Question about Samsung Microwave Ovens
Samsung microwave.....there is power and lights but no heat and timing is all screwed up, ie, moves thru 30 secs i9n 3 seconds!
  • Samsung Master
  • 9,098 Answers
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes.
Posted on Oct 17, 2013
MicrowaveSvc
  • 9098 Answers
SOURCE: Sparking / Popping Microwave
GE had a rash of "underperforming" magnetrons on these units. They replace the magnetron, stirrer and high-voltage diode at no charge for parts as long as a GE-authorized service center does the work. Sometimes the unit gets run too long in a failing state and the waveguide and chassis of the oven get damaged. To see if yours is covered, see this bulletin: http://www.microwavedisplay.com/ge_mw_mag_kit_bulletin.pdf Otherwise, you need to contact GE Customer Relations at 1-800-386-1215 as soon as possible and tell them your problem and they will put you in touhc with a local authorized servicer.
Posted on Apr 05, 2007
ukvacfan
  • 328 Answers
SOURCE: Panasonic Inverter NN-V673S microwave- shuts off after 2-30 secs
If the screen is showing a fault number or a number you havent seen before then its probably a program fault which can't be fixed. Check that the vent holes on the back of the oven aren't dirty and ensure that the whole oven is clean inside. Sadly it sounds like a program fault which cant usually be fixed by the owner though.
Finding a Panasonic oven repairer in the UK shouldnt be a problem though. My parents had a simlar problem wth their Panasonic Inverter oven, called the UK customer services and Panasonic contacted an authorised repairer in Scotland to visit them. Call customer services on 0844 844 3868.
If the call out charge exceeds £80 then you're probably better off buying a new oven.
Posted on Apr 19, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Panasonic Model NN T964SF inverter
If the digital programmer circuit / controller does not get a feedback signal from the inverter for a period of 3 seconds, the controller will stop the cook cycle.
In most cases, this is a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer.
Posted on Aug 02, 2008
  • 4 Answers
SOURCE: turns off after 3 sec
Usually this indicates failure of the magnetron and/or the inverter. Neither is easy to test without specialised HV equipment. Often the cause is operating the oven without anything in it. If this has happened, it will generally be failure of the magnetron.
Replacement of the magnetron is relatively easy (about 15 minutes) and the inverter a little longer but if you do not have the knowledge/skills please do not do it - there are very dangerous (deadly) voltages associated with magnetrons even after they have been switched off.
Cost of magnetrons ranges upwards from USD25 to USD100 (from Panasonic spare parts) and inverters range upwards from USD125. The cost of parts is often the reason microwave ovens are not repaired.
Doug
Posted on Nov 08, 2008
  • 3 Answers
SOURCE: GE JVM1870SF02 - not heating up anything!!
I had the same problem with mine, and discovered, somehow, that when I manually turned on the "vent fan", the microwave worked fine. A bit of a pain, but it heated up the food when it hadn't been prior to the vent fan being on. Can't understand why it solved it, but it's been working like that for about a year now. When I forget to turn on the vent fan though, the food is just as cold as when I put it in.
Posted on Jul 11, 2010
Hi I have a Samsung SMH9187 micowave that is dead (no display, light, fan, mirowave).
Sounds like the main fuse blew. It's either near where the power cord enters the cabinet, or behind the control panel (if an over the range unit).
You may also have some type of failure in the high voltage circuit; based on your description of the symptoms.
Aug 16, 2014 | Samsung SMH9187ST Microwave Oven
AFTER SETTING TIME COOK TO 1 MIN 60 SEC AND PUSHING START BUTTON 4O SECS MORE IS ADDED, I.E. TOTAL 2 MINS SHOW ON DISPLAY. CAN I RESET THE THE COMPUTER.
There are sixty seconds in a minute, so 1 min 60 sec is the same as 2 min. If you want 40 seconds less than 2 minutes then set it for 1 min 20 sec or for 80 sec.
Oct 03, 2013 | Danby DMW139 Microwave Oven
Micro wave stops working after 30 secs
Replace the door interlockswitches - or try re-positioning the existing set. They wear after time
Jun 08, 2012 | Neff H5470 Microwave Oven
Microwave heat level has changed. My mother is elderly and thinks the micro is broken because it started overheating everything. she isn't well and I wonder if she touched a button that would change...
Wow, that is FAST! I feel it is broken as well. I had a commercial Panasonic 1,500 watt machine that was not as fast as that. Microwaves do have multiple levels, usually only Full Power, Half Power and Defrost (which is low power, pulse, wait, another pulse, wait). It also depends what the food is? Something like one slice bacon, which is thin, and has minimal water content, would heat up much faster than a meat pie. This is why the standard output test uses a measured amount of water, and a set cooking time. I am a trade chef by the way, so this is one of my specialist subjects. Let me know how you get on by clicking COMMENT under my post. I'll get a notification.
This is the way to test the output
How To Check the Output Power wattage of Microwave Oven
A slightly easier way
http://products.geappliances.com/appliance/gea-support-search-content?contentId=16857
Feb 22, 2018 | Samsung MD800SC Microwave Oven
Stuck in demo mode after power outage - any ideas on how to get it out? model is JVM2070
Talked to GE Help Line (1-800-626-2005) and found out the magic key combination for this microwave. Plug in after being unplugged for at least 30 sec. and then press Help plus Boost at same time for 3-4 seconds (until it beeps). The microwave will now be in normal mode (I assume you do this to put it in demo mode as well).
Sep 13, 2009 | GE Profile Spacemaker Over-the-Range...
I have Emerson Microwave #mw8999sv which has the Express Cook option- cooking 1 - 6 minutes. How do I cook for 1 minute 30 seconds, etc.? Thank you.
The owner's manual is here. On page 10 we find:
COOKING IN ONE STAGE
1. Press the POWER button; the Microwave and High
Cook indicators will light and “PL 10” will light in the
display.
2. Press the POWER button different times to set the
desired power; the display will show the percentage
you chose. If selecting power level 70%-10%, the
Low Cook indicator will light instead of the High
Cook indicator.
3. Press number keys to set the desired cooking time.
OPERATION(CONTINUED)
4. Press the START/+30SEC. button to start cooking;
the Microwave and one of the Cook indicators will
blink and the display will countdown the remaining
cooking time in minutes and seconds. It will beep
five times when cooking is completed.
Sep 08, 2009 | Emerson Microwave Ovens
Time count down on microwave oven
Unplug the Micro for about 5 minutes and plug it back in this will reset the board,it may have picked up interference from other electronics.If the issue continues have a technician look at it.
Aug 25, 2009 | Maytag MMV4205 Microwave Oven
Panasonic Microwave only works for 37 secs no matter what time setting
If it stops after 22 seconds, that means the controller has detected a problem, usually a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
In Canada, you can find an authorized Panasonic servicer here.
Jan 04, 2009 | Microwave Ovens
Microwave Ovens Logo
71 people viewed this question
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Oscar Netto
Oscar Netto
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
