Question about Juki DDL-8700
I have a juki DDL-8700, I've recently been having problems with it. When I use the knee lift for the pressure foot, the tension does not go back to normal. The machine could be work fine the when I use the knee lift to turn the fabric, the it doesn't return the pressure back to normal and the thread is looping on the bottom when you turn. I hope you understand. Help! Please
    Champion:
  • 208 Answers
Check the tension unit, when you use your knee press a pin should open the tension discs then return to normal, check for any fluff in the discs as well
Posted on Oct 21, 2013
Zenqi
  • 208 Answers
SOURCE: Juki Sewing machine DDL-555. After 4-5 hours use feed not moving
Sounds like as the machine builds up friction from extended use, some vital part is lacking lubrication and is seizing up. A good service person will remove ALL of the covers and thoroughly air clean and oil every moving part. Sometimes these dry points are hard to find and patience is required.
You can get a sewing machine oiler with a long applicator and put a drop of oil on anything that moves, but over oiling can be messy.
Posted on Jun 17, 2009
SOURCE: The top thread is looping every 30 or 40 stitches
hi there
please check bobin case spring maybe need t adjust or rplace.
please check if you are wind bobin by correct way not too much titght or not too much loose. thread insaid bobin must be littel soft.
the last reason maybe the tip of stoper for hook id damaged and need to rplace.
best regards
ashraf abozid
aabozid@hotmail.com
Posted on Dec 25, 2010
  • 92 Answers
SOURCE: I have a Juki DU-141 with a tread tension issue.
If you are putting too much fabric for the machine to sew this will happen. Does it sew any other fabrics? Some machines....even many commercial machines.........will not sew real heavy fabrics. Any thing over 1/3 of an inch and thats probably the case.
Derek
Posted on Jan 18, 2011
SOURCE: Juki DDL-8700--top & bobbin thread won't hold together for stitch
What bobbins do I use on a Juki DDL-8300
Posted on Mar 11, 2011
  • 89 Answers
SOURCE: Hello, I have a juki DDL 5550, runs great, But the
Soulds like your not geting the top thread all the way in the tension disk. Make sure you have the presser foot up when you thread the machine. also after you get it treaded check to make sure you have tension, with the presser foot up you should have not tension and with it down it should be very hard to pull.
hope this helps
Posted on Mar 18, 2011
How can I run pressure foot selector switch
Pressure on foot is regulated by the screw on the top of the machine directly above the pressure foot bar. Make sure your lever on back of machine is down, then turn the screw by hand, left for less pressure and to the right for more pressure.
Has anyone adjusted the presser foot inside the machine? That can throw it off or sometimes you need to look under the machine head into the oil pan to make sure there isn't something stuck and holding the pressure up from there.
Is this a new or used machine? Does it have enough oil in the pan?
Jul 13, 2016 | Juki DDL-8700
How do I tilt my machine back to access the oil pan? The knee lifter bar is in the way and hit when I try to tilt my machine.
I don't know if you were the person that I was just writing to or not. I didn't think about the knee lift. I generally sew on a Juki DDL-5800 and we don't have the knee lift problem. I have an older walking foot with the knee lift. You might try what works with that one. Grab the front of the knee lift, push it towards the back and at the same time pull it up and left. There is a metal peg at the back of the shaft that will release and let you pull the knee lift out so that you can push the machine back. If that doesn't work, see if you can contact me and I can call someone else to find out.
Shirley :)
Mar 20, 2016 | Juki DNU-1541S Industrial Walking Foot...
Have a Juki 8700 what type of needle do I need to sew leather? Also what kind of leather have a Juki 8700 what type of needle do I need to sew leather? Also what kind of leather foot do I need?foot do I...
hi there
regarding your inquiry about JUKI machine model DDL-8700 , first your machine type was what ? DDL-8700/SS ( for light to medium material , DDL-8700/HS ( for jeans and can use to sew light to medium lather, type of needle is DBx1, size for lather was 18 and you can use thread number #30 and #20. one more thing you want to change your presser foot to teflon presser foot ( please see attached photo for that presser foot you want to buy.
if need more information please ask
thanks and best regards
ASHRAF ABOZID
CAIRO - EGYPT
aabozid@hotmail.com
Mar 07, 2015 | Juki DDL-8700
Pressure foot will not lift up
do u have an automatic machine meaning ft is lifted by pressing ft pedal a certain dirtection. otherwise tilt machine and push knee lever. there should be a flat oval piece on top of lever rod. does it rise straight? it needs to contact the push rod on the machine presser ft. see if the line up by lowering the machine slightly. if not bend rod to aglin. your knee lift may need adjustment too and maybe the presser ft screw located by removing the rubber plug on side of machine or take off the plate by removing 3 screws. careful with gasket cause machine will leak if u tear gasket.. presser ft screw is easy to find. lower ft and tighten. make sure that the needle is centered in foot slot when adjusting presser ft screw. otherwise thread will break when needle hits side of presser ft. a very common problem that many do know about and someday i will charge the site. 35 years with juki and still going strong.
Apr 22, 2014 | Juki DDL-8700
Knee lift won't engage on my Juki. Ddl-8700industrial straight stitch
tilt machine back and look at the lifter bar. try moving it now without any pressure on it. move ok then problem too much presser ft tension of the lifter plate on the vertical bar under the machine is bent or not high enough or not align with the botton of the part the machine thta connects to the presser ft. the lifter bar connected to the knee lifter can be bent to line up with the bar on the machine. go to the other side of the machine and look in thru the oil pan to see how they match up.
Apr 07, 2014 | Juki DDL-8700 Industrial Straight Stitch...
Activate juki ddl-8700-7 bobbin counter
good luck i have 12 juki auto machine and no one can figure that out!!! that panel on top should be shot.
Jul 28, 2012 | Juki DDL-8700
My juki ddl 8700 has a tension problem. The tension post assembly is loose.
theres a set screw to the right of the tension device. maybe its loose. the screw is part of the machine body. don't look for it on the tension device. u have to get your head down in the to see it.
Sep 16, 2011 | Juki DDL-8700
Hi there JUKI DDL 8500-7 Industrial Sewing Machine its that model auto left foot thanks
hi there
can you explain what is the problem exactlly? if the problem how to opne presser foot function tell me control box model or email me.
Best Regards
ashraf abozid
aabozid@hotmail.com
Oct 28, 2010 | Juki DDL-8700
Problems when sewing over heavy jean hems
Are you using the correct type of needle? have a word with your needle supplier and explain the problem. Different threads and different thickness material need different top and bottom tension adjustments.
Can I suggest sew one thickness material at a time with tension adjustments for that thickness. Then change the tensions and do a batch of thicker material.
Mar 29, 2008 | Juki DDL-8700
Juki DDL-8700 Logo
Top Juki Sewing Machines Experts
Tally Girl
Tally Girl
Pete Alaniz
Level 1 Expert
Derek Massey
Are you a Juki Sewing Machine Expert? Answer questions, earn points and help others
