Question about Dryers
GE profile dryer DPSB613ED1WW will not turn on by electronic button
  • 188 Answers
SOURCE: dryer not heating properly..taking longer to dry clothes
If there's heat inside the drum the heater coils should be ok, however your model has 2. With the door open and the machine running, look inside at the back of the drum and look for 2 glowing element coils. If one is not working you will not have enough heat.
Check the exhaust vent, make sure it's not kinked or squished behind the machine and that the outside vent is not clogged with lint. You should feel air blowing freely to the outside.
If there is no heat, first check for 240V at the outlet. If you have 240V, it could be the element, the hi-limit thermostat, the thermal cut-off, the timer, the motor or a wiring issue (loose or shorted).
Good luck!.
Posted on Mar 06, 2009
localwonder
  • 6784 Answers
SOURCE: I have a GE Profile dryer. The dryer is squeekly
Check the following areas thoroughly to address this issue.
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat.
3. Heating element
A heating element might only be partially burned out, in which case it would still work but will take longer time to dry the clothes. Replace the element if found defective.
Concerning the squeaking sounds. this can be caused by a bad drum belt or a leveling issue as well. more issues will be bad drum support rollers or, a failing bearing assembly in the idler pulley. the blower, baffles and guides will deteriorate as well, causing noise overtime. These are most of the uncommon issue that will cause this issue, but the most common issue will be failed idler pulley bearings. The pulley will tend to squeak very loudly if the bearings are worn.
Access to the idler pulley varies by model, if your dryer has a lower front panel (kick plate) start there. It should lift up and off or it may be held in place with a few screws or snaps; it may also have a catch at the edges or center gap between the kick panel and main panel. To release the catch, push a putty knife, wrapped with masking tape, into the gap and push back the catch. The next easiest access point is the rear panel. The rear access panel is held in place with several screws along the outer edges. The last resort method of access is the removal of the entire front panel. The front panel supports the front of the drum and so removal is more difficult. Front panel removal varies. In general, access is gained by lifting the top (remove the lint trap screws first), removing the screws that secure the front panel, and detaching the panel from the drum.
When reaching into the dryer be careful of sharp edges on the cabinet and interior supports. Reach in to the belt and give it tug. It should be taught and have only a little give. The belt should go under the idler pulley and over the motor pulley. Lift the idler pulley toward the motor to relieve tension on the belt and remove it from the motor pulley.
Turn the idler pulley wheel, it should turn smoothly, quietly and without any wobble. Inspect it for cracks or uneven wear. If the idler pulley does not maintain proper tension or is damaged it should be replaced. Depending upon your model, the entire assembly or just the wheel or bearing may be replaced.
Posted on Jul 30, 2009
ftw1952
  • 10319 Answers
SOURCE: GE profile harmony dryer has power, drum turns,
check out the ignition spark ignitor
that makes the burner to heat up
Posted on Mar 12, 2010
emissionwiz
  • 76109 Answers
Hello
You need to do some basic testing for me so we can at least get a preliminary idea of the problem here, open the dryer door and spin the drum, does it spin fairly easily? if it doesn't there is a problem that must be addressed first, then I want you to hold the dryer door switch in and spin the dryer drum while a helper pushes the start switch in, if the dryer drum spins and stays running the motor start capacitor or switch on the motor may be defective, if it doesn't start then the dryer motor may be defective, let me know what you find out asap.
Posted on Dec 19, 2010
  • 3074 Answers
SOURCE: My GE dryer model dpsb613ed1ww. Clothes won't dry
1H= 1 hour delay. press the cancel button and then run the dryer with the vent tube off as if it is not drying like it use to then the vent is restricted, note this has nothing to do with the 1H. You will need to clean the vent tube out and you may want to clean the dryer out,also. You will be amazed how much lint is inside the dryer. Good Luck Tim
Posted on Apr 03, 2011
Push power button and it wont beep on
Sounds like the electronic control is bad but check your power supply first
Feb 01, 2014 | GE Profile Harmony DPGT750EC Electric...
I have an electric Ge Performance Wizard Dryer and on the button panel to space over the start button is broken.
get it fixed. it might not be a easy job as electronics are a problem if you do something wrong, it would make something else break. OR just deal with it if it works fine, but a button broken...life isn't perfect.
Sep 11, 2012 | GE Profile Wizard DPSE592EAWW Electric...
My GE dryer model dpsb613ed1ww. Clothes won't dry as usual and I have a 1H in the display. What should I do?
Apr 03, 2011 | GE Dryers
Buttons not working/ screen options work fine
Problem for GE Profile Harmony DPGT750EC Electric Dryer Buttons not working/ touch screen & options works fine
Jul 11, 2010 | GE Profile Harmony DPGT750EC Electric...
GE Profile Harmony Dryer Drum will not turn
the inertia switch on the shaft of the drum motor has failed This will require removal of the drum motor
Jun 01, 2009 | GE Profile Harmony DPGT750EC Electric...
Dryer not heating properly..taking longer to dry clothes
Good luck!.
Mar 06, 2009 | GE Dryers
GE Profile Electric Dryer, Blower nt getting up to speed
On all the ones I've seen with this problem, they've needed a new blower motor. Don't take that as the golden answer because even G.E. tech support doesn't know. It could be the control board, but I haven't seen that yet. G.E. always recommends replacing the inlet thermister, which is accessed through a little cover on the back. Good luck & welcome to the wonderful world of complex electronic appliances.
Jan 27, 2008 | GE Profile Harmony DPGT750EC Electric...
GE profile Harmony electric dryer
not sure of a reset button there maybe a fuse on the controller board What is the problem you are having??
Jan 16, 2008 | GE Profile Harmony DPGT750EC Electric...
Dryers Logo
Top Dryers Experts
Dan Webster
Dan Webster
