Question about GPS
My lowrance X86ds keeps starting in the simulator mode. I have reset to factory settings, set it to OFF manually, and also checked all the wiring. It still starts in this mode.
jerryg50
  • 1689 Answers
SOURCE: I have a Lowrance x-51
You should be asking the repair guys about how much it will cost to repair. They determined the specific parts that have failed.
The members here are not fortune tellers and crystal ball readers. We have no idea of what parts have failed inside of your unit!
Jerry G.
Posted on May 07, 2008
battlesmith
  • 382 Answers
SOURCE: My Lowrance 522 GPS keeps
Hello Tim,
Try to switch it off the simulator mode in the System Setup and then Try to reset the System..This will surely help you!!.Thank you..
Regards!!..
Posted on Jul 22, 2008
franksguitar
SOURCE: How do I reset to factory settings
I have a Tom Tom One US/Canada Version with CE designation on the unit. The on button stays on and will not turn off and nothing on the screen at all. I even did reset even pressing the resrt sequence fr 15 sconds and on button and the unit is fully charged and is not working. Is this thing shot?
Posted on May 28, 2009
SOURCE: My Garmin is stuck in simulation mode at one of my last locations
all garmin nuvi users reset device small button on bottom then plug into computer using usb cable back up the nuvi folder in my computer,just in case, then run virus check on device`s nuvi folder when finished unplug safely , hopefully should be back to normal i have down this with 2 nuvi`s with keyboard problems and it has worked both times hope works for you regards brettjohns1350@bigpond.com
Posted on Jun 15, 2009
SOURCE: how do i reset to factory settings?
www.magellangps.com/assets/.../magellan_roadmate_series_en.pdf
http://support.magellangps.com/support/
manual and help site
Posted on May 21, 2010
Cant get the demo mode off my lowrance elite 5 dsi
go to menu click on system find simulator mode click off
Sep 21, 2012 | Lowrance Elite-5 DSI Color Combo...
Lms-332c lowrance fishfinder unit turns on as soon as the power wire is plugged in and goes to blinking pinging beeping between hi and low light settings constantly. All other features seem to work fine. A...
Hello
I don't know whether you have made a factory reset to this device or not. If not, set it first and see whether it helps you. To make it factory settings:
[1] Press 'MENU""MENU" (down arrow to system setup) "ENT" (down arrow to RESET options/ ENT
[2] The unit asks if you want to reset all the options. Press [<---] to YES and then ENT. All options are reset, and the unit reverts back to map page at 4000 miles zoom range. Any recorded sonar logs of GPS data will be unchanged. OK.
Sep 23, 2011 | Lowrance LMS-332C GPS Receiver
The errore code of my konica 7040 is F-35-2
f 35-i thru f35-6 low temtemperature or open thermistor
simulations
note : 9272 is the standered password to enter simullation press9,2,7,2,start , to use these with power already on press and hold the"*"key util the display says "please enter service password"note:factory manual says"keep pressing" this might mean hold down or it might mean press repeatedly.press9272 start "mode selectmenu screen" will appear.press the mode you want[p ,25, 35, 36 , or 47] when finished press "normal mode"to return to standard screen use the number keys to change values press print key to check item press "stop/clear"when finished
"25 mode" to enter this mode turn power off, press the 2and 5 keys and hold them down while they are held down turn on power menu screen will list choices
1 software switches
2pm count
3collectng
select your choice enter value press"return"to see that your new value has been entered turn power off new in formation will not take effect util power is off and back on again
1 software sw ....use up/downarrows keys to select dip switch use up/down arrow keys to select to select bit number"on"is 1 "off" is "0" on will set bit off will clear bit press "return"to return to menu listing dipswitches and all their bits cannot be done in a short publication such as this one
dipswitch 3 bit 1 is the fuser reset command {for error cdes f34,f35and f36}0 is no 1 is yes to reseta fuser fault you enter this mode select dipswitch 3, select bit 1and change "1"to "0"by pressing"off"
dipswitch 23 bit 7 is fuser web count-over stop machine will stop operating when fuser web life is reached if this is set to"1"
Aug 30, 2011 | Computers & Internet
What mean code f35-3 on konica 7020.
simulations note : 9272 is the standered password to enter simullation press9,2,7,2,start , to use these with power already on press and hold the"*"key util the display says "please enter service password"note:factory manual says"keep pressing" this might mean hold down or it might mean press repeatedly.press9272 start "mode selectmenu screen" will appear.press the mode you want[p ,25, 35, 36 , or 47] when finished press "normal mode"to return to standard screen use the number keys to change values press print key to check item press "stop/clear"when finished
"25 mode" to enter this mode turn power off, press the 2and 5 keys and hold them down while they are held down turn on power menu screen will list choices 1 software switches 2pm count 3collectng 4 5 select your choice enter value press"return"to see that your new value has been entered turn power off new in formation will not take effect util power is off and back on again 1 software sw ....use up/downarrows keys to select dip switch use up/down arrow keys to select to select bit number"on"is 1 "off" is "0" on will set bit off will clear bit press "return"to return to menu listing dipswitches and all their bits cannot be done in a short publication such as this one dipswitch 3 bit 1 is the fuser reset command {for error cdes f34,f35and f36}0 is no 1 is yes to reseta fuser fault you enter this mode select dipswitch 3, select bit 1and change "1"to "0"by pressing"off" dipswitch 23 bit 7 is fuser web count-over stop machine will stop operating when fuser web life is reached if this is set to"1"
Feb 24, 2011 | Office Equipment & Supplies
How I CAN CANCEL CODE U2 in sharp arm451n
This resets the code
Sim 16 sub 0 Used to cancel the self diag "U2" trouble. Cancel Trouble Error
SIMULATIONS
1. Entering the simulation mode
Enter the copy mode and perform the following procedures.
[P] [*] [C] [*] [Main code] [START] [Sub code] [START]
2. Switching the simulation mode
Press [USER SETTING] to return to the code entry screen.
3. Canceling the simulation mode
Press CA key to cancel the simulation mode.
You may need to have a tech look at this.
Hope that helps
Jun 23, 2008 | Sharp Office Equipment & Supplies
GPS Logo
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
