Question about Scotsman Ice Machines Scotsman CU50PA-1A Ice Maker Undercounter Gourmet Cube
Scotsman cu50pa-1a installed and connected to water and electricity. Making a lot of noise but not cooling and no ice
Why won't Ice maker make ice?
Scotsman Prodigy - bad Ice thickness probe
May 10, 2014 | Prodigy Scotsman CU1526MA-1A Ice Maker...
Scotsman ICE MACHINE SHOWS NUMBER 6 IN DISPLAY
does it look like "6" or "b" , the "b" just indicates the ice bin is full. If the unit is not making ice, check the curtain on the outlet of the ice making coil to see that it is not stuck open. There is no listed "6" error code in the service manual.
Oct 09, 2012 | Scotsman Prodigy Air Cooled Cuber C0530SA...
Scotsman cme456as-1a
Pull and clean water level switch. Check to see if water solenoid is getting power to it if so check to make sure you are getting water through it. FIRST check water filter make sure its not stopped up. if that is clear check make sure water line is not kinked. If your unit is not getting water then the unit will run high pressure and lock out on refrigeration.
Jun 14, 2012 | Scotsman Cooled Modular Contour Cuber Air...
Google CME456as-1a service manual you can find PDF to down load.
Scotsman has become very slow in making ice
I would try cleaning the unit, plus if there is a inline water filter I would replace it
May 23, 2010 | Scotsman Ice Machine - 290lb...
Banging noise in water line
If it is banging after it shuts off or cycles you may have a noisy compressor.It can happen during a move or if it droped.Hope i helped:)
May 18, 2009 | Scotsman Ice Maker WBin Flake Style water...
Scotsman Ice Machines Scotsman CU50PA-1A Ice Maker Undercounter Gourmet Cube Logo
29 people viewed this question
Top Scotsman Ice Machines Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Scotsman Ice Machines Kitchen Appliances - Other Expert? Answer questions, earn points and help others
