunctioning
Aug 27, 2012 | Bosch Dishwashers
I have a whirlpool adp6600 dishwasher. the green light just keeps flashing (i think it's 7 times in a row each sequence) and the cycle won't start. have tried turning it off at the wall, clean
Dishwasher is in fault mode hold start/pause button for a few seconds this will reset the unit run your cycle again if dishwasher faults again call you local service man.good luck
Aug 02, 2012 | Whirlpool Dishwashers
Door won't open on whirlpool duet washer frontload
Press the cancel button twice to cancel the error code. There should be an error code flashing -- for example 'F02'.
Nov 10, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Dishwashers Logo
Top Dishwashers Experts
Owen Barnes
