Question about Nordic Track Nordictrack C2050 Treadmill Motor Control Board For Model Number
Error codes 660 & 595, all functions perform, new motor from Icon, but motor will not go
    Top Expert:
  • Nordic Track Master
  • 12,223 Answers
Please test the output voltage from control board motor, for voltage measure in terminal motor, if there are NOT voltage in output the control board is faulty.
2) Test if there are voltage terminal motor, if there are the motor need to be test. Loose the belt and try again. and if the motor RUn YOU need to LUBE the deck belt board.
God bless youerror codes 660 & 595, all functions perform, new - 5e2ea095-36ba-4f94-afdf-20841fd60f32.gif
Posted on Oct 16, 2013
Error code E002
  1. Press the User Mode key. (Looks like a little man head. Some people call it the function or additional function key.)
  2. Press 2 and 8 on the keypad at the same time.
  3. Press the User Mode key on the control panel.
  4. COPIER Icon
  5. Press the Function icon
  6. Press the Clear Icon
  7. Press the Err Icon
  8. Then ok.
  9. Exit
  10. Power off
  11. Wait 1 min.
  12. And Turn on machine
May 14, 2016 | Canon Office Equipment & Supplies
What does error code E68 mean?
Hello Friend, this is Z. Thank you for your question!
If you are getting an error code E68 on your Frigidaire dryer, it usually indicates that one of the keys (buttons) is stuck closed (active). Let's perform Key Test to determine which button is at fault by entering "Function Test Mode". To perform the "Function Test Mode", doing the following:
Press and hold the START and CANCEL button at the same time for roughly 10 seconds. The stuck key should blink.
Carefully free the key and perform the test again after proper diagnosis. If button is free but the error code still exists, the electronic control will more than likely need replacing after proper diagnosis.
If you do not have a professional connection, you have the option to visit the manufacturer website to find a service provider in your area.
Hope this helps!
Jul 27, 2014 | Frigidaire GLGQ2152ES Gas Dryer
Error code 660 & 595
Ray here, I had the same codes Icon couldn't ID them, new motor, then motor control board was troubleshot by me & my tech guy has never been the same, if it's a commercial grade unit, it starts wth a C, the motors have a lifetime warranty, so don't buy one, 9 out of 10 times it's the MCB ">
Oct 15, 2013 | Nordic Track Nordictrack C2050 Treadmill...
test the output control board motor, if there are NOT voltage for to input voltage terminal motor, the control board is faulty, replace.
2) If there are voltage terminal motor, the motor need to test, take out the belt, and try again if the motor RUN the problem is deck belt board, LubE IT. see my personal TIPS for motor.
Oil light and motor icon light
It is common for many models to track when the last service was acknowledged in the ECU. This could be a simple service light or it could be an error on the computer - a scanner (mechanic) can check for any errors on the ECU.
Jan 31, 2013 | Chrysler Cars & Trucks
All key pad works, except to clean oven. It double beep sound and nothing happens.
Hi Carol.
First make sure that you are performing clean procedure correctly. If you press both bake and broil and then self clean, then instead of self clean the oven will go in child lock beeping twice. Two beeps may also be result of incorrect temp calibration. Perform calibration as suggested in the extract from service manual below:
Before starting the self clean cycle the electronic control (ERC) performs checkout of door latch and temperature sensor, lock motor is activated and both relay for bake and broil start the cleaning cycle. If one of the conditions is not met the electronic control will beep and you may get an error code.
Make sure that both bake and broil are working. If one of the two functions is not working, then one of the relays in the power board is likely faulty: If the oven is not heating at all , then problem is usually the oven sensor.
If the rest is working the problem can be the door lock motor. The relay board and control module may also be causing the problem. The oven must be tested.
This GE range is mostly electronic. Testing is mostly done following the diagnostic procedures suggested in the technical repair manual.
The first procedure is error code reading (user level). This consists in reading the error codes stored in the oven electronic control (AKA ERC).
Here an extract from service manual showing the procedure:
The procedure can be found in the Service Manual at the bottom of this document. Check page 19 of the service manual.at the bottom of this document. When performing the test look for error FF and F2, which respectively mean door latch and oven sensor problem. (codes at page 24 of service manual.
After the error code test, test individually door latch, sensor and lock motor. Perform the tests at page 22 of manual:
If the test does not return any error, then the door latch and motor must be tested manually as explained at page 21 of service manual.
HERE THE COMPLETE SERVICE MANUAL IN PDF FORMAT (click to open).
Regards.
Ginko
Oct 11, 2011 | GE Profile JGBP79 Gas Kitchen Range
Functional Problem SC321-00
What is the actual code. Your heading says '321', then you list "320"?
"320" is the polygon (laser motor) that is defective. "321" is more likely the BICU board.
Could simply require the LD pitch adjustment be performed, depending on what else you have done. Do both the 400dpi, and 600 dpi. initial setting
SP 2109-3 (400 DPI)
SP 2109-4 (600 DPI)
Mar 30, 2009 | Ricoh Aficio 450 Copier
Canon imageRunner 105
Hello PE. I will tell you what the code means and although we can reset the code, if the PROBLEM still exists I am afraid the code will of course return when the copier performs a diagnostic. By telling you the reason for the failure perhaps you can fix the problem and therefore MR. COPIER wont be pissed. :-) This code means that the paper supply referred to as tray "B" has a problem.The lift motor for that paper supply could not (or the copier believes it could not) successfully lift the paper to the correct paper heighth required to feed the paper. This explanation may help you correct the problem.Now to clear the code. On the operator control panel next to the nine key pad is a button that says "additional functions". That button will be part of a 3 step process. Press the the additional function button>>>> next press the numbers 2 and 8 together at the same time>>>> then back to additional functions button.This is a 1,2,3 process that should be executed in a smooth but timely fashion. This will bring up a new window on the screen. Ther will be several "blocks" on the screen and one will say COPIER. Press copier.Then a new screen appears with several tabs across the top. One of those tabs will say FUNCTION. Press function.The screen will be filled with an assortment of blocks and one will say CLEAR. Press clear, and a new set of blocks will appear.One of the new set will say ERR. Press err and then in the lower right hand corner you will say a block saying "OK". Press ok. Now unplug the machine and wait a few seconds and plug it back in.You WILL have successfully erased the error code and the machine will perform its power on diagnostic as if nothing was ever wrong. However if the problem still exists the copier will see it and the code will return. If it does, you can perform the process again but this time pull tray "B" out so the copier cannot run a diagnostic on it. This is merely a workaround and will allow you to use the copier and its remaining paper supplies. As to what specifically the problem with paper tray "B" is could be several things, all of which would require a tech to come out. I must assume that is what you are trying to avoid (as would I ....$$$$$) I hope this helps you and I wish you the best. SPINAL
Jan 18, 2008 | Canon imageRUNNER 8500 Copier
Nordic Track Nordictrack C2050 Treadmill Motor Control Board For Model Number Logo
63 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
Electro Med Services...
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
