Question about Kenmore 95822 / 95824 / 95829 Electric Kitchen Range
F-3 Error message
I actually have the 957xx series model but don't find it in the listing. I have an EO F3 error message when I attempt to pre-heat the oven. Other controls seem to be working fine. From other posts I am guessing it is the sensor gone bad but just want to confirm. Where does one buy a new sensor and are they easy to install? Thanks so much
  • brenda68516 Jul 23, 2008
    I recieved the E0 F3 error code... repairman said it was oven sensor, tried it today, didn't fix problem. Repairman said it must be the control panel, $282 plus labor. Stove about 5 yrs old is it worth it or should I just get new? What's the life span of this model? Is it really the whole control panel or could it be something else? Problem started after storm, think lightning struck it. Help???
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 77 Answers
This error refers to either a sensor problem, check it with an ohm meter. should be around 1100 ohms at room tmp. you can order the part through sears, just give them the model number and ask for an oven sensor, or thermistor. ALLWAYS UNPLUG THE UNIT WHEN TESTING OR REPAIRING
Posted on Sep 28, 2007
Haier Wine Cellar, Dual model, displays EE error code and was heavily iced on the interior back.
If the refrigerator or freezer displays error code, request a technician to check, please call the service
Different series display different error codes.
The error codes for the refrigerator: F1, F2. F3, F4, F5, F6, F7, EO, E1, E2, E6, Er, Ed, an so on
The error codes for the wine cellar: F1, F2. F3, F4, F5, H1. H2, A1, A2, E1, E2, EE, HH, LL, and so on
Notice: If you power off then power on, maybe the error code disappear, but it will display again after a few hours.
Mar 27, 2018 | Haier Refrigerators
WHEN MY WHIRLPOOL BUILT IN OVEN MODEL RBS305PRS00 IS BAKING IT SOMETIMES CUT OFF AND YOU HEAR A CLICKING NOISE AND IT WILL DISPLAY EO F3.I CAN TURN THE OVEN OFF AND IT WILL BEEP AND DISPLAY EO F3.AFTE
That's an oven sensor error. Replace the oven sensor. If you still have the error, check the wiring and/or replace the timer/clock board.
Nov 26, 2014 | Whirlpool Ovens
Whirlpool Oven GW395LEGT6 Replaced the oven temp sensor But oven will pre-Heat and run for 15 minutes then shut off with Error code EO F3
Have you tried pulling the connectors off the control board and reinserting them. If you still have problems the control board could be the issue.
Sep 24, 2014 | Ovens
I have a kenmore gas range with a computer panel on it, error message is EO F3 and I cannot clear it or use top or oven.
Hello & Welcome to FixYa
F3 E0 error code indicates a open/shorted oven temperature sensor and to solve this problem the sensor needs replacement. If you wan to be sure before replacing the sensor then you can test it with a voltmeter for around 1100ohms....if it reads more then this then it needs replacement however, if the reading is around or less then 1100ohms then it is the control board that needs replacement. Please get back to me if you have any other questions.
Kevin
Jan 11, 2011 | Kenmore Kitchen Ranges
Whirlpool Model GBS307PB00 has error codes
HI. The reason for the PF code will be the result of the power cycling. When you switch the breaker to the off position, the main control board assumes that there has been a black out, thus, triggering the PF code. This is not your principal issue here. The F3-E0, which is your main issue, is the result of a failed oven temperature sensor. The control has sensed that the actual sensor circuit is stuck open(Not functioning or energized).
Your main control board is programed to shut off the entire unit, due to this apparent failure within the oven temp sensor. The necessary actions are to have the affected part replaced, asap. I would, also, advise to preform an electrical test. I will list the entire procedure below. Follow carefully, and with caution. Make sure that your units is unplugged before administrating the testing procedure.
Sensor testing procedure:
First,you will need to check the oven sensor wires that link the actual sensor to the main control board. Make sure that the contacts are connected properly, and not loose, or corroded. If all the wiring checks out, test the sensor for the correct resistance readings.(you will need a multimeter for this test)
The most common oven sensor should be approximately, 1100 ohms when at room temperature. The others may be close to as follows:
100°F - 1143 ohms
200°F - 1350 ohms
300°F - 1553 ohms
350°F - 1654 ohms
400°F - 1753 ohms
500°F - 1949 ohms
If the sensor test is adequate, and the wiring is Ok at the control, this will lead to a failed control board. replace the control in this case.
Sensor location
The sensor is, generally, located inside the oven, mounted on the back wall, on the top right, or left corner. There will be two screws holding the housing on the back of the oven wall. Once the screws are removed, the sensor will need to be extracted from the back side of the unit.
Apr 05, 2010 | Whirlpool GBS307PDS Electric Single Oven
Error message F7-EO
turn the circuit breaker off for about 15 mins. turn it back on and it might reset itself. let me know if it works!!!
Apr 05, 2009 | KitchenAid 30 in. Architect II Series 4.3...
Error message EO F3
Check Thermocouple Oven sensor. ShouldRead 1080 Ohms at roomtemp. If that is working youneed a new control Board
Feb 10, 2009 | Whirlpool RF364 Electric Kitchen Range
F3 Error Message
It needs a new key pad it is shorted the ge website has a list of error codes f3 is the keypad
Jan 31, 2008 | GE Advantium 120 Convection/Microwave Oven
GE Model JTP15 oven shows F3 error code
I have the same problem. I noticed that the oven gets to the selected temp ok. Then when the pilot attempts to RELIGHT, it gets the error F3. Did you get a solution? After other posts, I will see if the temp sensor is around 1100 ohm as suggested by others. Ken
Jun 14, 2007 | GE JTP15 Electric Single Oven
Error Message: EO -F2-, but I don't have a manual
Actual Solution: I justed fixed EO F2
1. Disconnect the power for 30 minutes!
2. Once reconnect the power, press the "cancel" button for 3-4 sec, this two steps serve as reset.
I have a Whirlpoor gas range and it has error message EO F2 for few weeks now. After searching on internet for possible solutions and didnt find anything working, I called Whirlpool thinking as a last attempt before calling expensive tech. people.
They told me exactly the above two steps, I came home and tried, it worked like a charm....
Note: Disconnect for 30 min, I tired 1 minute as some suggested on internet and didnt work.
Mar 04, 2007 | Kenmore 95002 / 95004 Electric Kitchen...
Kenmore 95822 / 95824 / 95829 Electric Kitchen Range Logo
109 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
